Rank: Wiz
Rating: 85%, 89 votes
Simple question, with a multitude of complex answers... :-)
There are a couple of differnt things you can mean by "connecting", and depending on your computer platform there are a bunch of different choices. Also depending on how your local cable company behaves with a copy protection standard called 5c results will vary depending on where in the country you are.
So, to start with the basics.
For a fully featured solution you need to have some form of:
1. Input into your computer to record the video and audio
2. if you wish to have the computer act as the DVR, and not the cable box then you will need to add some control software to the computer, and also you will need to have some way of changing the channel on the cable box.
The most basic of solutions would be to purchase a video capture card / USB device which has a Video input. In the Computer based DVR world the hauppage PVR 150s are great and in expensive (Complete with hardware MPEG Encoding, trust me you want this). This with the supplied software would allow you to record the S-Video out of the box and the analog Audio into your computer.
There is not a consumer grade video capture device that will allow for recording from the HDMI port, or Component Outs.
i.e., if you want to record HDTV off this box via analog, I'm sorry. It can't be done..
Comments:
Nov 16, 2007
- Part 2.
HOWEVER, it MAY (and I stress MAY) be possible to record digitally from the Firewire out of this box to a Firewire port on your computer. That, if it works is a really great solution.
There are a couple of options for how you do this, I'll outline 4 solutions, One for each of the three platforms, and one for all three. :-)
1. Linux - Grabe the MythDora Diribution and have at it. Lots of documentation on how to get it working. A complete HDTV PVR solution.
http://g-ding.tv/?q=MythDora
2a. Windows Media Center Edition :- Grab the Timmmoore firewire drivers and follow these instructions
http://home.comcast.net/~timmmoore/firewire/readme.htm
Nov 16, 2007
- 2b. Windows XP / Vista (Vista is somewhat flaky though) Grab the same above timmmoore drivers, but then grab a copy of VLC
from
http://www.videolan.org/ and setup your capture device as the firewire panel and see what you can see. If you like what you see you can record the stream to disk..
Nov 16, 2007
- Gah, stupid box..
3. Mac, go grab
http://www.ammesset.com/irecord/ Nice and easy..
These first three solutions are all based on freeware.
go to
www.sage.tv to find a dvr solution for OSX, Windows & Linux that supports Firewire & Capture cards. It also supports IR blasters to change channel. There is some pretty heavy duty firewire support that can be easily added (Think 4 cable boxes at once!) There is an active user community which can be found here
http://forums.sagetv.com/forums/
Nov 16, 2007
- If my solution was helpful, please vote for me!
