Question about Sony Playstation 3 (PS3) Console
I was playing call of duty my ps3 turned off after that if i turn it on it freezes up and turns off. i tried reseting it through the beep double beep menu but it wont stay on long enough to finish, wtf
    Problem Solver:
  • 5 Answers
MABYE ITS OVER HEATED
Posted on Jul 13, 2009
  • 4 Answers
Through a connection in the internet
( or faulty parts whatever sony wants to tell you) playing that game ruined your Ps3 sometimes it can even be a game that you have been playing for months weeks even and something will just set it off your best bet is to find a repairman or to send it to sony and PRAY you still have a warranty (this happened to me only but 2 days ago)
Since i brought my ps3 on ebay when ever i play it it freezes after 20 - 30 mins, after it freezes if i reset it it will turn on slowly and then wont show the game up and if it does show the game it will...
Hi, you may have a problem with the lead give it a good wiggle all the way from the ps to the telly if that dont work try and borrow a friends lead to rule out the lead being the problem, if it still dont work then try the following to reset the console.
This is how to fix it:
1)turn your ps3 -off- by the switch at the back
2)turn it back -on- again by the switch at the back only
(there should be a red light now)
3)now -hold- your thumb on the power button located on the front for a few seconds until the ps3 turns itsself on and off.
(during this process there will be about three beeps spaced apart,and after that the light will return to red)
4)finally hold your thumb on the front power button again and you will hear two beeps then a double beep.
-IMPORTANT-
After you hear the double beep take your thumb off the button before it shuts itself down again.
5)once you have done that you should see the picture.
if after doing the above it still dont work then this would indicate it has over heated so try the following.
1 switch the ps3 off and leave it off for at least an hour
2 remove all leads from ps3 and tv
3 make sure the ps3 is not being used on carpet or on top of dvd player or sky box as this will cause it to over heat very quick
4 make sure all the air vents are clean and have no dust vac them out if needed.
5 make sure the ps3 has got good air flow around it and not stuck inside a shelf thats blocked off at the back as this to will cause it to over heat.
6 now plug it back in and give it a try.
if it still dont work then this would indicate the gpu chip has over heated and has probably fried.
if you have any warranty left on it take it back as this fault is covered by warranty.
i fix these for about 25 pound plus parts so you need to shop around and see if you can get it repaired, their is no guarantee the repair will work as their is always the chance that it has over heated that much that it has cracked the solder joints that hold the chip onto the circuit board.
im in uk and we do offer a repair service so if your in the uk and would like it repaired you can give me a shout back or if you need further assistance just give me a shout back.
let me know how you get on ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 19, 2010 | Sony Playstation 3 (PS3) Console
I had my ps3 after a few months when it first came out but in the past year in a half it started to freeze up when i hit ps button, sign in to psn when in game (multiplayer), it will not play dvds, when i...
Dear, before you get in touch with Sony technical support you may want to try to use the PS3 recovery options. The PS3 stores a copy of firmware drivers on the hard-drive and will reload any corrupt files. To access the recovery menu, do this: Make sure the PS3 is turned off Press and hold the power button on the PS3 it will power on then power off. When it's off press and hold the power button again until you hear two consecutive beeps. When you hear the double beeps take your finger off the power button (if your system turns off before you get a double beep, just try again and hold the button, it should double beep the 2nd time you try) It will ask for the controller to be connected via the USB cable, Turn on the controller and you will have access to the menu. Be aware that you may lose all of your previously saved data (NOT trophies, they're stored online so don't worry).
Thank you for using Fixya and for rating my solution if you find it helpful. Peter_Rei
Aug 06, 2010 | Sony Playstation 3 (PS3) Console
My playstation won't play a game. Everything else works but it won't play a videogame. It freezes everytime u start it.
Dear, before you get in touch with Sony technical support you may want to try to use the PS3 recovery options. The PS3 stores a copy of firmware drivers on the hard-drive and will reload any corrupt files. To access the recovery menu, do this: Make sure the PS3 is turned off Press and hold the power button on the PS3 it will power on then power off. When it's off press and hold the power button again until you hear two beeps. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try) It will ask for the controller to be connected via the USB cable, Turn on the controller and you will have access to the menu. Be aware that you may lose all of your previously saved data (NOT trophies, they're stored online so don't worry).
