Question about Honeywell Heat/Cool Thermostat
I am trying to install a Honeywell programmable thermostat and am having trouble with the instructions. The old thermostat connections are identified by wire color, six of them, W, O, G, R, C, Y, but the connections to the new thermostat are five in number and identified as Rh, Rc, W, Y, and G. I cannot find any cross reference to tell me what to hook to what. Somehow O, R, and C have to go to Rh and Rc. Thanks
  • 308 Answers
It sounds like you have a heat pump, o (orange) is usually used to power a reversing valve in your outdoor unit for cooling. But just in case you don't here is a little info Rh-power for the heating circuit, W- completes heating circuit, Y to your outdoor unit for cooling, Rc- power for the cooling circuit, and G power to your high speed fan.
O for your heatpump
C is 24v common for cooling circuit
If you do have a heat pump, you will have to get a thermostat that is compatable with heat pumps. Hope this helps
Posted on Jul 13, 2009
How can I connect to replace an old Electromode thermostat that has 2 black and 2 white wires?
The packaging for the most recent Honeywell thermostat I installed has a "Consumer Helpline" telephone number of 1-800-468-1502. You also might try a Google search using the model number.
Mar 14, 2016 | Honeywell Programmable Thermostat Heater
Honeywell programmable thermostat - was installed per instructions in manual and now the furnace runs non-stop unless I move switch to "off." The old (round mercury switch) thermostat was wired red t
If you are unsure about which wire goes where, that may be the source of your problem. The color coding can be confusing when changing from old to new. I pulled the instructions for my Honeywell CT3400A thermostat and found you can call Honeywell Consumer Services at 1-800-468-1502 M-F 7:30 am to 5 pm CT
Mar 11, 2013 | Heating & Cooling
Trying to install the RTH 23301 thermostat and the old thermostat did not have markings. we connect the wires by color and only get the frunace to come on.
i would open the furnace and find where the wires are connected inside the panel and you should be able to identify which color wire is hooked up to each terminal.
Aug 06, 2011 | Honeywell Focus 6300B 5-2 Days...
I am trying to replace my honeywell T834C2499 with a programmable RTH221. I have hooked the wires as follows: G to G, W to W, Y to Y and R to Rh - leaving the jumper between Rh & rc. My problem is that...
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
May 31, 2010 | Honeywell Programmable Thermostat Heater
I've just moved into an oldish house and there is a honeywell heating/water controller installed. its quite old and i cannot find any identifying marks on it. It looks like a st699, 2 on/off per day. I...
If you go to your local home depot, and get a new thermostat, it will come with different diagrams for wiring in the instructions that are pretty easy to understand. I hope this helps.
Nov 04, 2009 | Honeywell Electronic Programmable...
Changing out old thermostat
your old thermostat is a milivolt and the wire runs from the heater to the thermostat. You have to open the back of the new one and connect the wire as per the instructions on the wireing diagram that came with the new one. I just installed a similar one myself, you will be very happy with it.
Jan 24, 2009 | Honeywell Electronic Programmable...
Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Oct 23, 2008 | Honeywell Electronic Programmable...
Installing a honeywell CM900 wireless programmable thermostat
the analog unit uses just two wires for heat. red - white. there is a heat anticipator setting that must match the burner current. check your programmable specs and follow instructions.
Dec 04, 2007 | Honeywell Programmable Thermostat Heater
Honeywell Heat/Cool Thermostat Logo
357 people viewed this question
Top Honeywell Measuring Tools & Sensors Experts
Brandon Berry
Brandon Berry
Bill Long
richie46
Are you a Honeywell Measuring Tool and Sensor Expert? Answer questions, earn points and help others
