Question about Broan-NuTone N-667RN Combination Light Fan Exhaust Fan
Exahaust fan not working
I have nu-tone 667RN unit and its fan not running. What options do I have?
    Scholar:
  • 95 Answers
The best thing to do is buy the replacement motor. It is usually a pretty simple thing to change out and it sure beats having to take down the whole thing. Here is an article on finding the right motor. http://nutoneproducts.blogspot.com/2009/05/nutone-bath-fan-motor-replacement.html
Posted on Jul 13, 2009
I change my bathroom vent light. Before light went out. When I would turn the light on. It just came on. Now with new light, it flickers then comes on. And my hall bathroom started doing it too once I...
It sounds like you have indeed bought fluorescent bulbs. manufacturers are encouraged to replace the incandescent bulbs with more energy saving fluorescent bulbs. They are made to look like standard bulbs so you need to look at the package carefully to see the difference. The Nu Tone and other special bulbs may still be available in the old filament style for a while but you may have to look harder or ask if they are still available. The amount of flicker often reflects the quality of the bulb. It will sometimes decrease over time.
Mar 02, 2015 | Dryers
How do I remove fan from motor shaft it is a nu tone bathroom exhaust fan
THere is a set screw on the fan core that is tightly screwed down to the shaft. You may have to remove the whole fan unit to reach the screw...
Dec 21, 2012 | Heating & Cooling
Samsung SCX-3200 FUSER UNIT FAILURE #U1-2113
fuser unit failure #u1-2113, how to solve this problem?
Jan 15, 2012 | Samsung Office Equipment & Supplies
Sir, my canon ir 400 machine shows an error code 803. how can i solve the my problem. give detailed information to my mail. thanking u.
the code 803is for faulty exposure lamp or fault in composite power supply(the power supply to exposure lamp is not sufficiant to operate the lamp).to remove exposure lamp, remove copyboard glass,remove back cover ,slide scanner in the line of rear exahaust fan at the right side of scanner, remove rear exahaust fan, remove lamp holder(one screw).slide out lamp on the rear side replace new one and reverse the whole process.
Jan 27, 2011 | Canon imageRUNNER 400S Copier
Does the motor for a nu tone bathroom fan #86933-000 supposed to have 2 mounting studs opposite the shaft end? 8664RP
Yes. This motor has two studs opposite to the shaft.
Here are some pictures:
http://bit.ly/8YIowa
It is actually a better value to purchase the motor assembly S97017706 or S97017705, both fit.
http://bit.ly/asmjig
Nov 03, 2010 | Broan-NuTone N-8664RP Combination Light...
I need the glass for a QT100L Nu Tone bathroom fan
The replacement NuTone lens number is 84449000.
http://bit.ly/bfmiYu
Oct 31, 2010 | Broan-NuTone QT100L Fan
I have a Nu-tone 8663 RP Combo fan and light. The unit has been a great unit for a good number of years. The fan is shot. Motor bearings I think. How can I get a replacement fan assy. ?
I just ordered a replacement fan motor for this same exhaust fan. I got it from here, http://www.electricmotorwarehouse.com/aosmith/nutone/nutone1.htm
It's this one,
1.2 amps, 115 volts 60hz
1550 RPM; Shaft 1/4" x 1"
Rotation = CCW
3.3" Diameter Motor
2 Mounting Studs Opposite Shaft End
Motor Case Length 1 15/16"
2-Prong 115 Volt plug
For Model 8663RP, 8673RP
8664RP (86933-000)
86933000, JA2B104N, JA2B104
can substitute 99080517
Part # 86933
$43.95
It's on the first page, and the 8th motor on the page at the time of this post. Hope this helps!
Oct 20, 2010 | Broan-NuTone N-8663RP Combination Light...
Nu Tone Bath Exhaust Fan - QT-110N-B - motor vibrating
You can buy just the motor assembly. You would remove the grill. Usually there is a plug to disconnect the motor. Remove screw(s) and the motor and fan assembly will come out leaving the rough in housing in the ceiling. I did not locate your model number as you listed it however the QT line has numerous model numbers. Here is a link to the nutone page. You should be able to purchase a "trim kit" which would include the fan,motor,and grill. You can either buy it on-line, or you might try an electrical supply company.
http://www.nutone.com/product-detail.asp?ProductID=11043
Jul 05, 2010 | Home
Can the Nu Tone QTRN110 Exhaust fan be installed w/o access to attic? Mounting holes appear to be only on the flanges.
Before you put the metal box up make sure you have a couple of securely fastned pieces of wood there that the fan box will fit tightly between. Then put up the box and run screws through the metal box to hold the fan up. Then install the guts of the fan...
Heatman101
Feb 22, 2010 | Broan-NuTone Nutone QTRN110 Quiet Test 110...
Fan Light
try reducing the wattage of the light bulb.
Apr 03, 2008 | Broan-NuTone QT100L Fan
Broan-NuTone N-667RN Combination Light Fan Exhaust Fan Logo
371 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
Craig Dupler
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