Aug 05, 2010 | Sony Playstation 3 (PS3) Console
My playstation 3 wont read any discs, films, games, or music. The machine just stopped whilst playing a dvd and now refuses to work
Dear,
you may try to use the PS3 recovery options.
  1. Make sure the PS3 is turned off
  2. Press and hold the power button on the PS3 it will power on then power off.
  3. When it's off press and hold the power button again until you hear two consecutive beeps. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
  4. It will ask for the controller to be connected via the USB cable,
  5. Turn on the controller and you will have access to the menu.
Be aware that you may lose all your data previously saved. Good luck, Peter
Aug 02, 2010 | Sony Playstation 3 (PS3) Console
My kidere playing Call of Duty world at war and now My PS3 stopped working??
Hopefully this will help solve your problem:
1. Press and hold down the power button located at the front of the PS3 console, until you hear a first beep, then eventually a second – before the console shuts down, then let go of the button;
2. Now press and hold the button again until you hear a first beep, then a second beep then eventually a quick double-beep, then let go of the button;
3. The TV screen should now display a six option menu, where you can select what’s required, i.e. `Restart System`, `Restore System` etc. `Reset System` should only be used after other attempts with the other options, as your game saved data may be lost. If you play Modern Warfare 2 online, then this won’t be affected as your data is saved on the Sony Server.
4. During any of the above actions, your best having your handset controller connected to the PS3 via the USB cord, which includes pressing the `P` button when required (located between `Start` and `Select`).
These actions should help solve `freeze` problems and others such as update errors etc – which restrict you starting up or playing your console.
Don’t hesitate to contact Sony UK if required, who are very helpful. Their UK number is: 0844 7360595
Good Luck!
Jun 20, 2010 | Dmm Call of Duty: World at War
Problems with call of duty 4 and call of duty world at war
i guess it's a problem with your Hard Disk . please try the following :
  • re-updating your system by an USB device (download the update from sony ps3 website)
  • reinstalling all game data files
  • restoring your system (don't forget to backup all your important files such as game saves !!)
Jun 19, 2009 | Sony Playstation 3 (PS3) Console
My ps3 won't play ps3 games anymore. I was playing lego batman and then the game froze. so I turned off the ps3. I turned it on again and the game icon didn't show up anymore. I tried several games and...
I had the same issue. I had to send it to PSR Repairs to have it checked out. They ended up replacing the hard drive & the laser lens. According to them, both those components contributed to the freezing up & inability to turn back on. Before I sent it in, I was able to get it to turn back on by holding down both the power button & eject button simultainiously. Lie it beep once, then double beep... Once you hear the double beep, release both buttons. A menu will come up giving you 6 options. Try option 3 first! you wont lose any saved items with this option. If that doesn't work, you will need to use option 6. This will delete ALL of your saved items, but there's a chance that you may not have to have your console repaired. You can retrieve trophies, games & demos from the PlayStation Store. Good luck! If I can be of further help, comment me back under this heading!
May 12, 2009 | Sony Playstation 3 (PS3) Console
Starting up Problems
I found it 2 min. ago. Ok here: while your ps3 is on hold the power button on the ps3 for you will hear one beep, keep holding it then when you hear the second beep take your finger off. Your ps3 should turn off. Now push the power button while holding your finger on it again, you will hear two single beeps, then a double beep, let your finger ago and a screen should appear with six options. Chose something like reset(or restore) file data or something like that and click yes, this wont do anything to your game/music/movie/etc. files but now your ps3 shall work.
Feb 01, 2009 | Sony Playstation 3 (PS3) Console
PS3 will not eject the disc nor acknowledge the game being in the console
NEVER EVER TURN YOUR SYSTEM OF WHEN YOU ARE PLAYING ONLINE AND THE GAME FREEZES!!!...
Just try to wait for 30 - 50 sec.
If that does not work than EJECT THE DISC AND THAN TURN OF THE SYSTEM, It has nothing to do with your PS3, Check your connection status and reset all your internet settings BUT NOT THE SYSTEM ITSELF.
If this still doesnt work than there's something wrong with the disc.
Aug 23, 2008 | Sony Playstation 3 (PS3) Console
Ps3 wont come on!!
Hey, your screen settings may need to be reset. You can reset your playstation 3 screen settings by first turning of the playstation three, then turning it on by hitting the power button on the console and hold it for 5 seconds. You should hear it beep several times and then it should work.
Dec 25, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
73 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
