Question about Garmin nuvi 750 GPS Receiver
My garmin 760 screen reads "press dot".
My Gamin was in the glove box of my car for about four hours and when I plugged it in to use it the screen read press dot and when you do the dot moves around. Nothing else works. If anyone can help, it would be awesome.
  • 4 Answers
Hiya!
All you need to do is use a ds pen (or something that is plastic and will fit within the black dot) - our fingers are to big for the calibration. Ive just fixed mine. It should correct its self within 10 dots and away you go again :)
Posted on Nov 06, 2011
  • 23 Answers
I would do a complete reset. Turn on your Garmin at the same time press the bottom right hand corner of the screen this will completely reset the Garmin back to factory standard. Hope this helps
Posted on Aug 05, 2009
Not at all. I already restart it many times. still the same, after calibrated, I turn it off and on again, the dot come out again.
Posted on Feb 25, 2014
Garmin 1100lm locked in press dot game?
Your unit is in calibration mode. There should be a black dot to press on the calibration screen. Keep pressing the dot as it moves around the screen, you may need to press very firmly and use a stylus until it says calibration complete.
This usually occurs when a unit is dropped or left in extreme temperatures or jammed it a glove box or console with things jammed against the screen. It could also occur if you are touching the screen as you start.
Thanks for using FixYa
Aug 03, 2011 | Garmin nuvi 1300 Car GPS Receiver
My garmin nuvi 1350 LMT turns on to a calibration screen. it will not go to the maps home screen. how can i fix this
Jul 27, 2011 | Garmin GPS
White "press dot" screen
The actual answer is to press the dots, but use a dull plastic tool that fits "within" the dot. Otherwise the width of your finger is too imprecise to calibrate the dots and screen.
Hope you, and others, get this and try it. It works. I just discovered it and did it, successfully after only about 10 presses.
Jul 21, 2010 | Garmin Nuvi 660 GPS Receiver
Nuvi 760 will not take charge
I don't know which of the three ways you're trying to charge - car cradle, via USB cable to a computer or via accessory AC adapter. An 18 month old 760 should still have a good battery.
If you are using your car cradle to charge consistently, use one of the other methods and allow the 760 to charge for 8 hours. Use of the car cradle can cause the 760 to stop taking a charge after a while, and switching to one of the other methods should "refresh" the internal battery. Since the AC adapter wasn't included in the box, the USB cable method is likely your only other choice. While connected to your computer, you should download & update the 760's firmware. It's fast and free - and could solve other potential issues. Get the WebUpdater software direct from Garmin.
It is also possible that the fuse in the cigar lighter plug has opened. Disassemble the the plug to check for and replace a blown fuse.
If unable to get the 760 to accept a charge, you might need to replace the battery. There are several sources for batteries - but a free call to Garmin Support should be your first move.
Please rate this reply and good luck!
Jun 10, 2010 | Garmin Nuvi 760 Car GPS Receiver
Garmin 205w got soaked touch screan not working what can i do
If you unit has dried itself out, but does not boot up properly, I recommend performing a hard reset of your Gamin Nuvi 205. Also, use Garmin's WebUpdater service to make sure you have the latest software on your device.
I hope that helps.
Jan 31, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
My Garmin Nuvi 205 just has a blank white screen. I just took it out of the box and read the directions and plugged it in for the first time. I've hit the reset button.
Whenever these devices start acting up, I recommend performing a hard reset of your Gamin Nuvi 205. Also, use Garmin's WebUpdater service to make sure you have the latest software on your device.
I hope that helps.
Dec 27, 2009 | Garmin nuvi 250W GPS Receiver
My Garmin Nuvi 760, after the Garmin bootup screen, goes to a press dot screen and then freezes. I have tried setting back to factory setting but that did not work. Any Suggestions?
try a master reset:
How to do a master reset:
1. Turn on the unit
2. While it's booting up keep pressing the bottom right corner of the screen.
3. A message will appear asking if you want to clear user data. Answer yes.
4. Bootup will continue. It's after this that you have to re-enter or confirm your country and time zone.
I hope this helps
Oct 29, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Not turning on
My unit was totally dead. I just kept it plugged into my computer for about 12 hours. I downloaded the newest software from Garmin. When I unplugged it from my computer, the battery seemed to drain quick, but once I plugged it into the card adapter in the car... everything seems to be running great now.
Oct 09, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin won't come on
plug it in to the wall charger or car charger for about 4 hours, then slide and hold power button for up to 15 seconds till it starts.
if that fails, unplug the nuvi then press and hold the lower right hand corner of the screen until you see the message " Do you really want to erase all user data?" remove your finger from the screen and select YES. (this will erase all your saved data) this should reset your nuvi to the factory settings.
use the web updater to update your nuvi once you get it started again.
you can get it HERE
let me know if you need further help.
bill
Sep 05, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin 760 phone feature
Did you check the settings for the sound output? If it is set to FM-receiver, you have to tune your radio to the same frequency as the 760 transmitting frequency. To get sound from 760-device, you must deselect the FM-transmitting feature.
(I don´t think this solves your problem. Too obvious.)
Jun 26, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin nuvi 750 GPS Receiver Logo
2,217 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
