Question about HP Photosmart C7280 Laser Printer
Trying to print a picture. printer tells me to load glossy side down in photo tray even though the paper is there.
    Scholar:
  • 113 Answers
Try going into the advanced settings and make sure it's on the right settings there .
Posted on Jul 13, 2009
  • Daryn  Horn
    Daryn Horn Jul 13, 2009
    try going into the advanced settings and make sure it's on the right settings there .
Sharp mx3110n printer won't use bypass tray? Trying to print on glossy paper using that tray and it won't, it automatically switches to tray 1. Or can I just put glossy paper in tray 1?
Hello Laura,
Here is the pdf that explains how to set up th bypass tray; http://support.appstate.edu/sites/support.appstate.edu/files/MX3110%20USE%20SPECIAL%20PAPER%20IN%20THE%20BYPASS.pdf
The text of it is as follows;
TO USE SPECIAL PAPER IN THE BYPASS
? Press either the picture of the copier or press
paper select
? Load paper in the bypass
? Make sure the correct size shows up under
bypass tray
? If paper is not just plain paper press type and
size
? Choose paper type
? If you are printing to the bypass from your
computer you must also tell the print driver
under the paper tab what type of paper is in
the bypass if its not just plain paper
? The copier and the PC must match paper
types
? Press the X button to Accept
Good Luck!
Rich Lilja
Feb 21, 2015 | Sharp Office Equipment & Supplies
How do I print color photos on glossy paper with Canon Pixma MP 6
printer supports it. just you have to goto printing preferences or printer properties and set rear tray to accept glossy paper. it will accept size of paper ur using. so give the actual size.
Apr 23, 2009 | Office Equipment & Supplies
When I try to print photos from a memory stick it fails to print and tells me to load paper glossy side down even though there is enough paper properly loaded. When I take out the paper the top sheet has...
The problem is that the metal paper stop is not fully recessing into the guide at the rear of the printer and the photo paper is catching on the lip on top of the stop. Take the back cover off the printer and check that the guide has not moved out of position. Also try to twist the photo paper tray to the left or right so the stop lines up better with the guide recess. This worked for my printer tempoarily, but then things went out of allignment again, so I took a slightly more drastic step. With only a single sheet of photo paper in the tray, print another photo. When the photo tray slides back to deliver the paper to the rollers, unplug the power cord from the rear of the printer to stop the tray from moving forward again. With a pair of needlenose pliers, bend the lip on top of the metal paper stop upward. This fixed my problem permanently.
Oct 19, 2009 | HP C7200-69016 Network Adapter
Trouble photo printing
hello.. try to unplug the power cord and usb cord and replug again and also chick the inside part of your printer maybe have a paper jump or ashes due to saying of of paper or try to remove the printer driver software how to remove? go to control panel and click the name (ad and remove program )and you can see the currently install files find your printer driver bellow the currently install files and remove it and install again..........thank you hope i can help you.. have a good day
Jul 06, 2009 | HP Photosmart C6280 Printer
Keeps saying to load paper glossy side down even when full j ust off of photo tray
It's telling you to turn over the paper so that the shiny side is down. The back side with the stripes and logo should face up.
Jul 03, 2009 | HP Photosmart C8180 All-in-One InkJet...
Won't accept photo paper
Only load photo paper do not mix it with plain paper, this will happen on all printers.
May 03, 2017 | Brother MFC-260C All-In-One InkJet Printer
Pictures will not print and paper will not load for printing pict
You need to push the paper through just touching the boundary of the printer paper tray
Feb 12, 2009 | HP Photosmart D7260 Printer
HP Photosmart C5280 doesn't print photo
my steven
u need to chek setting of pritner in pc when u do pritner command it's show pritner propaty this is capple of options like in cd pritner on photo 4x6 also give all setting u have to chek this setting it's help u
Jan 09, 2009 | HP Photosmart C5280 InkJet Printer
Kodak 5300 wont print on glossy side of photo paper
I just sussed this issue out. On the front of the printer tray there is another pull out tray, this opens up and must activate the photo printing for A4 because it stops the paper falling on the floor once printed (cos once printed on photo paper it may still be wet). As soon as I opened the tray (and it then opens again - you'll see what I mean) it printed A4 photo paper perfectly
Hope this helps others
Feb 23, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
HP Photosmart C7280 Laser Printer Logo
175 people viewed this question
Seeker5211
Seeker5211
