Set turns on and then goes off sometimes it will go back on sometimes, sometimes not. Makes a clicking sound when it happens. Happens whether the set has been on a while or not. model is vs-60801 made in 3/98. Mitsubishi brand
    Problem Solver:
  • 5 Answers
That is an old sob but if it is projection then check the power butten on the tv might be stuck in or the remote might be sticking or check the battery that is suposed to save the memery in the tv
Posted on Jul 13, 2009
Flashing ch on greenstar 42cdi boiler
ch calling for heat check ignitor or heating element
Oct 18, 2017 | Water Heaters
My amana range oven works intermittently. When you turn on the dial to a setting it sometimes makes a buzzing noise and the oven indicator light goes off. If you push on the knob it sometimes will go back...
If this is a gas oven you probably need a new Igniter (Ignition Switch). If it is an electric oven, one or more of the Electric Filaments might be fried or about to fry. Good luck.
Dec 16, 2017 | Kitchen Ranges
Crackling from set volume button makes no
Sounds like a loose connection with one of the audio/video cables inside the TV or a short. Contact a qualified service technician to do the fix.
Jan 25, 2010 | LG 32LX1D 32 in. LCD Television
I have a WS-55313. The screen will go totally blue and a message appears that says- tv will shut off in 2 minutes unless any button is pushed. Pushing any button just makes the message go away. Turning the...
Well not sure what is causing the problem but i think the simple solution is to change your power management settings. I set mine to shut off as well if there is no input signal but the only way it goes to the 2 min. warning is if the cable box is off or its not getting any signal.
Dec 01, 2009 | Mitsubishi WS-55313 55" Rear Projection...
My tv turns off by itself and makes a clicking noise
Most likely it has some bad capacitors in the power supply. Flat--panel sets are VERY hard on capacitors, due to the fact that the "rising heat' from the set "cooks" the caps and they fail VERY early.
Oct 12, 2009 | Samsung HP-T4234 TV
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Set turns off randomly
there is a capacitor right behind hori output transistor it most of the time goes bad 1200pf 2k volts,yours could be on its way out,when it does set will not come back on.
Jan 09, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Color Turns Green
HI PLEASE ADJUST THE SCREEN CONTROL OF UR TELEVESION SET IT IS INSIDE THE TV..IF U KNOW THE SCREEN CONTROL IN THE SET THAN MAKE IT LITTLE ANTICLOCKWISE.AND THE SET WILL BE OK..
May 13, 2007 | Sharp 27H-S60 TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
