Question about HP LaserJet 3330 All-In-One Printer
Recurring error I keep getting a message that says printer mispick and I cannot solve it. My HP 3330 is only 3 years old and has had light use. Its in perfect condition. How can I fix this? Thank you.
  • Anonymous Nov 17, 2007
    Exact same problem. Does anyone out there know how to fix this?
  • Anonymous Dec 17, 2007
    same here. no solution so far. please post any solution.
This answer was almost exactly correct:
>hey guys, for the "printer mispick" problem, try to remove the >toner and look IF there's any paper jam inside,because this >solved my problem,..
>=open toner door
>=remove the toner
>=look carefully IF there's any paper stuck between roller
>=CAUTION - carefully and gently remove the paper if so, as it >will be a nightmare if half tear off and the half end will be more >difficult to remove,...
The only thing I did differently, that worked like a charm, was to =open the door on the other side of the machine, and
=swing down the two green levers (one on each side); this released the roller tension and removal of the paper was easy.
=Once the paper has been gently removed, put back up the two green levers, and
=close everything up, re-installing the toner cartridge as you do.
Posted on Apr 28, 2008
  • quickview Dec 06, 2010
    Re: "Printer Mispick" error. The post by Bricolage was very helpful, the only thing i would add is that the two green levers that release the tension on the rollers are located on the BACK of the machine under the rear cover not on the side.
Hey guys, for the "printer mispick" problem, try to remove the toner and look IF there's any paper jam inside,because this solved my problem,..
=open toner door
=remove the toner
=CAUTION - carefully and gently remove the paper if so, as it will be a nightmare if half tear off and the half end will be more difficult to remove,...
Hope this will help !!
thank you
Posted on Mar 16, 2008
I have had the same problem,,,,another internet search, suggested the "mispick" is really a paper jam,,,,,which turned out to be the case for me.
Posted on Feb 24, 2008
Hey, mine just did the same thing . . . unplugging and rebooting printer does nothing. Rebooting computer did nothing as well . . . help!
Posted on Jan 25, 2008
Printer mispick message
Your printer probably needs to have the paper pickup roller replaced.
You might try to clean the roller with a slightly damp lint free cloth.
Pull out the toner cartridge and look down you will see the roller sitting there.
Gently wipe it down, reinstall the toner and try printing again.
Mar 29, 2011 | HP LaserJet 3330 All-In-One Printer
"printer mispick enter to resume"is
replace pick up rollers and or the whole pick up assembly
Dec 25, 2010 | HP LaserJet 3330 All-In-One Printer
Message: Printer Mispick.[Enter] To Resume
Sounds like the pick up rollers are not pulling the paper in. Try cleaning them or replace if they look worn. When I try to examine all the parts you can find some small piece of paper caught in somewhere around.
Thank you!
May 18, 2010 | HP LaserJet 3330 All-In-One Printer
HP Laserjet 3330 Multifunction monochrome printer,copier,scan and fax. This machine will warm up, and after it reads "scanner lamp warming", the scanner lite lights up, the carriage moves back and forth,...
This type of problem is usually caused by dirty mirrors in the scanner. After a few years of use the mirrors and lenses in the unit will get a fine coating of dust particles on them. The dust interferes with the scanner initializing the optics. When this happens the unit displays the Scanner warming up message on the screen and keeps trying to move the scanner assembly to get a good reading from the pickup. To solve the problem you will need to disassemble the scanner portion and clean all of the mirrors with window cleaner and a soft cloth or q-tip. To get dis-assembly guides just do a google search for the 'scanner warming up' error.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 04, 2010 | HP LaserJet 3330 All-In-One Printer
Problems with hp laserjet 3330
suspect either worn ADF(automatic document feeder) pickup roller or there is a jam in the ADF unit where the paper feeds to the scanner.
Mar 11, 2010 | HP LaserJet 3330 All-In-One Printer
Printer mispick
Hi ,
The print engine has failed to pick up a piece of media.There is a paper jam in the printer's paper path. Reload the paper in the paper input tray; verify that there are no jams in the paper path, and press MENU/ENTER to continue the job. If the error persists, replace the printer pickup roller. Check paper path, including rear output door for jams, fuser area, and under the print (toner) cartridge.
Feb 10, 2010 | HP LaserJet 3330 All-In-One Printer
Printer mispick and how to solve it? I tried to open the door to take paper out, but left a little piece there I believe since the paper was broken. Now, I can not print anything and can not find any piece...
Clearing a paper jam - (or leftover bits of paper)
The LJ 3380 may be shown in this tutorial from HP: (do not try any disassembly other than opening the product doors as suggested in this tutorial)
HP LaserJet 3330 Clear Paper Jams
If this info is helpful, please vote.
Dec 29, 2009 | HP LaserJet 3330 All-In-One Printer
Printer error as stated "Printer Mispick [Enter] to resume." There was a mispick but that was corrected; however the error message is constant.
Hi:
I own a HP Laserjet 3330, and usually all that it takes to fix this problem is cleaning off the paper pick up roller with a damp cloth.
It is having trouble picking up the paper sheets, and you will get the error time after time. It seems that the recycled paper is worse than others. Remember to use a cloth dampened with only water, as other cleaners will dry out the pick up roller
Oct 26, 2009 | HP LaserJet 3330 All-In-One Printer
HP laserjet 3330 MFP
I have that oranage triangle light blinking as warm up message continues I also had power loss I have taken the plug out and will wait a while and try again. I still get now scanner errors using ubuntu..
May 16, 2009 | HP LaserJet 3330 All-In-One Printer
Problem with HP LaserJet 3330
hi,
try to clean the pick rollers with cotton w/ alcohol.if it doesn't work maybe your separation pad is worn out and need to replace it..
Oct 30, 2008 | HP LaserJet 3330 All-In-One Printer
HP LaserJet 3330 All-In-One Printer Logo
1,146 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
