Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Can i take apart the door shelves of my subzero for cleaning
  • 28 Answers
No you should not take apart the shelves. They lift and pull out so you may clean in the sink.
Posted on Sep 27, 2009
  • qaz Jan 15, 2015
    WRONG, they do come apart, see my answer below
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 102 Answers
You can take them off the door by lifting up and out at an angle but do not try to disassemble them. You can soak them in hot water to try and get rid of spills in the seams.
Posted on Aug 05, 2009
  • qaz Jan 15, 2015
    WRONG, see my answer below
  • halftank123 Jan 17, 2015
    Question is asking about door shelves.
    Novelist:
    Scholar:
  • 165 Answers
YES YOU CAN!!! Okay take the shelf out and turn it over. You will see two notches under the front side and by gently working the rubber out you will find the rubber is like a wedge running the length of the shelf holding the rest in place. Once that is out the glass can move some. Move "up and down" but not forward/backward. This allows you to remove the rubber strip in the back. And then the entire glass shelf will come out easily. The rubber strips are simply long molded pieces. Taking the front one out allows you to take out the back one and then the glass is freed from the metal frame. I just did it with mine.
can i take apart the door shelves of my subzero - 84ea4625-95ad-42f9-b21d-28418acb66aa.jpg
Posted on Jan 15, 2015
I need subzero 632 shelving?
I need a serial number and which shelf do you want to replace so I can check to see who has it and where. The serial number is important and all subzero unit and design changes only accrued in some parts. Get back to me and I can search this for you and you can call Subzero direct to get the same information I could. Either way, I am willing to assist you if you want. Thanks..
Aug 25, 2014 | Refrigerators
Frost forming on top/front panel in freezer side subzero 632
In your freezer section there are 2 door switches -- press each one. One turns off the light. The other turns ON the freezer evaporator fan. If the freezer compressor is running the evap fan should RUN when the switch is depressed. If not, the fan motor is defective OR the switch is defective. Easy to troubleshoot the switch - just pry it out with a screwdriver, short the terminals with a piece of insulated wire. If the fan runs, it's OK and the problem is the switch.
If it's the fan, it's not hard to replace. Get replacement motor, turn freezer control to off, remove food and shelves, then the back sheet metal panel. Fan is right behind the panel.
Aug 02, 2017 | Sub-Zero Overlay Design 632/O Side-By-Side...
Fresh food door will not close/seal
Check to see if one of your door shelves is bigger (sticks out more into the fridge) than the other ones. If it is, theses shelves can cause door closing problems. Try removing the shelf from the door and closing it again. If this shelf is the problem, call subzero at 1800 222 7820 and give them your model and serial number, and they will send you a new standard depth shelf to replace the deeper shelf at no charge, these shelves caused a lot of door closing problems when they came out. Hope this helps!
Sep 07, 2013 | Sub-Zero 690 Side by Side Refrigerator
My subzero 561 keeps freezing the food that is in the refrigerator. What can i check to try and correct his myself?
Tempe setting must be between 38*F and 46*F in fridge. Turn thermostat anti clockwise to check the thermostat function. If unit shuts off, good.If not, replace thermostat. Thanks.
Feb 16, 2011 | Sub-Zero 561 / F
Side by side refrigerator- water dispenser clogged and now leakin
i'd shut off the water take apart and clean change water filter.
Jun 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Sub zero bottom freezer access
that unit must be 20 plus years old. There wouldn't be any diferent shelves available for it.
Jan 31, 2009 | Sub-Zero 650 / O Bottom Freezer...
Subzero 561 Fridge side works, Freezer side working fine
Sounds like a cold control. It is located behind the panel and can be ohmed out to check for proper operation. You need to remove the light shield then after the shelves have been taken out remove the two screws that hold the fan shroud in place. This will allow back panel to come for so you can check the cold control. It should read as a short in all positions except off when the cap tubes have come to ambient temp. If you get the back off and see ice on only a small portion of the evaporator you have a sealed system problem and need a qualified technician.
Nov 24, 2008 | Sub-Zero 685/S Stainless Steel Side by...
Cleaning Glass shelves mold.
the shelves can be removed not taken apart. sorry they're glued together, just use a bristle brush and some bleach. no problem.
Mar 30, 2008 | Refrigerators
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
1,441 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
