Question about Dell Dimension 5100 (D51L1) PC Desktop
I took a WD external drive and installed it as a second sata drive. Bios and Device Manager recognize it not windows xp explorer. I want the data so I can't formator use disk manager. Drivers are on the disk. ANy Ideas?
The Drve most likley does not have a partition or it has one that is from Linux or Mac. Use the disk manager snap in and see if it sees the drive. If so then create a partition on the disk then windows will assign a drive letter and you can format it
Posted on Jul 13, 2009
A8VE-SE won't recognize SATA HDD
If you are trying to install Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Jan 08, 2013 | VIA Asus A8v-e Se Socket 939 Pci-e K8t890...
My Windows 7 cannot recognize my Sata/usb connector
USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
b>
Jan 04, 2013 | Apricorn SATA Wire 3.0 - storage...
I have a Compaq Presario Desktop Computer SR1150NX. I've added a new WD SATA 1 Terabite HD. but the system does not recognize it. I updated the Bio's but see no way to activate the SATA ports. The...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 11, 2011 | Computers & Internet
Drive Recognized but not visible on my computer
Right-click My Computer, go to Manage, Disk Management under Storage
Find your drive there and assign a drive letter.
The drive may still need to be formatted.
Sep 01, 2009 | Sabrent EC-UEIS7 USB, eSATA Internal Drive...
WD Sata drive was working perfectly then during the night
As you hear a tickling sound, I am pretty sure the HDD has gone faulty. Only way to see whether you can recover the data by your self is to fix the HDD into a external SATA enclosure and see whether it works and detected by the PC.
Otherwise the only option is to go to data recovery specialists who are normally very expensive.
It is worth contacting a local computer shop first.
All the best!
Jul 28, 2009 | Western Digital RaptorĀ® WD1500ADFD 150 GB...
External hard drive not recognized
I recenctly bought a my book 500 gig drive and it is usb.
the firsttime I plugged the usb cable in it worksed. I had only a 40 gig ide harddrive and so I ordered an internal 500 wd hard drive to replace it. The internal 500 gig is a sata drive. first I cloned the 40 to the sata 500 and then copied the external 500 to the internal. I mover the cables to then make the internal 500 sata my boot drive. The computer would no longer show the external e\when i used the windows explorer. the device manager said it was there and working with no problem but windows did not see it.
After several experiments with diferent configurations I have concluded my motherboard wasauto configuring the external and internal 500 drives as drive 0. Since the usb was detected first and was notthe boot drive then windows assigned the internal drive as drive 0 and since the usb drive was drive 0 also it would not work. windows ignored it. my solution was to return the ide as the boot drive and plug the sata into a slave port. with that configuration both drive are seen and work normally. It took me several days to find this arrangement. so since my sata ports are auto configure and the external has a sata connection i will install an esata port adapter and try to hook it up as a slave sata drive so i cab\n use my internal 500 sata drive as my boot drive.
sorry this was so long but it is my solution to what others may be facing.
May 12, 2008 | Western Digital My Book Essential Edition...
WD1000VE external hard drive not recognized
If possible check it out on another computer.
This will then establish one or the other which is misbehaving.
Then come back
Feb 11, 2008 | Western Digital (WD1000VE) 100 GB Hard...
Wd800jd sata hard drive not recognized in bios on boot up
Hi, A couple of ideas: 1. There are 3 versions of this motherboard: Dragon Plus, V1.0 & V2.0, perhaps your BIOS needs an update to be able to recognize the new HD. This of course would require flashing; 2. There are two variations of a WD SATA hard drive: Serial ATA amd Serial ATA II; 3. Re Jumper settings: the eight-pin jumper block is only used to enable power management on the drive. There are no master/slave settings since there is only one drive per cable; 4. If you are fresh installing Windows on it, you need to press F6 when asked by the Windows Installer and follow on-screen instructions. Hope this be of some help/idea. Post back how things turn up or should you need further information.
Sep 17, 2007 | Western Digital Caviar SE WD800JD SATA...
Dell Dimension 5100 (D51L1) PC Desktop Logo
50 people viewed this question
Alun Cox
