Question about Refrigerators
Kenmore 106.53252202 ice door parts assembly - Refrigerators
  • 4,070 Answers
Kenmore Elite 106.54609300 What are the exterior dimensions? H,W,D I need to replace with a similar sized refrigerator in an enclosed spot. Can't find this info anywhere.
This is not credible request: Manuals are available from SEARS...
Use your measuring tape... and then go to the MANUAL and add the required clearances
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/user-manuals/manual-downloads/Model-10654609300/0582/0165000?modelNumber=10654609300&diagramPageId=&documentId=26037129
STRAIGHT FROM THE OWNERS PDF
Door ...
shipping dimensions... seriously!
Part Information
This manufacturer-approved door assembly (part number L2255526LJ) is for refrigerators, including Kenmore refrigerator model 10654602300.
Unplug the refrigerator to disconnect electrical power before installing the new door assembly.
Follow the instructions in your owner's manual or installation guide to remove the existing door and install the new door assembly L2255526LJ
This Refrigerator Door Assembly part #L2255526LJ is guaranteed to fit your KENMORE REFRIGERATOR #10654609300
Door shipping Specifications
  • Category: Refrigerators and Freezers
  • Shipping Length: 77 in
  • Shipping Width: 28 in
  • Shipping Height: 13 in
  • Shipping Weight: 45 lbs
for questions or assistance, call 1-800-733-1381
M-F 6:30 a.m. - 10:30 p.m. CT
Sat 7:00 a.m. - 9:30 p.m. CT
Sun 7:30 a.m. - 9:30 p.m. CT
(Se Habla Espa?ol)
Jan 03, 2016 | Kenmore Refrigerators
Red light inside the freezer part stay on for my side by side Kenmore refrigerator
Hello William;
My name is Peter. I am a retired field service refrigeration technician.
The, 'Red' light is a infra red light. This light assembly on the right hand side of your freezer is the transmitter.
Directly across is the receiver. On the receiver is a spring loaded plastic flapper.
This is a safety device for your ice maker. When the freezer door is closed, the flapper is closed, allowing the infra red transmitter to complete the signal to the receiver. This allows the ice maker to discharge ice cubes. When the door is open the signal is broken, the flapper springs out blocking the circuit signal, and the ice maker will not discharge ice cubes.
There is a On/Off switch on the red transmitter. I do not know why you would want to turn it off. If you turn it off and the transmitter stays on then you have to replace both the transmitter and receiver.
Nov 11, 2014 | Kenmore Refrigerators
Ice and water keeps coming out
Cup lever isn't returning to the off or close position completely. Suggest checking for rusty spring, dirty parts restricting lever and other parts there from moving freely. Could be the switches are worn out as well. Dis-assemble and clean all parts and inspect or replace old worn switches. Inspect ice drop/ flap door for mildew, sticky residue from drinks and ice build up.
Feb 09, 2014 | Kenmore Elite 31 cu. ft. Grab-N-Go...
I need to remove the front cover assembly to replace the ice dispenser door. The model number is Kenmore 106.59292992. Regards... MGH
pop off the front trim with a flat screw driver or putty knife. then remove bolt holding silver clip between ice door and water. door should slide out to replace.
Nov 02, 2010 | Kenmore Refrigerators
Kenmore freezer won't make ice
If you did not replace the thermostat then it is possibly your problem The thermostat tells the ice maker to do every function.Sears uses a model number that is different than anyone. For example 213.546987 should be listed near floor and behind fresh food section door above the kick plate.Get me that number and I will be able to look at the parts for your ice maker. Sea Breeze
Jul 02, 2009 | Kenmore Refrigerators
I have a kenmore three door refrigerator ice crystal built
This is usually due to an air leak at the freezer door/drawer. Check out the gasket and if it is bad, out of place replace it. If the gasket looks good go around the door with a dollar bill closing the bill in the door. The dollar bill should resist being pulled out. If you find spots where the bill slips out easily this is a spot where the door/drawer is not sealing good and letting in air causing the frosting.
Go here for: Kenmore-Refrigerator-Parts
RepairClinic.com
Appliance parts, help & more
Apr 29, 2009 | Kenmore 24.8 cu. ft. Trio French Door...
Ice door for ice dispenser not shutting.
How do I remove the ice/water dispenser front cover assembly
May 22, 2008 | Kenmore 53542 / 53544 Side by Side...
Kenmore side by side refridgerator w/water and ice in door
If there is a lot of water dripping and I guess there is since you had to turn the water off, you need to replace the dual solenoid valve to cure your problem. You did not post your model number so it is not possible for me to say if you have more than one valve assembly in your refrigerator. If you have 2 separate valve assemblies you will need to disconnect the lines one at a time to locate the correct valve to replace. I hope this helped you.
supertechks
Please don't forget to rate me
Jan 16, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frost buildup in ice-dispenser tube
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced. The problem you describe is almost always air laekage around that flap. Post back if you need more help.
Oct 18, 2007 | Refrigerators
Refrigerators Logo
107 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
