Question about Mtd Garden
I have a 1991 mtd riding mower, the last time I used it I parked it and when I went back to use it the mower won't go in forward or reverse- help.
    Sergeant:
    Champion:
  • 226 Answers
Sounds like the spring to linkage has given way to age;if you lift up the rear you should be able to determin if the linkage spring rusted away or came loose .hope this helps
Posted on Jul 15, 2009
Why won't the blades engage on my riding mower 54" mtd 13ap625k730?
You have probably thrown the belt for the blades. If it continues to throw the bet check the tensioner.
Aug 10, 2014 | Mtd Garden
How to adjust brake/clutch on mtd riding mower
Go to MTD website and download owners/or repair manual for your tractor ,then adjusting the brake will be easy !
Jun 29, 2014 | Mtd FASTATTACH MANUAL SLEEVE HITCH
Hi i just bought a second hand MTD C4510 ride on mower yesterday, and the drive belt came off , where can i view a diagram to fit it so it can drive forward etc
u should have two drive belts .go to nearest seller of mtd ,get owners manual .u can'not push foot speed lever to quicky up & down .start to learn how to use your mower slowly .there is no gear box for forward & reverse speed. but u have forward & reverse gearbox .talk to your dealer he will explain
Dec 10, 2010 | Mtd 46" Dozer Blade, Fits All & Yard -...
I have an MTD mower tha tis ver jerky in forward, reverse is fine. What could it be? The trans is about 2 years old. I thisnk it could be the clutch plate or the differentital, however, reverse works fine...
Assuming that the model you have is a single speed transmission with variable speed belt system and that the mower has never been used to tow anything heavier than a dump cart. 9 times out of 10 its usually the forward gear shift key not allowing it to go all the way into forward gear. Might be able to ajd the shift linkage to acomodate a tighter mesh with the input and ring gear
Nov 23, 2009 | Mtd Garden
Need instructions to replace main drive & transmission belts. Mower will not go forward or backwards. MTD model # 13AN601H729
Before you go trying to replace the belts, did you shut it down the last time you used it while the transmission was in a HIGH range?
If you did, restart it, put your speed lever back in the same or higher position with the F& R shifter in neutral, let out on the clutch/brake pedal until it takes up the slack, then pull the speed lever back into lowest speed, push in the clutch/brake and put it in PARK. Shut of the engine and then restart, it should be back to normal operation now
Sep 07, 2009 | Mtd Garden
Tractor will not go in forward gear, only reverse.
Try rocking the mower forward and backward while you try to shift it.
Aug 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
John deere x340 wont move
there is a release usually behind the seat that has to be pulled in order to push it physically. make sure that the release is pushed in for the forward/reverse to work.
May 26, 2009 | Garden
Garden Logo
166 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
