Question about Eureka 5893AVZ Bagless Upright Cyclonic Vacuum
It is plugged in but vacuum does not start. I
It is plugged in but vacuum does not start. I tried reset button and still it won't start up. Help. Model 5893.
    Problem Solver:
  • 9 Answers
If the belt is loose the motor wont run just a guess
Posted on Jul 12, 2009
Kenmore vacuum just died
Sorry about that . Before you bury it see if there is a reset button you can push to reset it. Most Vacs have reset buttons. Check electrical wires and plugs to make sure they are ok. Is the plug outlet you plug it into working. These are things that you can check. did it die or did you break a belt. Does it try to start but won't.If I could see it it would be easier to know but these are just ideas. Good Luck.
Feb 04, 2017 | Kenmore Vacuums
Kemore upright died will vacuuming
Sorry about that . Before you bury it see if there is a reset button you can push to reset it. Most Vacs have reset buttons. Check electrical wires and plugs to make sure they are ok. Is the plug outlet you plug it into working. These are things that you can check. did it die or did you break a belt. Does it try to start but won't.If I could see it it would be easier to know but these are just ideas. Good Luck. Posted on Feb 04, 2017
Feb 04, 2017 | Vacuums
Why wont the reset button depress on riccar 8955 or turn on after trying
The reset button does not have a significant amount of movement in response to pressing to with a paper clip or ball point pen. If the vacuum does not start upon pressing the button, then either the thermal protection circuit is not why the vacuum stopped in the first place or the reason the thermal protection circuit tripped has not been cleared. Quoting from the manual
"Your Riccar vacuum cleaner comes equipped with a Manual Reset Thermal Fuse Protector. This thermal protector is designed to protect your vacuum cleaner from overheating due to a restriction in airflow (i.e. clogged hose, operating the vacuum without a bag). Should this situation occur, the thermal fuse protector will safely shut off the vacuum cleaner to avoid any potential damage. NOTE: To determine it was the thermal fuse protector that turned off your vacuum
cleaner, please refer to the vacuum cleaner's headlight. If the headlight is on while the motor is off, then the thermal fuse protector did safely shut down the motor. If both the headlight and motor are off, then there is some reason other than the thermal protector (i.e. pulled plug) your vacuum is off.
To reset the thermal fuse:
. Unplug the vacuum cleaner
  1. Check for problem - over-filled bag, clog in hose, clogged filters, etc.
  2. Correct problem
  3. Locate "tripped" fuse - the small white button located on the bottom of the back side of the main body (roughly one inch to the right of the left wheel)
  4. Using a pencil, paper clip or other pointed object, push the reset button in
  5. Plug vacuum cleaner in and resume use"
Mar 08, 2015 | Riccar 8955 Upright Vacuum
Reset button power
Reset switch is located on the back of the vacuum and close to the back wheels.Press a reset switch a few times and vacuum should start. Check also cord plug . Many times metal prongs are broken at the end of the cord (usually one of them)
Nov 28, 2013 | Riccar 4812 Vacuum
I have a simplicity freedom F3700.2 upright vacuum. It has been working wonderfully until now. I plug it in and it won't start. I have tried removing the bottom and cleaning the roller, the bag isn't...
Sounds like a break in cord or plug somewhere. I am not familiar with the particular vacuum myself. Another thought I have when looking around your vacuum cleaner have you seen a red reset button anywhere at all?
Or by chance does your vacuum cleaner have a plug comes off....... (i.e. like a computer)
a few thoughts
Sep 02, 2013 | Simplicity Vacuums
My S5211 is 5 months old and was running perfectly. Last weekend I took it out to vacuum house but it would not start. I checked the fuse in the plug but it was fine. I replaced the dustbag but still it...
if you put everything back in place properly it should be working,check dust bag properly seated, and cover reseated, still not working do as planed, take it backto the shop, hope this helps
Sep 01, 2011 | Miele S5211 Deep Black Vacuum Cleaner...
Hi. My vacuum won't power up. The plug-in is OK. Is there a re-set on the motor I can try? Thank you, Vic
Need to know which vacuum it is. The more reasonable vacuums will not have a reset. You probably are missing a filter that needs to be cleaned. Your cord could be bad or even the plug on it. Depending on what it is worth and how much you like it, you should take it to a vacuum shop.
Jun 20, 2011 | Bissell 6596 Bagless Upright Vacuum
I have an electrolux discovery II vacuum cleaner and the floor function works, but when I try to switch over to carpet mode, it doesn't seem to engage.
There is a red reset button on the back of the machine. When it trips, the brush won't engage. Press the reset button and then try your machine again.
Apr 07, 2011 | Electrolux Vacuums
Where is the reset button the riccar 8850?
If you look down at the base of th vacuum cleaner at the vacuum bottom in the back, right above the rear wheels, you will see a small red button. Take a ball point pen, and while the vacuum is plugged in, go ahead and push the red button or the reset switch. Did the vacuum come on?
If not, it may another simple problem of the cord/ plug going bad.
I think if it just stopped workint all or a sudden, it's prbably the reset switch.
If this was helpful to you, please help other Fixya users find the repair by clicking the thumbs up icons.
Thank you,
Chris J.
GoVacuum
Apr 09, 2010 | Riccar 8850 Vacuum
Vacuum g6 won't turn on
Hi
Either the bag or the main head is not locked on correctly
Feb 22, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Eureka 5893AVZ Bagless Upright Cyclonic Vacuum Logo
337 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
