Question about Whirlpool MH7130XE Microwave Oven
Turntable has suddenly stopped working.
We have an old Whirlpool microwave model MH7130XE. It still heats the food but suddenly the turntable has stopped working. We tried the on/off switch for the turntable but that's not the problem. Does anyone have any ideas as to what needs to be done?
  • 5,911 Answers
The turntable motor may be bad, if you've confirmed the switch is working. The motor is located under the bottom of the microwave and has the shaft penetrating through the bottom of the oven cavity with a drive coupler attached. The coupler is what drives the glass carousel tray. The motor can be accessed by unplugging the microwave and removing the bottom panel screws. The motor is held in by a couple of screws and two connecting wires. The coupler will lift up and pull off the motor shaft from inside the oven.
You can view this part and exploded view diagrams of your microwave at appliancepartspros.com. Just type in your model number and look under the "Magnetron and Air Flow" heading for item 6 (part number AP 3119645).
If you have any questions, please let me know. I hope this helps you.
Posted on Jul 13, 2009
My 5 yr old Whirlpool microwave stopped heating food. All other lights, displays, fan and turntable work. What could be the trouble?
If you do not have any experience in the repair of microwave ovens do not engage in their repairs because it is one of the most dangerous household appliances and the consequences can be disastrous. According to your description, low voltage circuit (220V or 110V) works well (light, turntable...). Obviously the problem is in a high voltage (HV) circuit which is made up of the magnetron, HV diode (rectifier), HV capacitor and HV fuse or protect diode. Failure is in any of these components in "HV circuit" or in the main board.
Dado
Jun 09, 2015 | Whirlpool Microwave Ovens
I have a High Pointe model EM925Bss-s and although the turntable does not work the oven still works. Is this dangerous?
no as long as you never put any metal or foil inside but food won't heat evenly , the turntable can usually be fixed by cleaning out center bearing with Q tip and a shot of oven cleaner this sometimes gets lots of food and grease build up from heavy use machines (usually mass food prep areas) and slows and stops the drive of turntable
Sep 10, 2014 | Microwave Ovens
Turntable won't turn
This may be a grease buildup underneath the turntable, or a bad turntable motor or coupler, or the circuitry which drives it.
If your internal cook light or cooling fan are also not working, I would suspect a controller problem, especially if your cooktop lights recently went out.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Oct 02, 2011 | Whirlpool MH7130XE Microwave Oven
Phillips whirlpool microwave turntable not turning
HELLO.
The turntable is the unit in the center of a microwave that you set your food on. It rotates during the microwave cycle, making sure all parts of a dish are properly heated. These are typically made of either hard glass or microwave-safe plastic.
Your microwave turntable may not turn due to any of these problems explained below.
(a)If your turntable is removable (as many are for cleaning purposes), it may have come loose from this turning mechanism.place the turntable properly on the turning mechanism.
(b)If your turntable was previously working and now does not any longer, check the settings on your microwave's LCD display to make sure you haven't accidentally turned off the turntable.
Most microwaves have different settings that the user can select with the press of a button, like a "Defrost" setting or a "Popcorn" setting. Certain microwaves may stop the turntable from turning during certain pre-programmed selection modes. Stop your microwave and don't use a pre-programmed mode. Instead, just specify the time using the number pads and start your microwave to see if your turntable begins to rotate again.
(c)The rotating mechanism on the inside of your microwave that rotates the turntable is actually connected to a small motor on the inside of your microwave's case. If this motor burns out or stops working, the mechanism will stop turning. This is something that needs to be replace.
follow these steps below to replace the faulty motor.
1. Open the microwave door, and carefully remove the turntable tray. Also, remove the frame that the turntable is positioned on. Both the turntable and the frame are not secured in the oven, so removing them is a quick process.
2 .Remove the bottom panel of the microwave. The Microwave Wizard website explains that the number of screws securing the panel varies depending on the manufacturer and specific microwave. Once the bottom panel is loosened, disconnect its wiring harness in order to completely remove the panel.
3. Locate the turntable motor. The Microwave Wizard website explains that the motor compartment should be positioned below the center of the microwave. Unscrew the motor, disconnect the wires, and remove it from the microwave.
4. Determine the specific part number for the turntable motor so that a correct replacement can be purchased or ordered. Position the new motor into the shaft in the bottom of the microwave. Screw the motor securely into place.
5. Test the microwave to make sure that the turntable motor is operating correctly. The Microwave Wizard website explains that the motor can make noises if it was not positioned evenly in the shaft. Reconnect all of the wires that were detached when removing the old motor.
6. Reinstall the microwave's bottom panel parts, and secure all of the screws in place. Reposition the turntable frame in the bottom of the microwave and place the turntable on top of it. Test the microwave in order to make sure that everything is working correctly.
Thanks.
Oct 01, 2011 | Microwave Ovens
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
MICROWAVE, NO HEAT, TURNTABLE WORKS, COULD THIS BE A FUSE
Please reply back with your brand and model number so we can help you.
Jan 07, 2009 | Maytag MMV5156AAS Microwave Oven
Microwave stopped working
to indutolia
The original problem was probably a bad turntable motor, which is pretty easy to replace.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Now I'd say you have a bad door switch (whether upper or lower depends on the model number) or a problem with the door switch mount.
This is a pretty simple problem to fix, too: http://www.microwavedisplay.com/doorsw.txt
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
to lostonisland - Your problem is different enough that it should be a separate post. Please include your brand and model number when you repost.
Dec 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Noisy when running - not the usual humming noise
check turntable motor or bush, this very easy problem, you can use oven no problem..
Nov 11, 2007 | Whirlpool GH8155XJ Microwave Oven
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
Whirlpool MH7130XE Microwave Oven Logo
161 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
