Question about Cell Phones
Everything works except for the telephone doesn't ring with incoming calls.
  • 3,230 Answers
First of all i like to know which phone do you have?
anyway - i think you do some wrong sound setting to your phone, so check that first.
there are two ways to solve this problem -
1. go into sound settings and set sound to ring.
2. restore your phone as factory default setting.
Good Luck!!
Thanks
Posted on Jul 12, 2009
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
Before I moved, my Lexmark all-in-one printer worked perfectly, but after I moved, everything worked EXCEPT printing of an incoming fax. Everything sounds the same through the sounds the telephone makes as...
Please go through the following checklist:
  • Make sure to plug the telephone fax line from the phone jack in the wall to the Line port on the back of your printer. For more info, please refer to the Lexmark X125 User's Guide.
  • If you have an answering machine connected to the same fax line, be sure to configure it so that it answers first before the fax machine (e.g. if your answering machine picks up on the 3rd ring, set your fax to pick up on the 6th ring or more)
  • If the line has a voicemail feature, disable it or request for a distinctive ring from your phone company.
Sep 14, 2011 | Lexmark X125 All-In-One InkJet Printer
Ring tone
In most cases the ringer has been inadvertently turned off or too low. You can turn it back on from the system menu and can also try by increasing the volume control while the phone is idle.
May 01, 2010 | Uniden DECT 6.0 Cordless Telephone...
Vintage mickey mouse telephone works perfectly EXCEPT it does not ring to alert incoming calls? help..help..
Did it start with a modular plug and base cord, or the old style?
One of my 3 is an ATC made about 1982. You may be able to put the green and yellow wires together and the ringer will work. If not, post back and we'll have to open 'er up :-)
Carl
Apr 09, 2009 | Disney 's Mickey Mouse Desk Phone
I can't get incomming calls
When I press talk to make a call, it just beeps and turns off, there is no ring tone? There is a new battery and the charge light is lit when the phone is on the base. Please advise.
Dec 05, 2008 | GE Telephone pr521w
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Wont accept incoming calls
this happened to mine , I never had aproblem before than one day ??? didnt work . I changed phone jacks ?? dont know why ??
1. Try disconnecting all phones in the household except the phone being affected.
2. Do a test call to see if the unit rings.
3. If the phone rings at this time, begin reconnecting all the other units one at a time. If the affected phone does not ring again, this is an indication that there are too many phones in the loop.
4. If possible try testing the phone on a totally different phone jack (friends or neighbors) to check if the same thing happens.
Also make sure the phone is not connected through an external answering machine, caller ID box, fax machine, computer, splitter, or defective DSL filter. If so then connect the telephone cord directly to the telephone jack and make a test call.
Jun 30, 2008 | Uniden Cordless Phone
System is 5 years old. It's a fax, answer phone & cordless telephone.
my dear
the microphone of your handset is not working
Everything elseis fine
if problem exist email on harjinderbawa2000@yahoo.co.in
Feb 06, 2008 | Panasonic KX-FPG175 Plain Paper Thermal...
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
