Question about Makita AN901 Coil Nailers
Need tofind a used nose peice - Makita AN901 Coil Nailers
  • 142 Answers
This solution may sound way out there, but generally nose pieces are expensive, so you may want to go hunting through the pawn shops for the same model, in crappy condition, in order to get one
Posted on Jul 13, 2009
Have broken dipstick 05caravan but still have peice of plastic tip on dipstick now how can I get it out????
You might have to remove the dipstick tube in order to push the remaining piece out.
Oct 03, 2016 | Cars & Trucks
What can I do hdmi broke off of ps4
turn off and unplug. wait 15 minutes. get needle nose pliers and pull broke peice out. make sure to get all little peices out. vacuum the port to extract all the small peices. plug new hdmi in and enjoy
Jun 22, 2015 | PS4 Video Game Consoles & Games
Where is the drive depth adjustment on the FC350?
On the front of the nose, where the two peices of the safety come together there is a hex head screw. Loosen that screw and the lower piece can be extended or retracted. The more the lower safety extends past the nose, the higher the nail will be left in the work. The shorter it is, the deeper the nail will be driven.
Mar 27, 2012 | Porter Cable Air Tools & Compressors
Why does my Auto Feed Screwdriver not screw deep enough?
What model auto-feed screwdriver do you have? All of the auto-feed drivers I have worked on have an adjustable nose peice that has to be set to the length of the screw so they will start properly and drive correctly. They also have a fine tune adjustment wheel somehwere on the tool so you can set the screw to be anywhere from just below the surface (dimpled) or flush or slightly above the surface (proud). This is all in relation to the surface the nose peice is touching. The driver is designed to release the bit when the screw has reached the depth set by the adjustment wheel so it doesn't strip out the head of the screw. I don't know of any that would let you set it so the screw would go through the plasterboard (drywall) and end up flush in the wood.
Feb 15, 2012 | Makita Drills
The nose rubber peices broke off, only a part of the wire is visable.Can they be fixed?
hello
yes you can replace it from any sunglass repair shop easily.
good luck
Dec 14, 2010 | Burberry BE 3011 Sunglasses
Nail is jammed in my Bostitch power finish nailer and partially sticking out. When pull on nail with pliers, it won't come out.
Remove driver guide nose peice, should be a couple of alan screws, remove nail, check driver to make sure it is not bent, re assemble. Make sure you are using the correct Nails!
Aug 27, 2010 | Stanley Bostitch N88rh Framing Nailer...
Senco 601 nailer shoots 2 nails each time the trigger is pulled.
the 601 had a design flaw, in the nose, where the nails hit as the are being pushed forward, the peice was made out of a peice of metal that was too soft, it wore down and that is where you get the double nail problem.
Senco offered a trade in, this was years ago, for a limited time and gave us credit towards new guns, which we gladly did
Dec 31, 2009 | Senco & Frame Pro 601 Framing Nailer
I was using my framing nailer on some framing and after about 20 nails it started acting up know I have to pull the head forward shoot a nail and pullit again I don't know what I need to do to it, could...
the nose peice it either bent or dirty. if you over oil it this will make it dirty and jam. should have a spring arm that flips back and allows inspection of loading mechanisim. look for burs or binding parts, wire or nail heads are common. check piston tip too for malled end to. they are pretty simple to fix just look and c whats binding.
Sep 03, 2009 | Campbell Hausfeld Air Tools & Compressors
Cant get any torque,chuck head keeps slipping on my 18v cordless drill
check the plastic nose peice for setting. 1 is the tightest and the higher the number the more it slips. if is on 1 or the 'drill' setting and is slipping than somthing internal has failed
Sep 02, 2009 | Drills
Makita AN901 Coil Nailers Logo
54 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
