Question about Whirlpool Dryers
Clothes dryer will not start
Clothes dryer began tripping the breaker and then stopped starting completely. I replaced the breaker and checked to make sure there is power.
    President:
  • Whirlpool Master
  • 1,922 Answers
Sounds as if your motor has tightened-up or seized from heat and age bearing failure which it would cause excessive current draw at start-up if you can access the motor unplug unit then remove belt and spin motor pulley is should turn freely and coast to a stop if it seems tight the bearings are dried out
Posted on Jul 29, 2009
My white knight tumble dryer wont start
Nothing works or drum fails to turn (tumble dryers)
Ensure that the power supply to the dryer is switched on, the timer is set to the desired drying time and the door is correctly closed. If you have a condenser model, also check that the bottle is empty and is fully pushed into the machine.
http://www.whiteknightrange.co.uk/whiteknight/faq.html
The first thing to establish when troubleshooting the clothes dryer is whether the dryer will start or not. If it won't, start by checking the outlet and the circuit breaker. Is the dryer plugged in or has it tripped the circuit breaker? If the breaker has been tripped, flip it back on and try the dryer again. The drum should turn without a problem.
If both plug and breaker are fine, you'll need to inspect the door switch as you continue to troubleshoot the tumble dryer. When you close the door on the dryer, a plastic peg should click and operate the switch which allows the dryer to work. The peg might be bent or broken, in which case it won't connect with the switch. You can try to straighten the peg, but if it's broken, you'll need to replace it. If the peg is fine, the switch has probably failed and will need to be replaced.
http://www.doityourself.com/stry/troubleshooting-a-clothes-dryer-drum-doesnt-tumble#b#ixzz3FOOQgtAT
Oct 06, 2014 | White Knight Press Genuine Tumble Dryer...
When I push the start button, nothing happens. I have checked the breaker and the plug, both are OK. I just completed drying a load of clothes.
When I push the start button, nothing happens. I have checked the breaker and the plug, both are OK. I just completed drying a load of clothes. Kennmore 96590140.
Jan 01, 2011 | Kenmore 62602 Electric Dryer
While I was out of town my wife was drying clothes and she said the dryer stopped, and when she opened it the clothes were still damp. She tried to re-start the dryer and it would not start. She called a...
you must check if there is power to the element when you have it switch on , , if you have no power to the element , then trace the wiring from the element to a hi limit thermostat , it a small round disc shape item about the size of a 10 cent coin with two connections , remove the wires and check continity accross the two terminals, if it is ok , then check the on and off switch or timer dial , you might see burn marks around the connections , since it trip the circuit breaker
Jul 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore 66812 dryer stops but heat stays on
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 26, 2008 | Kenmore 62802 Electric Dryer
My kenmore gas dryer heats up but cools down too fast without completely drying my cloths
Heating element
Thermal fuse
Wiring
Oct 15, 2008 | Kenmore 74602 Gas Dryer
Magic chef dryer
hi there,
she may have tripped the house breaker. unplug the machine and check the breaker on the house electrical box. plug the dryer back in and see if that will work.
Sep 30, 2008 | Dryers
Dryer won't start
thanks fore thew question i really think your problem is with your motor if you want to change the motor get back to me and i,ll show you how the other question i would look at the therml fue located st rear of dryer remove back panel you willl see 2 small blue wires thst part replace thanks thew appliance docj
Jun 19, 2008 | Kenmore 98702 Stacked Washer/Dryer
Timed drying knob doesnt move
hi .thanks for the question. if its the timed dry cycle that s not working .replace the timer .thanks the appliance doc
Apr 17, 2008 | Kenmore 74602 Gas Dryer
Whirlpool Electric Dryer Won't Start
Your dryer has a non-resettable "thermal safety fuse" part number 3392519 which stops the machine dead when the temperature near the heater gets too high. Typically a restricted vent system causes this so you definitely want to check that before replacing it. A failed control thermostat can also cause this so check the operating temp too.
Dec 30, 2007 | Dryers
Dryers Logo
67 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
