Question about Westinghouse Refrigerators
Westinghouse fridge ice maker stopped making ice, water dispenses
My Westinghouse side by side fridge WRSZ28V8A Auto Ice maker stopped working. water dispenser works ok. On-off wire lever functions and ice release fingers manifold makes a full turn. No problem light is on. It seems ice maker gets no water. Where can it be clogged and how to get there ?
  • etpal Jul 13, 2009
    Sorry your answer does not help me one bit. I can't find out where the possible clogged nozzle is, there's no literature on the ice maker or indication where the parts are, I can't figure any access to the parts. the filter is not the answer because water is running in the water dispenser that logically feeds from same filter
    President:
  • 2,187 Answers
If it was determined that the no water is coming in the ice maker, you may have to check the fill valve. This is the one that lets the water in the ice maker. See if it is working correctly by checking the continuity of the solenoid without any power to the fridge. If it has no continuity, it needs replacing. The fill valve in most units can be found at back at the bottom of the unit. You might as well check the tubing while at it and check for obstructions.
Posted on Jul 13, 2009
  • 3,230 Answers
Check for right direction on the filter,check the water intake solenoid valve.water pressure. check that the bin is seated properly and all interlock switches are closed and working. check and see if the nozzles are blocked..run with apple cider in the unit until unblocked. install new filter and some sort of water softer.
you need to change your filter or you have air in the line just run water in your refrigerator for about three to five minutes and try again.....
post further comments..
Good Luck!!
Thanks
Posted on Jul 12, 2009
Just bought a used westinghouse RJ275M fridge. It seems to work fine except for the noise - it has a low hum and rattling noise.
It can be compressor fan noise,may be motor getting overheated and causing noise.It has to be inspected.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
My maytag msd2657heb i could hear it running but the fridge and freezer not cold at all
It can be faulty compressor or issue with defrost.
These will help.
Thanks,.
I have a Westinghouse side by side refridgerater with water and ice dispenser. The other day I arrived home to find water pouring through the back of the freezer section into the ice maker,and into ice...
Your water control has two sides. One side is for the ice maker and other is the water disapenser. If the ice maker valve becomes mechanically defective the water valve can allow water to continue to flow or not flow at all. Replace the water control valve and I believe this will solve this porblem, Thanks Sea Breeze
Dec 11, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not working, no water or ice dispensed.
Cause found to be faulty ice/water control board which is located at the back left hand side of the condensor behind the water solinoid valves.This is the single most expensive part of the ice maker!
Oct 13, 2009 | Westinghouse Refrigerators
Stopped making ice
First of all is the water flowing into the ice-maker? Check the solenoid valve which regulates this water flow to the dispenser & ice maker. If water is flowing in, the ice-maker's thermostat may have malfunctioned, since this thermostat is separate from that inside the fridge...........sodeep
Aug 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE side by side fridge/freezer is working, water dispensing ok, but not making ice. I switch off the fridge, than ice maker but still not making ice. I try all the hints from Manual but no luck. Water...
fill the ice maker with water manually, if you have ice in the bucket you know that the ice maker is working , after check the water valve if is opening , if it is replace main board
Jun 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana Side-by-Side Fridge Model SBD21VPSE Problem started when water stopped flowing from in-door dispenser and ice maker stopped making ice. I emptied fridge and freezer, left unit off for several...
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Nov 29, 2008 | Refrigerators
Water dispenser
wow that's agood one!!!! theres a short for sure, just a matter of where. somehow your energizing both sides of water valve at once, sounds as if it would be behind the dispensor, at the switches. would remove the dispensor cover and have a look for a bad switch or exposed wire
Mar 08, 2008 | Refrigerators
Refrigerators Logo
47 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
