Well i have a ibm mainboard with socket mpga 478b
Well i have a icm mainboard with socket mpga 478b i need to change it but i am not sure if that is the problem how can ia know if this does not work beacuse i have done all what i done including changing ram memry formating the hard disk etc but the computer does not start the windows i neded help
It's your motherbord problem
check 6.3v capacitar in motherbord
Posted on Oct 26, 2010
    Sergeant:
  • 400 Answers
Does it load the BIOS( Basic integrated operating system). then check power supply ,if no power to the computer.
Posted on Jul 12, 2009
Socket 478 mpga p4m266 drivers
to old MB, you can try driver genius11
Feb 03, 2014 | IBM (02R4083) Motherboard
IBM Server x3400 7975 our Mainboard crashed. How to access Data on Raid ? Does it work with a replaces Mainboard ?
What operating system does it use?
The problem is whether you're using hardware RAID or software RAID.
Hardware RAID will likely require another motherboard to read. Software RAID can be read in any other machine that can run the operating system.
Nov 25, 2013 | IBM x3400 Server
Mother socket no:mPGA 478B i have a display problem in my board. i clean the ram and remove the processor and clean it, and then change the jumper setting also. the problem has been not over no beep...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size larger size or custom settings
always click APPLY after making any changes
also
hope this helps
Jun 03, 2011 | Intel PGA478 Motherboard
What`s the maximum processor upgrade for IBM ThinkCentre M51?
MAXIMUM CPU FOR IBM M51 = Pentium 4 650
3,40 GHZ / 2M CACHE / FSB 800 / HT / SOCKET 775 ( SL7Z7 or SL8Q5 ) they take 84 Watt, by the way, change the power supply,with connections for Pcie x16 graph-cards ,like 800 Watt. HD cards are not supportet, Max.- card is ATI x1950 Pcie x16 512MB. Do not try the ATI 5450 will not work.
Processors:
DO NOT THINK ABAUT THE P4, 651 / 660 / or 661 ,will not work .( multiplier is 17 ) and not supportet by the mainboard and chipset.
Nov 20, 2010 | IBM ThinkCentre M51 PC Desktop
I can not find drivers for the motherboard 533 socket 478 Prescott Intel i845G chipset mPGA at www.asrock.com. Where should I download the driver?
As for your Asrock Mainboard with the Intel i845G chipset it support only Win XP, W2K & Win 98.
Here the download site for the drivers @ http://www.asrock.com/mb/download.asp?Model=P4i45G&o=All
Hope it helps.
"Courtesy is free but it will carry you forward a long way in a lifetime!"
Nov 02, 2010 | Computers & Internet
Socket 478 mpga builtin sound card driver
You can download the drivers from Intel WEB site. Select your model motherboard/device, and make sure you select the Windows XP or
Vista version of the drivers that matches your Windows operating system.
Click on this link: -
http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Jul 22, 2010 | Intel Motherboard
I have Dell Latitude D600 orginal with BIOS A16 and Intel(R) Pentium(R) M processor 1500MHz,Banias,Socket 479 mPGA,my question is --- can I replace with :Intel Pentium M 760,Intel(R) Pentium(R) M processor...
For information for your D600 model use this link to the Dell WEB site.
http://support.dell.com/support/edocs/systems/latd600/en/index.htm
The service manual listed these CPUs.
The recommended processors for the D600 are :-
Processors
7U338
1.3 GHz CPU
7R414
1.4 GHz CPU
6R637
1.5 GHz CPU
4R867
1.6 GHz CPU
4W884
1.7 GHz CPU
Jul 24, 2009 | Dell Latitude D600 Notebook
Video Card question...
It can support the card although the bus speed of the board could limit video thru-put. Another issue to consider is the wattage of the power supply which is at the low end of what is required. I would recommend a 400W minimum.
Apr 25, 2009 | IBM ThinkCentre M51 PC Desktop
Memory inserted Wrong side
Unfortunately the memory socket has probably been damaged. An experienced electronics technician might be able to replace it, but the board could easily be damaged by the replacement work. It would probably be best to replace the motherboard in this case.
Feb 26, 2008 | Computers & Internet
Computers & Internet Logo
407 people viewed this question
David Payne
David Payne
