This section describes dialing and sending faxes directly using the Numeric buttons.
note:
A PBX (Private Branch Exchange) is an on-site
telephone switchboard. If your machine is connected through a PBX or
other telephone switching systems, you have to dial the outside line
access number first, and then the number of the party you are calling.
Sending a Fax with the Numeric Buttons .
Click here for other
useful sending methods.
1. Preparing for sending a fax.(1) Make sure that the power is turned on.
(2) Load a document on the Platen Glass or in the ADF.
important:
When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
(3) Press the FAX button.
The fax standby screen will appear.
(4) Adjust the density (scan contrast) or image quality (fax resolution) as necessary.
See "
Adjusting the Sending Quality"
2. Sending the fax.
- When the document was loaded on the Platen Glass:
(1) Use the Numeric buttons to dial the recipient's number.
(2) Press the Color button for color sending, or the Black button for black & white sending.
important:
Color sending requires that the recipient's fax machine supports color faxing.
(3) Press the OK button.
The machine starts sending the fax.
note:
When loading two or more documents
- Load the next page, and press the same button as
you pressed in (2) of step 2. Repeat the same procedure to scan all
pages of the document, and press the OK button.
- When you have sent the first page with the Black button, the following pages will be sent in black and white.
When the document was loaded in the ADF:
The machine scans the document automatically and starts sending the fax.
important:
note:
To cancel sending a fax, press the Stop button, and follow the instructions on the LCD.
If documents remain in the ADF after pressing
the Stop button during scanning, "Close the feeder cover [OK]Eject the
document" will appear on the LCD. Press the OK button so that the
remaining document is automatically fed out.
Automatic redialing
- When sending a fax and the recipient's line is busy,
the machine will redial the number after a specified interval. Auto
redial is enabled by default. Auto redial can be enabled or disabled by
selecting ON or OFF. Select ON to specify the number of redialing in
Redial times and redialing interval in Redial interval.
Redialing the Number Dialed with the Numeric Buttons
1.Prepare for sending a fax.
(4) Adjust the image density (scan contrast) or quality (fax resolution) as necessary.
See "
2. Select the telephone number recently dialed.
(1) Press the Redial/Pause button.
Most recently dialed fax number using the Numeric buttons will appear.
(2) Use the
(-) or
(+) button to select the number to redial.
The selected number will appear in the fax standby screen.
3. Send the fax.
important:
