Question about HP Pavilion dv9730us Notebook
HP Pavilion DV9730us, turn on and lights come on and off at 2 sec rate. no post., hard drive flashes once when first turned on - then on more. can stop lights for blinking if i press windows button or ctrl-alt-del. then they just stay on. sometimes it will boot and freeze with ripped screen. suspect bad video section. ?
    President:
  • HP Master
  • 2,923 Answers
If you are hearing 2 long beeps or 1 long beep followed by 2 short beeps, the problem has to do with the video card.
But if you are hearing 3 short beeps, it could be the memory card (RAM).
If you suggest to contact the manufacturer for assistance.
Have a great day!
Posted on Aug 17, 2009
  • 3,230 Answers
First of all i suggest you to repair your Operating system because i don't think so that it's a hardware fault.
and yes You are right it seems that there must be some file getting corrupted like video driver file.. so try installing it again...
Good Luck!!
thanks
Posted on Jul 12, 2009
"HP Pavilion m7580" is not
To verify whether it's a no POST issue, press NUM LOCK or CAPS LOCK key and check whether the CAPS LOCK or NUM LOCK lights are lit or changes when you press on it. If it doesn't then it's a No POST problem.
However, if the computer screen shows the HP logo or a display then it's POSTING and is experiencing a No BOOT issue.
If the NUM LOCK or CAPS LOCK responds when you press it but there is no display, check the connection between the monitor and the CHASSIS or CPU.
If you have verified that it's a No POST issue because CAPS lock is not responding, you need to open up the chassis to do a troubleshooting procedure. Be sure to unplug the chassis to all the connections especially the power cord. Drain the power by pressing and holding the power button from 8-10 seconds.
Here are the things that you need to do after you open up the chassis.
1. Reset the Memory sticks. Connect the CHassis to the power and monitor. If no go, try turning on the computer without the memory sticks. The aim of this troubleshooting is to see a display on the screen. Any display would be a good sign. If no go. Put the memory stick back in.
2. Remove the CD drive. Turn on the computer, check for development. If no go, proceed to step 3. Just leave the cd drive removed
3. Do the same thing with the other devices like the hard drive and other devices inside. Your aim is to see a display.
Let me know if what happens and I'll get back to you.
Once you see a display. Let me know by replying to this thread.
Apr 07, 2011 | HP Pavilion m7580n PC Desktop
I have an HP Pavillion dv9000 the blue lights come on for just a sec and then nothing. It will turn on periodically and works great when it on. But that is the problem it hardly ever does. Just the blue...
This could be lots of things. so lets try the easiest.
Blow out the dust in and around the fan(s)
replace the AC power cord and/or battery.
replace hard drive
and the big one replace Motherboard (which i done once in my lifetime)*
* = most likely not it.
Nov 02, 2010 | HP Pavilion dv9000z Notebook
I have a hp pavilion dv9730us.cd/dvd drive is missing in windows 7 device manager,and is not recognized in bios(cannot boot).i removed the optical drive,and tested on another laptop.is working.i put back...
Up date the bios and than reinstall the chipset, also check in device manager for the make and model of the optical drive and update firmware before that run this link from MICROSOFT
Dont forget to say Thanks!
Aug 11, 2010 | HP Pavilion dv9730us Notebook
Hp dv3 boot: no bios, blinking screen
You re having the problem with your hard drive because constantly putting Off your system without following the Shutdown Process will corupt your hard disk and probably crash out so you will have to reload the system by reformating the hard disk or probably change the hard disk and reload it all will be fine ok anything else post back CHEERS
Mar 01, 2010 | HP Pavilion dv3z Entertainment Notebook
How can I turn of the HP blue Invent window? My comuter is HP Pavilion 735N
if window Xp installed on ,just press the window button on the keyboard,once wait for feww sec,press letter U,wait for few sec,then press letter U again.
Feb 09, 2010 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
Hp dv1000 doesnt boot
Sounds like the battery is not being charged properly. With a voltmeter, check for voltage at the output of the charger that plugs into the computer. It should read several volts higher than the battery voltage rating. It is common for one of the wires to break just inside the plug. Radio Shack stores have a plug and cord that fits the computer, but the new wiring must be spliced into the original cord (with the correct polarity). Replacement cost for a new charger is quite high! Good luck!
Jan 31, 2010 | HP Pavilion dv1000 Notebook
Testing motherboard
the motherboard can not be tested but, usually what makes the motherboard fail is the little tape between the power switch board and the motherboard
the answer to hdmi and, blueray is: yes and, yes you can interchange them then go to hp.com to get the software and, drivers
Apr 24, 2009 | HP Pavilion dv9730us Notebook
Power Issue turn on and is turns off after 2 sec
Could be a glitched battery. Turn it on without battery installed. Also, to eleviate the memory - take it out. The unit will still turn on. I have to go along with HP support, that's it's probably the mother board. Now all is not gloomy. Hp has extended their warranty on many models, Dv2000-Dv6000 to name a few. Ask for a supervisor.
Mar 21, 2009 | HP Pavilion dv1000 Notebook
HP Pavilion dv9730us Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
