Question about Uniden Qt206 Thru Hull, Digital Depth Gauge
Accurate when still display changing inaccurate
Accurate when still. displays changing inaccurate depths when moving even slowly. unit was just refurbished for this problem.
    Problem Solver:
  • 9 Answers
You might have air bubbles trapped on surface of transducer. Use soap on it so water sticks to surface, no wax, oil, or grease.
If transducer is mounted inside the boat, you have air trapped between it.
Posted on Oct 19, 2009
Testimonial: "Thru hull monted. I'll check for bubbles and clean with soap."
Lowrance troubleshooting
Pay attention if depth readings shift during times when moving from spot to spot at higher speeds. If this is the case then you have air bubbles disrupting your sonar signal causing inaccurate readings or a loss of bottom lock for the unit. If over this weeds in shallow water, this at times creates havoc with sonar readings because of the wide variance of signal returns.
check the voltage at the head unit.You should have a minimum of 11.7 volts. 12.5 to 13.5 is optimal
lower power input can affect the overall performance of your unit.
Sep 04, 2014 | Lowrance Boating
How do I get water depths displayed on my C70
You haven't said if you have a DSM fitted ( sonar unit and tranducer) the C70 is only a multifunction display unit MFDU you then put a card in for navigation, a radar aerial/ scanner or a sonar unit for depth and fish finding .
if you have a sonar unit and it's working then
press Presentation
press Depth Digit and select on / off
press OK or cancel to return to the default display
hope this helps
Aug 28, 2014 | Raymarine C70 Multifunction Navigation...
FDB4315LFC2 ERROR
Hello - Typically the "ER" code displayed on your unit does typically indicate a shorted out control panel. This can happen by excess moisture getting into the control area. Let the unit dry for 24 hours with no use, and see if the display error code erases itself. If it does not, this unit will require the repair of a professional to move forward accurately.
Oct 25, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
I have a 1999 Silverado that runs great. One problem. The is shot. Unreliable fuel gauge, display lights inaccurate, and NO odometer (or trip meter). What's worse, emissions test will require some kind...
Locate a complete gauge cluster from a local salvage yard...unless you have the odometer recalibrated in the replacement unit however, you will be required to list "mileage indicator" is not accurate to any buyer...Hope this helps.
Mar 14, 2012 | 1999 Chevrolet Silverado 1500
I just installed your video card HD 4350.I am adding a second monitor.The computer doesnot see the second monitor.
OS?
open the Display Properties window. In the settings screen, you should see something like this:
You'll see that a second display is shown. Click on the grayed out display marked as "2". The window will change slightly to look like this:
You can then change the desktop resolution and color depth. Once you've done that, click your mouse on the "Extend my Windows desktop onto this monitor" to enable it. Remember that the resolution, color depth and refresh rates of each monitor adapter combination don't have to be the same. The window should look something like this now:
Click on OK and your second monitor should activate itself as an extension of the first:
You'll find that you can change the relative geometries of the two monitors by moving their respective boxes around in the Settings window.
Oct 03, 2010 | Computers & Internet
X510c most of the time it reads 1.6 for the depth, it flashes 1.6 then it will go to the correct depth for a shqrt time then get stuck on 1.6 again some times other depths but mostly 1.6
Does this occur at any depths...over 20ft even.
The X510c will have problems keeping depth in shallow water...especially if it is muddy, weedy down there.
If the problem occurs even in depth over 20ft, then try resetting the unit:
1. Turn unit off
2. Press and hold ZIN, ZOUT, and PWR until you see the depth (flashing or not) in the top left corner.
If the problem still occurs, make sure the transducer is clean and still mounted so that it is sending the signal straight down to the bottom.
If the problem still occurs, make sure the power is good. You can have the voltage displayed on the screen through the overlay data menu.
Does the problem occur at any speed? If the problem clears up when you stop or slow down, the problem is due to cavitation and the transducer will need to be moved to a location where it is in a smooth flow of water at all speeds.
If none of this helps, there may be a malfunction with the X510c. You can try to update it but you will need to get the software update from someone at Lowrance support and then find a way to connect your X510c to a Lowrance unit that has a memory card slot via a NMEA 2000 network. I can help you with this if you need.
Other than that you can have the X510c returned to the factory for service.
Jul 09, 2009 | Lowrance Boating
Lowrance x96 does not function after 20 feet depth
Your transducer needs to be adjusted so the return signal can be picked up. Some of these have to be super tuned to receive the signal. Also the transducer may be moving ever so slightly when the boat is traveling at speed. You may have some water turbulence interference all contibute to signal return.
May 26, 2009 | Lowrance X96 200khz Fishfinder
Friendster says my friends list may not be inaacurately dispplaye
this just means that they are updating their servers on that particular element of the system or invovled in that element.
hope this helps
kev
Nov 16, 2008 | Computers & Internet
Freezing
Check the capacitors around the u-com. And also the supply capacitors for the display. I can help if u can provide me the model no. and also what kind of experience u have in electronics repair and the tools u have. Cheers. Rifaa
Sep 04, 2007 | RCA RT2390 System
Uniden Qt206 Thru Hull, Digital Depth Gauge Logo
150 people viewed this question
Top Uniden Boating Experts
Steve
Steve
Greg Cann
Greg Cann
Mike Marcotte
Mike Marcotte
Are you an Uniden Boating Expert? Answer questions, earn points and help others
