Question about Samsung LN-S4051D 40 in. LCD Television
LA40R71 problem... I have a Samsung 40" LCD TV, model # LA40R71. I've had it for one year. Recently I've noticed that on the left side of the screen, about one-third, the color is duller in some scenes. I have ruled out the sattelite receiver, and have changed the input cables, so it's none of these causing the problem.I simply have the receiver hooked up through video cables; one yellow, and the red and white audio. What's odd is that the problem is very bad when connected to the AV1 source ports, but much better when I connect to the AV2 source ports. Even in the AV2 ports, it's still slightly noticable. It's most noticable in dark scenes, especially connected to AV1.Does anyone have an idea of what is causing this? I'm currently living in a country where the customer support is almost nonexisitant, so I'm hoping to at least determine a probable cause.Thanks, Bryon
  • Krustov Dec 30, 2007
    I have the same problem, and it appears regardless of the input.  Cable box, Xbox, etc.  My TV is just over 1 year old, but it's had this problem for at least 6 months.
  • 244 Answers
SOURCE: AV1 / AV2 Connections don't work
No picture or dark picture
Check R516 (56Kohms, 0.5w) or R517 (27Kohms, 0.25w) for high
Will not come out of standby, no picture
If at power on voltage on pin 37 of the micro drops low then reverts to 5v suspect memory chip ICA07 (Toshiba 23319016)
No picture No sound
Faulty IC TDA6107q on crt board
No picture on e-e, I.F output ok
This was due to switching chip IC3901 (M51292FP) on the scart panel
Posted on Nov 26, 2007
SOURCE: blue tint
I had this problem as well. I tried adjusting the voltage, but it only caused different color problems.
If you using HDMI, try checking your HDMI connection. I found that by I could simply "jiggle" (yes, that the technical term..he he) the HDMI cable around - while the cable was fully/completely attached to the TV - until I found a position where the color issues went away.
Now, the only problem is that I have to go and "adjust" the HDMI cable from time to time as the cable seems to shift over time. I'm thinking there is a problem with the HDMI input board on my tv (42" plasma - HP-S4253). But, since I'm over 3 months out of warranty, I'm not about to shell out big bucks for a new board. I can live with adjusting the cable from time to time.
Posted on Feb 07, 2008
tv start working on its own.
Posted on Jun 27, 2008
SOURCE: samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Posted on Jun 28, 2008
SOURCE: I bougth a lcd samsung 40 inch tv. I cannot connect my gamecube
You need to get a special scart lead which you can connect your red, white and yellow leads to then connect the scart lead to your tv it should work then
Posted on Feb 01, 2009
Samsung 40" LCD Right Half of Screen Distorted / Pixelated
I think you are screwed. When the price to repair exceeds 25% of the unit cost I get new up-graded items. New warranty for better items
May 09, 2013 | Samsung LN46A550 LCD TV
Samsung TV Screen faulty
t con board failed if its half and half. can also be a lose cable on the screen to the tcon board from the lcd screen side. Tcon is in the middle off the screen on the back.
Nov 18, 2012 | Samsung LE46M51B 46 in. LCD Television
Samsung LN-S4095D HDTV Screen Glitching
look to see if same issue with a DVD etc connected to a rear input.
Jun 07, 2012 | Samsung LN-S4095D 40 in. LCD HDTV
I have recently bought a Samsung SM2033HD TV and want to wall mount it. I can remove the base but how do I remove the collar that joins the base to the TV.
Your tv is not fully VESA compliant. You cannot remove the collar. There are mounts available that grip the screen instead of screwing into the back. This type will look better.
Jan 10, 2010 | Samsung LE40R74BDX 40 in. LCD Television
Samsung LNR408DX/XAA Won't power up. Sound works but as far as the screen, no input/source works. After it died I noticed that the screen was very hot especially the upper Left side. In the dark, the...
It sounds like this is a problem with the inverter boards on the LCD panel. Unfortunately the inverter boards are usually only available with the whole LCD panel and the only way to fix it is by replacing the whole LCD panel. This is the most expensive part of the TV (about $1000) and you will need to take the whole TV apart in order to replace the panel. A new TV of similar make and model will usually be about the same price as the repair.
Nov 09, 2009 | Samsung LN-R408D 40 in. LCD HDTV
42 inch samsung lcd tv darker on one side
Its one of two things, bad lamps in the panel or bad Tcon board
Dec 24, 2017 | Televison & Video
I dropped my Samsung LN-T4053H 40 in. LCD
yes. sorry to deliver bad news. cost to repair is 90% the cost of when you purchased. panel is around 400-500 plus your labor. samsung may have flat rate program but still is not very economical. sorry again.
Jun 04, 2009 | Samsung LN-T4053H 40 in. LCD Television
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Samsung LCD Question
The model is a LN-S4041D. A 40 inch LCD. I can send you a photo but I can't get the file size small enough to post
Feb 09, 2008 | Televison & Video
Image Retention
burn in is not supposed to occur on an lcd tv, however I have an lcd from Proview that leaves images on the polymer layer the white horizontal address bar is the most prominent. if I leave the monitor off for about 3 days the images disappear, this may or may not help you, if Samsung has created a ticket on this issue you may well receive a prepaid shipping label to return the tv for repair.
Jan 10, 2008 | Samsung LN-S4051D 40 in. LCD Television
Samsung LN-S4051D 40 in. LCD Television Logo
200 people viewed this question
Jerry Greenberg
Jerry Greenberg
