Question about Whirlpool GH4155XP Microwave Oven
When I try to turn on my microwave it will not start and "door" shows up on the screen. The light on the inside is not workin either. This unit is 4 years old and we have already have the light fixed once - for 100.00 - tell me this is not same problem as this has been a very poor appliance - is there a reset button?
  • William Miller
    William Miller May 11, 2010
    What is your model number? This
    is usually caused by either a bad door switch or a loose door switch
    mount, which are pretty simple problems to fix. This
    is usually caused by either a bad door switch, a loose door switch
    mount (which are pretty simple problems to fix) or
    occasionally a
    problem on the control panel.
    Even though a door
    switch clicks, it may still be bad inside.
    Door switch
    or mount trouble is usually caused by slamming the door or by opening
    the
    door while it's cooking without hitting the Stop pad first.
    There are
    plastic mounts inside the microwave which hold the door switches and
    onto which the door latches lock when you close the door.
    The screws on these
    mounts may be loose. If they get too loose, the switches will not be
    activated properly.
    Sometimes it's
    a broken tab on the switch holder, allowing the switch to rotate just
    out of position. This tab
    can be hard to see, since it is under the
    bottom edge of the switch.
    If the switch mount is broken, it's usually more economical and
    safer to add a dab or two of hot glue to the mount to secure the
    switch. Let it cool for about 30 minutes before using.
    One test that sometimes
    helps is to
    gently lift up (and/or push down) on the door or handle as you try to
    start it. If it works or tries to work, then it's a door switch mount
    or
    door alignment issue.
    If you only need a
    switch, you can order a universal type here for $5 postpaid.
    If you think the problem
    is on the control panel, we repair these nationwide by mail
    for $39.95 postpaid in most cases in about a week or so with a one-year guarantee.
  • 999 Answers
The "door" is telling you the door is not properly closed or a switch or two is not working properly. Start troubleshooting with the door switches. One of them is a monitor and is normally closed and opens when the door is closed. it will blow the fuse if it does not open before the other switches close. Very short time frame.
Eric
Posted on Jul 16, 2009
Why won't my interior microwave light turn off and my microwave won't start?
It sounds to me that your door switches aren't working.Your oven is protected by a couple of switches that engage when you open or close the door.They control a couple of safety features and also your interior light.One of them seems defective.
Dec 17, 2014 | KitchenAid Microwave Ovens
Whirlpool Electric combination Microwave and Oven -- when I try to turn on the microwave the words "door" comes on screen and unit does not start. The door does latch but still does not start....
I could have been more specific with a model number, but if this general answer doesn't do the trick, feel free to contact me with your full model and specific symptoms here.
It's usually a bad door switch or door switch mount. My helpful text file on door switches is here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If it's one of those overdesigned Whirlpools, it can be one of many components. See the example photo at the bottom of this reply.
Oct 05, 2011 | Whirlpool RMC275PD Microwave Oven
I have a JVM1850 that was installed 4 years ago. The unit was working fine, then a day ago I received an error display requesting a charcoal filet replacement. No filter is needed since it is vented...
I have a JVM1850 White microwave-over the oven-installed 3 years ago. Last evening the unit would not turn off. The inside light and fan continued to run, however, the microwave was not working.
All the controls and functions seem to operate, but when completed, the unit remained working, as stated above, with the door opened or closed.
Sep 18, 2011 | GE JVM1850 1000 Watts Microwave Oven
Hotpoint RVM1435 when I push start button will not start unit?
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 30, 2010 | Hotpoint RVM1435 Microwave Oven
Hi our Haier HMW31AEDS microwave has the following problems. 1. It starts itself as soon as we shut the door. 2. The keypad does not work. 3. The only way to turn it off is to manually pull open the door...
I am 90% sure the running as soon as the door is closed is a bad door switch. This could possible explain all the issues with the unit. I would check that first
Nov 21, 2009 | Haier Microwave Ovens
Microwave seems to run, but won't heat.
We have a similar problem! It sounds like a problem with the microswitch inside the unit that the door is suppose to engage when closed. If not engaged properly, it will not cook. We had the switch replaced last March but it has started acting up again. We can press in on the door and/or lift it slightly and it will cook. Try putting time on the counter and hit start. It the word "cook" appears then try moving the door slightly and see if the turntable starts turning. If not, then you may have a more serious problem. Good luck!
Oct 09, 2009 | Frigidaire FMV156DC Microwave Oven
Door latch and Screen
This is because of the broken latch. There are switches inside the oven that are operated by the door latches to make sure you're not trying to use the oven with the door open. With the new door, your oven should be back to normal.
Feb 06, 2009 | Whirlpool Microwave Ovens
We have a microwave modell MQ9998W, which is not responding, when we press start, it will not activate, clock counts,and light inside works, just will not start, I feel as though there is a fuse or...
Your issue is;
"we have a microwave modell MQ9998W, which is not responding, when we press start, it will not activate, clock counts,and light inside works, just will not start, I feel as though there is a fuse or something which is the problem. The unit is from 1990, if it is something simple i will try to fix , if not guess you know the alternative"
My Solution is:
Following this link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides valuable D.I.Y. safety information on the make and model number of your appliance. In order to access your product information, you will need to enter the model number stamped on the manufacturers product information data tag, located on the unit.
Note: A volt-ohm meter is beneficial in performing electrical tests.
Thank you for providing a valid model number!
From your description, it sounds as if 1 or all of 3-4 door switches has failed. Using the link supplied above, you can view a page with these switches. The link below shows an exploded view of the service area. Using an ohm meter will help find the faulty switch.
http://www.repairclinic.com/0100_37.asp
Please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 26, 2008 | Microwave Ovens
Keypad problem
The most likely causes are a bad door switch or a problem with the control panel assembly. You can find critical safety information plus our information file on checking and replacing door switches at our site, via our poisting here: http://tinyurl.com/yzjozk If you need control panel repair, we do that for $32.50 nationwide.
Jan 24, 2007 | Kenmore 62622 Microwave Oven
Whirlpool GH4155XP Microwave Oven Logo
103 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
