Question about General Electric AEM25DL Thru-Wall/Window Air Conditioner
The unit in my apartment did not blow cold air when i first moved in, then all of a sudden one day it worked, and worked good too. Now after switching from fan to air, its not blowing cold air anymore
    Champion:
  • 233 Answers
Have miantenance check the thrmostat and the control wiring
Posted on Jul 12, 2009
Air Conditioner isn't blowing cold air
There are a few thing's that can cause this, if the evaporator coil in the a/c is blocked a little, you could get a little cool air, it's like having a dirty filter. If the condenser coil is blocked, you won't get cold air. If the refrigerant is low, you won't get cold, cold air.
Jul 19, 2013 | Amcor Heating & Cooling
M6X08F2A Air Conditioner problems not blowing cold, not cooling off apartment
Sounds like the heater is on as well. Even if ac is not working it shouldn't get hotter than outside air temp. Possible stuck relay.
Mar 01, 2017 | Maytag Heating & Cooling
My 04 dodge stratus heater/defrost doesn't work very good. You can take the dash control unit out and mess with the wires on the back of it and it will blow hot air for a little while. I use to do this...
Sounds like the control unit or wiring (since you could mess with the wiring to get it working). The controls aren't controlling the dampers in the ductwork to control hot/cold, etc.
May 19, 2017 | 2004 Dodge Stratus
2005 s type jag a/c quit blowing cold air suddenly .just blows hot at any setting or on auto
hi,is this a heatpump or a ac unit only...if a heatpump ,there is a valve that switchs from heat tocool mode...go outside with unit running..put hand on big copper line,if it is hot your in heat mode..if cold your in cool mode....possible stuck change over valve if a heatpump...hope this helps...good luck...michael doctor airr appl.repair..843-384-8474...if need more assitance..call..its free...good luck
Mar 26, 2010 | Heating & Cooling
The Amana air conditioner is not getting cold.
when is it the last time you cleaned the unit and changed the filters? it may be working good but you need to maintain the unit...clean all filters and see if you can vacum alll parts especially the condensing unit (you may need air pressure) can you move the unit to outside so you can clean it good? if you can use air or water pressur to clean it after you cover the lectrical parts. Good luck. (save your money this unit need cleaning only)
Sep 07, 2009 | Amana PTH093B35AJ Air Conditioner
A/C blows weak/low volume of air through vents
I f it is fan that has more then one speed if you run it all the time,it may
not be on high sample : low fan speed runs all the time
med fan speed for heat
high fan speed is usually for air conditioning so if everything is good then it maybe the relay.
May 02, 2009 | Carrier Heating & Cooling
Will not blow cold air
pls check your remote setting
Apr 27, 2009 | Heating & Cooling
A/C Electronic Dual Climate Control
you got dual air control on it you can ajust the the right and left if you already try that there and electric motor on the black and square in the middle of the heater on the side its did go all the way tru to see where that little motor is start our car put to cold setting and gently tap on it it should move they get stuck sometime it the setting are not change for a long time or the motor defectif go under the dash driver side look at the heating systemon the side little sqare motor with plug in the middle tap it let me know about it good luck PIERRE
Jun 29, 2008 | 2001 Pontiac Bonneville
Weather king central air conditioner
You have done a good job under the circumstances. It could be a bad start/run capacitor as well. It carries a lot of amperage so I suggest hiring a technician to check the capacitor and the motor.
Jun 25, 2008 | Heating & Cooling
General Electric AEM25DL Thru-Wall/Window Air Conditioner Logo
175 people viewed this question
Top General Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a General Heating and Cooling Expert? Answer questions, earn points and help others
