Question about Goodman CLQ36AR49 Air Conditioner
Inside the air is blowing, but the outside unit fan isn't moving at all. HOUSE IT HOT!!!
  • panilling9
    panilling9 May 11, 2010
    CHECK THE OBVIOUS--------circuit breakers tripped or off labeled a/c or outside unit in your house electric panel you have a box outside near the outside unit that may contain fuses or a circuit breaker check this or have a electric tester or ohm meter handy. safety first if you are not comfortable with electric find someone who is
    Scholar:
  • 91 Answers
Two things; outside does the compressor try to come on? If not you may have a switch\Thermotat problem. Also make sure the breaker to the outside unit hasn't tripped. If it has tripped there may still be a problem after you turn the breaker back on. If it's only the fan that's not coming on outside you will need a new capacitor or fan motor and compressor(if the fan motor is replaced you should have a new capacitor also. If it has been intensely hot your unit might have just gotten overworked. Then resetting the breaker is all that is needed. If you have continuos resettings you MUST call a qualified HVAC Tech.
Posted on Jul 12, 2009
    Champion:
  • 233 Answers
If the compressor is on and the fan is not, check the wires to insure that the fan has power, take an amp draw on the fan leads. no fan amp draw with power = replace fan motor and capacitor
My air conditioner is not blowing cold air in the house
because the fan inside the house is working doesn't mean that the compressor outside is working
It may be a faulty start /run capacitor for the outside unit ,out of gas or failed power board
I suggest that you get an accredited technician to come and give you a proper diagnosis of the fault.
Jul 17, 2015 | Heating & Cooling
Unit not cooling inside below 72 degrees lines sweating
how hot is it outside??? 20 degree split is usually the norm ,,,,,outside 95 then inside will be 75,,,,,where is the line sweating ,,, it should sweat near outdoor unit
Jun 02, 2014 | Ruud Central System Air Conditioner
Ac unit isn't blowing
It sounds like your freezing up at the coil, which in turn, blocks airflow across coil and only a small amount of air comes out of the vents. This also explains the cold air coming from fan on the outside unit, since the system cannot absorb the heat from the inside of the house through the coil. Your air outside is usually blowing out warm to hot air because thats the heat it rejects out of your system. I would turn the thermostat to "OFF" and turn just the fan setting to "ON" instead of Auto, this thaws the system out faster. Give it time to fully thaw, make sure filters are clean, and check airflow. If airflow is back to normal, your problem is more than likely the charge of refrigerant. If you have to call a technician out, make sure the unit is not frozen at all before they get there, they would not be able to do anything with the system froze. Hope this helps and good luck!
Jun 18, 2012 | Heating & Cooling
Our AC unit is on inside the house but blowing hot air. Outside unit is not on. My husband tried to turn the fan blades on the OS unit and it won't turn. Is the fan motor gone?
It is a strong possibility. Use some oil on the motor.34a4ac9.jpgIt might be the contactorace24b7.jpg
Before he goes messing with anything inside the unit he needs to kill the power. It may be the capacitor, look for a swollen cap45d0615.jpg06e208f.jpg
Aug 22, 2010 | Intertherm Heating & Cooling
Carrier 38tkb not working, but furnace is blowing
It is probably a capacitor problem. Check inside the outside unit. you will see a round cylinder with three groups of terminals on top. If the top of it is dome shaped it probably needs to be replaced. You can check it if you have a microfared tester. However if it is poofed out it probably is bad. If this is not the problem you will probably have to replace the fan motor.
Jul 07, 2010 | Carrier 38CKC036 Air Conditioner
House HVAC Not Blowing
If the outside unit is running and the inside unit is not, probably a problem with the fan motor itself or its capacitor. If you have to have someone repair or replace the fan $200-$250 with parts, a capacitor for a service call and part $100 or so. Check it yourself first to see if there is anything obvious broken wire, hot connection, etc if you feel safe doing that. Turn the power off first. There is also a chance the thermostat could be the problem. Have you tried running the fan on the thermostat "fan on" setting?
Jul 01, 2009 | Goodman Heating & Cooling
When my unit is on the outside is not working the inside is blowing little hot air. What do I need to check? Its a Ruud Achievers Series
Set the thermostat four degrees lower then house temperature and fan to on. Go outside and see if fan is running. If not check circuit breaker.
Apr 26, 2009 | Ruud UBHC Air Conditioner
Central ac blowing hot air outside fan not moving but making a noise
This is nothing but an either or -or ! First, make the thermostat calls for cool, there are suppose to be 2- noise outside, the fan motor and the compressor (and if a old system,a humming noise which is the contactor coil which picks up the main 240-volts).. hurry up and take a stick or something and turn the fan blades, if it picks up speed and run, then its the capicator. If not then the fan motor is bad.! (BOTTOM LINE)!
Jun 09, 2008 | Heating & Cooling
Goodman CLQ36AR49 Air Conditioner Logo
356 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
