Question about Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum
Beater brushes don't work, what to do? They only work when the canister is in about an 85 degree up position.
  • 40 Answers
This appears to be a loose connection. The below post was answered by highntools a while ago. It probably is related to you problem.
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
There have been several people who reported loose or burnt wires to be the culprit for the brush bar not working. The DC15 does not use a belt, but a motor that is control by the circuit board. And I really believe that in your instance, the problem is a loose wire between the circuit board and the brush motor.
Posted on Sep 28, 2010
Brush won't spin on my shark navigator.
Maybe not the same issue, but my roller brush would only work intermittently. I had to take apart the main housing and clean the two contacts (female side) that connect to the lower brush assembly. Now it works like new.
Oct 30, 2011 | Shark Navigator Bagless Upright Vacuum
The suction is quite poor, also definite burning smell after normal use. we only have about 3 years would it be the engine
I would check the drive belts for the beater brush and make sure the beater brush itself is free to move in the holders. Clean the beater brush of all debris and add a bit of WD40 on the two ends between the brush and the holders.
I do not charge for my advice. : )
Paul
Sep 18, 2010 | Hoover S3755 WindTunnel Bagless Canister...
The belt keeps breaking. Like it's burning through.
Sounds like the beater brush the belt is supposed to turn has frozen up due to debris. Remove the brush and clean all debris. At the ends of the brush will be two fasteners that hold the brush in place, be sure all debris is cleaned from these and add a small amount of WD40 where the beater brush fits into these two small holders. Turn the beater brush around these holders by hand to be sure it moves freely. Reassemble with new belt.
Sep 17, 2010 | Dirt Devil Breeze Canister M082550 Bagless...
Dyson ball not picking up properly and very noisy
Is the beater brush spinning? Is the sole plate that is removable and covers the bottom side of the beater brush housing installed properly such that there are no gaps between it and the housing? Is the hose that connects the beater brush housing to the canister connected or have any holes in it?
May 26, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Bare floor selection still rotates brushes
Your switch should have 2 different on positions. One for simple suction and one to engage the beater. The setting without the beater being engaged should be first position from off and the beater would be second position
Jan 20, 2010 | Eureka 5849A Boss Bagless Upright Cyclonic...
Beater bar has stopped turning
All beater and rotating brush bars are fairly easy to get to with a couple of screw on the bottom of your wan. They are driven by a belt and these belts come off, break, or the bar itself is stuck with rug material. Unplug your vacumn and get our screwdriver. It;s easy to figure out once inside the wan.
Mar 02, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Power brush not working well
You probably have a worn belt that drives the beater bar... 2 year old belts with reasonable use are more than likely due for a replacement. You should be able to get a replacement drive belt from Sears and change it yourself.. The baseplate of your power brush seperates and should provide access to the beater brush and drive pulley system.. Hope that helps..
Aug 25, 2008 | Kenmore 22812 Bagged Canister Vacuum
Beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Jan 12, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Beater bar
on the bottom take out 2 screws they are closer to the back wheels pull off cover there is a plastic cover over the beater bar take off there is a belt if it broke or wore out change the belt that should fix your problem
Jan 07, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum Logo
382 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
