Question about Campbell Hausfeld Airless Spray Guns & Accessories Roller 20 Inch Roller Attachment Each AL2275
Airless sprayer will not prime Model AL230502LX
    President:
  • 1,273 Answers
Check for a plunger on the bottom of the machine. Pump it several times and try to prime with water. Also, if there is difficulty priming after trying the plunger, switch on in prime, and cycle to paint, back to prime,paint,prime. After several tries, leave it in prime with the pickup tube in water, and pump the plunger again. If this doesn't help, disconnect the hose fron the pump and try again. If you're getting water now, the issue is down the hose, or at the roller/gun.
Hope this helps! --W/D--
Posted on Jul 19, 2009
Sprayer was working fine and ran low on paint and lost prime. could not get it to re-prime. now its still got paint in it and i can't get it to do anything. i need to clean it ont.
I haven't much experience with airless sprayers but I have heard the bad language from those who use them.
I expect there is still paint in the business end of the mechanism and an air bubble stuck between that and the new paint fill.
I think the sprayhead will have to be removed or dismantled so the air will be able to escape and allow priming to take place. I suggest spending a little time with the instruction manual.
Dec 05, 2015 | Titan Xl 335, xt 330 Airless Paint Sprayer
How to repack the sprayer
The packings are static and self adjusting. The repack kit includes the piston so it replaces everything. Just buy the kit and follow the instructions. Try Scott at American Airless on 770 4771337.
Aug 25, 2014 | Titan Paint Sprayer. Advantage 200 Airless...
440i titan only pressure is between 0-200 psi no matter the setting
If an airless paint sprayer won't prime it's usually because one or both check balls are stuck. First try hitting the head where the pump is sharply with a hammer, hard enough to knock the balls loose but not so much that you do any damage to the pump. If that doesn't free them up you may have to take the pump apart and clean them and their seats.
If an airless paint sprayer won't develop pressure, it's usually because the packing rnigs are damaged or collapsed. The only way to check this is to totally disassemble the pump and check them. Also look for any damage to the piston and cylinder. They must be very smooth and shiney, if they are scored they will eat up any new packing rings you put in.
Jul 19, 2012 | Titan 440 Impact Airless Paint Sprayer...
Graco magnum paint sprayer won't prime
Airless won't prime- I always start trouble shooting an Airless that won't build/hold pressure look at sump hose inlet filter (the hose that goes into the paint if its got paint debris on it clean off filter and pour the paint thru a strainer bag into a clean 5 gal bucket-also remove the filter housing on the spayer and clean and flush and replace filter and housing- the shaft or the metal sleave has two ball bearings called "check balls" that maybe stuck turn on sprayer and put a piece of wood on shaft and give it a few good taps this will knock the check balls loose if after all this fails then you need to have new packings put in becuase the old ones are worn this is pretty easy to see because the rod the compresses the paint will have signs of paint on it indicating that the packings are worn.. Note keep rod and other moving parts oiled ith graco throat seal and finally Graco sprayers with the X on them are there (Graco) home owner line of sprayers that sell at home depot they are rated for only a certain amount of Gal per year keep it in good condition and cleaned store with coro-check inside of the pump when you are done using it.....
May 27, 2012 | GRACO INC 232745 Magnum XR-7 3/4-HP...
Owners manual for a campbell hausfeld model # AL233300LX airless sprayer
http://www.chpower.com/manualsearch/
Manuals for Model: AL2333Manual Description Classic Mega Bytes
AL SeriesParts List- AL Airless Breakdown.6AL SeriesParts List- AL Airless Models - Breakdown with Block- 2001.073.1AL SeriesSafety Sheet- 2011.06AL SeriesSpecifications- Airless Tip Compatibility.3AL SeriesSpecifications- Paint Tip Selection Chart- 2003.04.5
Nov 12, 2011 | Campbell Hausfeld Airless Spray Guns &...
I HAVE A MODEL sx55nxpcd-7443 ailess sprayer that has not been used in 4yesrs I tried to use it today I put a bucket of water for the pick up tube but nothing happens Ihave also missed placed my maunel...
When you say nothing happened.
If the machine doesn't run at all, check the cord and plug.
If the machine doesn't pick up paint, read the following:
There are 2 steel balls inside the sprayer.
The first one is in the pipe at the first joint > this ball keeps prime in the pump head.
The second ball is 5" higher, and it is opened and closed by the prime valve
These balls can rust and then the sprayer needs to be replaced
Always store sprayer filled with kerosene
The prime valve goes bad too
And the intake can be clogged with wasp nest or paint.
Let's say your prime valve is okay, and the pipe is not clogged.
Tap the pipe where the ball is located while the machine is running.
See if you can loosen the ball.
If you can't loosen it, take the pipe apart, but be careful because the ball has to fit perfectly to hold the high pressure of a paint sprayer.
If you can get the machine to prime, then tap the next ball to see if machine will fill the hose.
Oct 22, 2010 | Campbell Hausfeld Airless Spray Guns &...
AL2340 will not prime. Motor runs but cannot get it to prime
I worked at a tool rental center when I was going to college and learned many useful tips / tricks about airless sprayers. Airless sprayers have two check valves/balls that can stick on their seats or stay open due to chips of paint on seat. Easy method to prime is to remove intake filter from machine, tilt the machine back far enough so that the pick-up tube is pointing up high enough to pour water in tube until full; hold in this position and turn on machine. If water is sucked in turn off machine and tilt machine into pail of water and restart to check for prime. If it still will not prime remove water from pickup tube and use air pressure into tube with bypass valve open. Air pressure will attempt to release the stuck lower check ball. If air pressure does not release stuck ball you may have to use physical pressure against ball. If lower check ball was stuck you can assume that the upper check ball is probably stuck also. An aid to loosen stickey valves is to pour solvent into pickup tube with machine tilted back as before leave overnite. Enjoy
Dec 09, 2008 | Campbell Hausfeld Airless Spray Guns &...
Campbell Hausfeld Airless Spray Guns & Accessories Roller 20 Inch Roller Attachment Each AL2275 Logo
1,185 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
