Question about Nextar X3-08 Car GPS Receiver
Nextar x3-08 freezes up on startup - Nextar X3-08 Car GPS Receiver
  • Kellie Billy
    Kellie Billy Dec 12, 2012
    I turn it on n it stops at the 1st screen n wont go from there. i've pushed the restart button a number of times n still nothing......any ideas :I
Push the reset button on the back of the unit
Posted on Jul 14, 2009
Hi, I need help, my pc freezes and I cant move the mouse or do anything else, I have to restart it. Please Help me.
Start/Run... Run msconfig. On General tab, select Diagnostic Startup. Reboot. Use the computer in this state for as long as the freeze usually appears.
If no freeze, return to msconfig General tab. Selective startup, uncheck Startup.
Repeat reboot and trial usage. If no freeze, check normal startup. On startup tab uncheck everything that looks non-essential. Reboot and retest. When the computer seems "fixed" recheck one startup item at a time. Repeat your timed test until the issue reappears. When it does, the latest startup item you enabled is the cause.
Oct 16, 2012 | ASUS P5VD2-X Motherboard
Nextar MA797 cd program video converter problem
well, on the instruction manual, what size is the screen? mine is 128x128 so in the resolution on the converter (any) i click that resolution and then it should work
Jan 08, 2010 | Nextar MA797 MP3 Player
My nextar GPS screen is flashing and won't turn on or off. I have had it for 1 week. X3-08 Please let me know. Tim Nextar X3-08
try tapping the bottom right of the screen with your finger, during the error or freeze up. > (gently)
Sep 03, 2009 | Nextar X3-08 Car GPS Receiver
My x3t is frozen at logon screen help
Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In this case you must return the unit for exchange or repair to the retail location from which you purchased it, or contact Nextar for further assistance.
For technical support for your Nextar GPS see http://www.nextar.com/frontend/support.asp or you can phone them on 888-849-0846
Please remember to rate my answer. Thanks.
Jul 02, 2009 | Nextar X3-02 GPS Receiver
Gps freezes , wont load up,and fatal application error comes up
Your getting fatal error's ? Your going to need to have this services if it freezes! There is not a easy fix for this one..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 24, 2009 | Nextar X3B GPS Navigation System
NEXTAR 14-bct KEEPS FREEZING UP.
I just opened up a Nextar 14-BCT GPS unit and found the inner side of the ribbon cable is cracked. This unit has the exact same freeze on load screen as you do, so try looking inside, you may need the LCD ribbon cable or both LCD and LCD ribbon cable for your unit to function normally again.
Feb 23, 2009 | Nextar I4-BC GPS Receiver
MY NEXTAR MA9336A1S IS STUCK ON THE NEXTAR SCREEN
Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In either case, please return the unit for exchange or repair to the retail location from which you purchased it, or contact us for further assistance.
Apr 06, 2008 | Nextar MA933A MP3 Player
X3-02 nextar gps
three step solution, easily correctable. wrap in towel, smash with ball peen hammer, gently lay in trash. You should have no more issues after this.
Mar 22, 2008 | GPS
I need help
ok it seems you don,t have enough ram that why it freezes your computer ?
Mar 03, 2008 | Nextar MA7151B MP3 Player
Nextar HGPS35
I found this on Nextar support site. These units **** lots of problems being reported by many users.
Q: It (GPS) freezes on the "loading" screen. Why?
A: Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In either case, please return the unit for exchange or repair to the retail location from which you purchased it, or contact us for further assistance.
Jan 13, 2008 | Nextar X3B GPS Navigation System
Nextar X3-08 Car GPS Receiver Logo
394 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
