Question about Yahoo Messenger
When i try to install yahoo massenger iys give firewall error in vista
Try messing around with your Firewall's settings. You can access these options by going to Start Menu>Control Panel and click Allow A Program Through Windows Firewall.
Posted on Jul 13, 2009
T want download yahoo massenger
Sometimes proxy setting or a firewall or even the antivirus can stop Yahoo Messenger from downloading. If you have turned off the firewall, you may want to have a look into your proxy settings or antivirus.
Alternatively, you can download the application from a different website like Softpedia. Yahoo will only give you an installer which will download the application and cause one of the above problems. Here is the link to download Yahoo Messenger 10.
Feb 15, 2011 | Yahoo Messenger
I cant download a yahoo massenger
Sometimes proxy setting or a firewall or even the anti-virus on your computer can stop Yahoo Messenger from downloading. If you've turned off the firewall, you may want to have a look into your proxy settings or antivirus.
Alternatively, you can download Yahoo Messenger from a different website like Softpedia. Yahoo will only give you an installer which will download the application and cause one of the above problems. Here's a link to Yahoo Messenger 10.
Jan 23, 2011 | Yahoo Messenger
I can not install yahoo massenger because they are saying see your firewell settings
Hi!
Did you actually check your firewall settings.
Disable first the Firewall Setting to be able to completely download the software and install to your computer. Firewall setings can be disable on Control Panel.
Dec 26, 2010 | Yahoo Messenger
Application error occuring to install or remove yahoo massenger?
You need the following OS to support Messenger
Windows 2000 / XP / 2003 / Vista / XP64 / Vista64 / Windows7
If that is not an issue read on.
The problem is probably due to a mal-function of the uninstall software.The Yahoo Messenger uninstall software is notorious for leaving files and fragments behind creating conflicts with the incoming software
Close all programs when uninstalling / downloading and uploading.
If you tried to uninstall the old Yahoo Messenger program from the Control Panel and failed to back it up with a visit to the 'C' drive, you may have old software conflicting with the incoming software trying to share the same folder.
If you have Vista the whole Messenger folder should have been removed during the uninstall.
Check
Start > Computer >> Local drive (C) >> Program Files >> Yahoo >> Messenger. - The Messenger folder should have been deleted and not seen. If the Messenger folder is still visible - delete it.
If you have a pre-Vista OS, the Messenger folder remains, and inside, only one sub-folder should be seen. This is the 'Profile' folder and contains all the message history. All other software should have been deleted.
Manually delete any other folders and files before moving on
Download 'ccleaner' and run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.
http://www.filehippo.com/download_ccleaner/
Re-start your computer and download Yahoo Messenger from here.
http://www.filehippo.com/download_yahoo_messenger/
Failure to initialize error message persisting? try this download site
http://download.yimg.com/ycs/msg/dl/msgr10/us/ymsgr1000_525_us.exe
Jan 09, 2010 | Yahoo Messenger
M having windows vista yahoo messenger 8.1 is not intalling
Right Click in Yahoo Messenger ,exe And go to Trobulshuting Complier
Plz Install
Enjoy........
Aug 17, 2009 | Microsoft Windows Vista Home Premium...
I cant open my yahoo massenger its wright to me there was abroblem sighning into yahoo massenger please try again later
Have you tried re-typing your e-mail?
If so, then try rebooting the program. If it doesn't work then your firewall might be preventing it from connecting to Yahoo!
Check your firewall for what sites are deemed "safe"
Jul 05, 2009 | Yahoo Messenger
Unable to install yahoo msn
Check your internet connection, may be your connection encountered problems...always download from your trustful sources website. i think better you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you download yahoo messenger,check it out, may be it blocked your yahoo messenger set up from downloading it.
Try these! Good Luck!!
May 31, 2009 | Yahoo Messenger
I cant install yahoo messenger in my connection settings
You can try to diable your VirusScan and Firewall and then try to install Yahoo Massenger...
If you dont know how to disable them.... reply with your VirusScan name.
Apr 28, 2009 | Yahoo Messenger
Installing yahoo messenger
Is the download complete? If it is complete, you can try installing the application again. If it doesn't, try to identify if you have any programs in your PC that is blocking the installation of any application. These are anti-spyware applications or personal firewalls.
Or simply try downloading the YM again and re-install..
Oct 23, 2008 | Yahoo Messenger
Yahoo messenger
pls give me the easiest way i can fix this, thank u
Oct 12, 2008 | Yahoo Messenger
Yahoo Messenger Logo
56 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
