i've got an apple mac, i've had it for a while and use it near every day, sometimes leaving it open for a while as i had quite bit of work to do but one day when i went to turn it on, it wouldn't work, it still says its charging though and i've tried takin the battery out and puttin it back in, but this still didn't help, apart from getting a new one, can anyone give me help/advice?
You may need to reset the PRAM--command-option-P-R on startup. Some chimes expected. This resets the small carry-over memory, so you will lose some settings. First get it working. Before or after that try resetting the SMC--power button with battery removed, this to reset the power management.
Please report back.
-Ken
1. In System Prefs :: Energy Saver, turn on the Show Battery Status. Then you can go to Prefs and see the charge state. Consider your Battery settings.
2. Go to Apple :: About this Mac :: More Info... Power. Tell us this info as from my fairly new book. Want count < 150, Just had it on bat.
Will charge slow above 95%. Mine is white 09 early.
Charge Information:
Charge remaining (mAh): 5343
Fully charged: No
Charging: Yes
Full charge capacity (mAh): 5375
Health Information:
Cycle count: 4
Condition: Good
Cycle
Please look at Apple :: About This Mac :: More Info :: Hardware :: Power :: Battery Information and read the Health Information :: Cycle count and Charge Information :: Charge remaining and Full charge capacity.
If the cycle count is more than say 300 or the ratio of charges is <80% and it is not charging, then you will need a new battery.
Specify your Hardware :: Model Identifier and Software :: System Version too as a minimum.
-Ken
Active Computech has been working in the field of custom software development since 2005. Our expert...
(More)
Active Computech has been working in the field of custom software development since 2005. Our expert team has taken part in dozens of application development projects. We are experienced in developing advanced systems with complex business logic dealing with large amounts of data and transactions. We are able to supply you with an innovative, trustworthy software solution to complement your most complicated business ideas.
Active Computech specialists use up-to-date technologies and latest industry trends to deliver technically complex and yet easy-to-use web development and web application solutions with the optimal cost / performance ratio.
Power up and get the sound and then a white screen on a MacBook Air without a disc drive. Have tried...
(More)
Power up and get the sound and then a white screen on a MacBook Air without a disc drive. Have tried the things mentioned in chapter 3 of the manual to no avail. Would a software reload work using another PC at this stage or is it a terminal hard disk problem as somebody has suggested to me?
i have a mac book, but my macbook wont reconizge my sd card for my cell phone, but the iphoto pops...
(More)
i have a mac book, but my macbook wont reconizge my sd card for my cell phone, but the iphoto pops up, but in the finder there is no folder that will pop up
my ibook doesn't want to charging and what should I do? if I want get fix, how much it would be?...
(More)
my ibook doesn't want to charging and what should I do? if I want get fix, how much it would be? Thank you.
