Question about Canon PowerShot SD1100 IS Digital Camera
Canon SD100 Lens Error (camera)
My 3 month old Canon SD1100 camera will not work as it says "Lens Error" It happened during our vacation so I assume sand may have gotten into it. Any suggestions?
    Sergeant:
    Champion:
  • 270 Answers
Your assumption is probably correct. Even dust can cause the lens to get stuck (pg 193). You might try using a can of compressed air while pressing the power button to see if you can free the lens or take it to a camera shop like Ritz.
Posted on Jul 12, 2009
  • Canon Master
  • 4,738 Answers
First try calling 1-800-OK-CANON to see if warranty repair applies. If not...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Lens barrel is stuck in the out position on my Canon Powershot SD1100 IS. Error message reads: "Lens error, restart camera". To my knowledge the camera has not been dropped and the barrel seems...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Jul 20, 2011 | Canon PowerShot SD1100 IS Digital Camera
When i turn my camera on i get amessage lens error restart camera.
The lens error is due to failure of the lens control system. It will be good to have it checked at the Canon service as you do not have to run around for spares.
You can remove battery and card replace battery and while switching on tap the lens hood on your palms so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service centre.
get estimate before you decide.
Oct 07, 2010 | Canon PowerShot SD1100 IS Digital Camera
Cannon powershot SD1100 IS it displays the
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
Nov 24, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
My canon SD1100 Is digital camera lens came open in my pocket and now wont open or close. How can I repair this?
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 22, 2009 | Canon PowerShot SD1100 IS Digital Camera
Lens error canon powershot sd1100 is
Apparently, you missed some sand and it just took a while to work its evil way into the works of your camera.
Aug 11, 2009 | Canon PowerShot SD1100 IS Digital Camera
Lens error restart camera
Aug 10, 2009 | Canon PowerShot SD1100 IS Digital Camera
Aug 02, 2009 | Canon PowerShot SD1100 IS Digital Camera
same thing just happened to me today. the little girl that I babysit dropped it about 1 foot to the rug on the ground, not a hard drop at all. so i tried taking out the batteries and hit it on the table (read on other sites) then i gently turned the end of the lens (my lens was stuck out) counter clock wise and it clicked and then worked.
Apr 20, 2009 | Canon PowerShot SD1100 IS Digital Camera
Lens wont move
Apr 17, 2009 | Canon PowerShot SD110 / IXUS IIs Digital...
Canon SD600 lens jam
I followed the directions contained in http://www.avh.dds.nl/Fix-Canon-SD600-Lens-Error/ and by disassembling the camera and turning the rotor just a little bit (page 4 of the instructions), it freed up the lens and it is now working perfectly! The camera had been put down on the lens as the lens was retracting and I assume that jammed the retract mechanism. While the camera was open, I blew out whatever dust/dirt was there (didn't see much). The fix took me probably 20-30 minutes, and I am very pleased with myself!
Oct 24, 2007 | Canon PowerShot SD600 Digital Camera
Canon PowerShot SD1100 IS Digital Camera Logo
470 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
