Question about LG WD-16115FD Front Load Washer
The door to my lg washer won't open - can you help
Slide a flat tool (paint scraper,screwdriver )between the door and machine body where the door latch is.you should be able to push the latch open. worked for me.
Posted on Sep 30, 2009
    Problem Solver:
  • 8 Answers
I agree with mnilgwia40 that a springy steel tool.... I used an old long knife with a flat end and springy... worked a treat.
Posted on Feb 14, 2010
3 Suggested Answers
SOURCE: faulty door catch on my LG washer?
I have had the same problem for a week now. Until I find a spare part I slide a scraper to push the catch open. That just works.
Posted on Jan 30, 2008
rickead1
  • 1998 Answers
SOURCE: Hi, I can't open the
I am unable to find that model number for your unit but I did find another that was close and is also an LG Tromm click this link http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28702783&pkw_=basket&model_id=5520802&NewWindow=1 you would have to remove the bottom panel the one that has the drain filter attached to it by removeing the screws that hold the panel in place. Once the panel is removed then you would reach up along the side that the door lock assembly is on and you will see and feel a cord with a ring that you would pull and then your door would open once you pulled this cord. In some units if you unplug the machine for 7 minutes this also causes the control to reset and sometimes this also causes the door to be able to open once the control is reset. If you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation Thanks Rick
Posted on Aug 16, 2011
Washer won't unlock
These doors are usually on a timer and so won't be released for opening until a couple of minutes have passed by after turning the machine off.
Assuming you've already allowed for this, try giving the door a good firm push (closing) on the mechanism. It may just have caught partially closed.
Apr 28, 2012 | LG WM2455 Front Load Washer
Door won't open
You will need to remove the top cover of the washer and reach down to release the door with the manual release.
Apr 25, 2012 | LG Washing Machines
Hi, I can't open the washer's door when it's done washing. I tried washing again, turn on/off the main switch but the door just won't open up. Please help! The LG Tromm model is...
Aug 16, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Have a de error so washer won't work how do i fix?
A DE Error Code is indicative of a "Door Error"
Check in this link the LG procedure: lgknowledgebase.com/kb/index
Hope helps.
Aug 11, 2011 | LG WM-2277HW Front Load Washer
I pushed the 'pause' button during the wash cycle of my LG WD-3274HD and now the door won't open.
Hi!
The machine knows it dint't finish the washing cycle, and, because it may be possible that water is still a lot inside, the door is locked.
If you are shure the door can be opened without the water coming out by the door, simply disconnect it from the electrical supply and wait a few minutes until the door unlocks. (you will hear the unlock click)
Aug 08, 2011 | LG WD-3274RHD Front Load Washer / Dryer
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
Won't come on say's de
dE: door error. open door. switch is out, clothes in door?
Service manual and more
Jun 27, 2011 | LG WM-2277HW Front Load Washer
Door won't unlock
take top off reach down with flat head screw driver and pop open unplug unit first then replace door lock
May 13, 2011 | LG WM-2277HW Front Load Washer
LG WD-16115FD Front Load Washer Logo
5,344 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
