I was replacing a DUO-Therm 3105058 Rev A. very old Thermostat in a Coachman RV with 3106995.032 from Amazon. After looking all the information on the directions it was clear I would have to play a hit or miss on some of the wiring. Instead of using the same coding, such as RC, RH, G, Yellow and such. they used the function and I had to guess at some.
Here is the wiring I found worked:
There are 6 wires. One set of two wires (white On the W & red on the RH) and the set of 4 (yellow On the Y, green on the G, red on the RC and blue on the H). So to keep it simple the red on the RH went to the +7.5. The White on the W went to the FUR. HS/HP not used. the Yellow from the Y went on the cool. The green on the G went to the fan. The red on RC went to GND. and the Blue on H went to Hi fan.
So red (RH) of the 2 wire goes to +7.5
White (W) of the 2 wire goes to FUR.
Yellow (Y) to cool
Green (G) to fan
Orange or red from the RC lug goes to GND
Blue (H) goes to Hi Fan
Rv repair place should be able to order one
