Question about Dishwashers
Cleaning Dishwasher sludge
I live in NJ and have a Maytag 300 Quiet Series Dishwasher that has a build up of black/brown sludge on the bottom the door when opened. I have cleaned it repeatedly but it returns. It is so sticky and so hard to remove. I have tried running bleach, vinegar and baking soda which do not help at all. Help!!!
  • 4 Answers
This may be coming from your garbage disposal. You may not realize that residue in the disposal will seep back into the dishwasher line. Make sure the hose to the dishwasher is higher than the port where the hose enters the disposal. This will work even if you don't have a disposal. Many people make the mistake of lying the discharge hose from the dishwasher lay flat. It must go up to come down. That's why dishwashers have pumps. Hope this helped !
Posted on Jul 13, 2009
The latch is sticking on my dishwasher. How can I
replace the door latch and the handle check to see if the console loops that hold the latch are broken if so replace the console
Jun 02, 2010 | Maytag 24 in. MDB9750AW Dishwasher
1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
Nov 07, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Foul smell coming from Maytag Quiet Series 300
Hello jscott,
It is typical nowdays for most dishwashers not to drain all water out of the bottom tub (Even where you cant see) due to siphon design and energy efficiency. Try using about a liter of vinegar and throw it on the bottom tub of the dishwasher. Let it run through a full cycle and see how that works. Has worked for me
Sep 07, 2009 | Dishwashers
Maytag Quiet Series 300 smells broken door latch and lower rack
I have had the same problem and there is a simple fix.
The problem in my case was the floating water sensor was stuck and gummed up with grease.
On the bottom of the dishwasher, in the front right corner there is a round doughnut-looking thing. This is the water level sensor. It is open on the bottom, and grease collects there.
When this happens, the air pocket is too small, and the float won't float. then the dishwasher overflows. To clean it: just reach under with your finger, and scoop out the grease.
Sometimes, after doing this, the float then gets stuck in the "up" position. When this happens, the dishwasher completely drains, and the heater element for the dishwasher is exposed, and food cooks onto it, and that is where the smell is coming from.
Sep 05, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
Maytag Quiet Series 300 Dishwasher will not turn off after it com
MY DISHWASHER KEEPS RUNNING, IT IS A WHIRLPOOL GOLD QUIET PARTNER IV
Apr 05, 2009 | Dishwashers
Maytag quiet series 300 leaks from front
check the float switch on the righthand side on the bottom in the corner it should click and move freely
Dec 16, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Maytag Quiet Series 300 Dishwasher leak
hi there,
the leak may be coming from the door gasket or the door vent.
can you provide me with the complete model # please?
Sep 21, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Maytag Quiet Series 300. The lights flash in sequence starting from the outside traveling inward. The timer counts backwards from 50 to 1. Then the sequence starts over. and continues over and over. I'm able to clear it when the time reaches 1 or 2. It stays off for a while (3-4 hours) then starts over. I can not clear the countdown until it reaches 1 or 2. After I clear it the dishwasher will work, but until then, no way. This happens with the door open or closed.
Sep 15, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
I have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. I can manually hit the start button twice and it will go...
Hi jeffwirch,
I'm Harvey the Master Plumber.
Your problem is: You have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. You can manually hit the start button twice and it will go through a 2 minute cycle and pump out the water. You have cleaned the filter inside the dishwasher where it drains and have checked the hose to the disposal and it pumps out fine. It just doen't pump itself at the end of the cycle.
It sounds like a bad control board. It's in the top of the door panel. I don't recomend this repair to the average homeowner. You might consider the Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Maytag Dishwashers
Dishwashers Logo
1,833 people viewed this question
Top Dishwashers Experts
