Question about Canon MultiPASS C3000 All-In-One InkJet Printer
I have been given a used cannon multi-purpose fax/copy machine. I put new ink cartridge in it still doesn't copy just makes black lines. fI cannot find out what the problem is and does it have to be connected to the computer in order to send/receive a fax?
    President:
  • 3,085 Answers
No, it can be used as a stand alone fax machine.
Posted on Jul 13, 2009
Why does it keep asking to replace black ink when already a new one has been put in
Did you use genuine ink cartridges or no-name ones? Some non-genuine cartridges just will not work no matter what the seller tells you.
If you were using genuine Epson cartridges, have a careful read here, especially the steps at the end of the article:
http://www.inkbank.com.au/webcontent31.htm
Feb 09, 2015 | Epson ME OFFICE 620F MULTIFUNCTION INKJET...
Black ink not working lexmark pro915
Check ink level, clean contacts on cartridge and machine.
Oct 10, 2013 | Lexmark Pro915 Wireless All-in-One Inkjet...
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
How can I get the fax and copy to print clearly?
Still sounds like a bad ink cartridge, try cleaning the bottom of the cartridge with a Kleenex and soapy water. Dry it off real good.
Look where the cartridge sits and clean the same way.
Ink jets are dead technology.
Nov 11, 2008 | HP 640 Inkjet Fax Machine
Print quality is poor
if you replace the black ink cart with an original one then it's the print head
Solution: Cleaning the Print Head - C555 / C560 / C635 / C530 / C545
Untitled Document Follow this procedure to clean the BJ cartridge print head:
1. Press c755funckey.gif 2. Press c755cleankey.gif 3. Use c755down.gif or c755up.gif to select the [HEAD CLEANING]..
4. Press c755set.gif.
The MultiPASS cleans the print head.
Feb 12, 2008 | Cannon MULTIPASS C530 Printer
Fax mach 1800c brother
Although you may not use the other colours the cleaning assembly cleans all the cartridges hence the other ink gets used. To trick the machine into thinking there is ink in the cartridge, place some black tape over the top of each cartridge facing front of the machine. This fools the sensor into seeing no reflected light and reads that there is ink in the cartridges you do not use. Pleas enote that if you do this on a long term basis it is liley the head will dry out and may damage the head - use this advise to get urgent prints out.
Sep 08, 2007 | Office Equipment & Supplies
Canon MultiPASS C3000 All-In-One InkJet Printer Logo
66 people viewed this question
old marine
old marine
