SOURCE: I have a new vivitar i can not see anything out the lens
TAKE THE CAPS OFF THE ENDS! THE MIRROR MAY HAVE BROKEN INSIDE!
SOURCE: vivitar 60050
Hi
The manual that came with it is very limited shows Parts and a diagram and a small blurb Happy to photocopy it and send to you if you wish Kauricot New Zealand
SOURCE: WE have an Australian Geographic
Without a porro-prism or a erect image diagonal, all telescopes show a reversed image. This is normal. There is no up/down in space. If you want to use the scope for terrestrial viewing, see first sentence. Do not use a erect image accessory for astronomy since it reduces the contrast.
Testimonial: "Thanks for the response. We wondered if that was the reason. No more looking at the hills!"
SOURCE: I have a Vivitar Telescope 60x/120x VIV-50600.
The only thing I can think to ask is whether you have fitted an eyepiece (NOT the barlow lens, if it came with one). Eyepieces are small lenses marked with a focal length (in mm, like 20mm or 9mm). They fit into the part that does the focussing, and are held by a small screw that you tighten with your fingers. If you have fitted an eyepiece and it still won't focus then I don't understand what is going on.
I would suggest that this is one of those problems best sorted by an experienced person physically present.
