Question about Watches
When i push the Bluetooth button nothing happens. When i first got the watch and clicked the bluetooth button the dial changed and pointed to the bluetooth arrow. Then i could connect to phone.
  • Anonymous Sep 20, 2015
    Is a casio edifice eqb 500
  • Hans Deraedt
    Hans Deraedt Feb 10, 2019
    was there a solution?
    Sergeant:
  • 257 Answers
Check with user manual .
Posted on Dec 27, 2015
slp11508
  • 43 Answers
SOURCE: Trying to remove links on a fossil watch w/arrrows pointing out
Are you pushing the links in the same direction as the arrow is pointing? If so, are you using a tool specifically made for removing watch links? If the answer to both of the above is "yes" then look closely at your watch. The pin will look different on both sides. One side will look like the head of a "screw" and the other will look rounded and just come to a point. You always want to use the watch link remover tool on the ROUNDED end and push the "screw" looking end out. It could be that your watch was assembled w/the pin facing the wrong direction.
If you appreciate me solving this for you then please rank this solution as "fixya" or at least "helpful", thanks!
Posted on Jan 14, 2009
SOURCE: my michele watch chronograph is stuck
raebarb,
I had the same problem, you can fix it without an expensive watch maker. The online instructions are not perfect, but are better than the ones that come with the watch. Go to www.michele.com/.../Michele/.../instructions/michele_instructions.pdf
Refer to page # 10 "Adjusting the Chronograph Hands to Zero Position" even though these instructions refer to adjusting only 2 hands on a different model, with a little playing around you can reset all 4 hands. The trick is to pull out the stem, 2 clicks to position III and then using buttons A and B. You will have to do the 2 hands then push the stem back in. Repeat the process and reset the other 2 hands.
Good luck, YOU can do it, I just did.
Fingers Cramer
Posted on Jul 02, 2009
escapement
  • 2338 Answers
SOURCE: I can't set the time I pushed the mode button 3
Try to push and hold a bit.
Posted on Feb 08, 2010
  • 93 Answers
SOURCE: i am trying to figure out how to change the backgr...
Not knowing what watch you have, most likely the battery for the background is dead. Most of these type of watches have two batteries. One for the actual watch and another for the background. Take your watch to a watchmaker and they can properly change the battery or diagnose what is wrong. if the battery is not the issue.
Hope this helps.
Ken
Yellowstone Watch, Inc.
www.yellowstonewatch.com
Posted on May 24, 2010
  • 267 Answers
SOURCE: my talking watch does not work. I have pushed all the buttons and nothing happens. Where can I have it repaired?
The battery is probably dead or dying. It takes more power to make sounds than to just keep the time.
Posted on Feb 09, 2015
Hi there I have a forerunner 35 that is showing as connected with my iPhone, however, none of my activities registered on the watch are showing on my phone in the Garmin app, any ideas?
Tip & How-To about Miscellaneous
Pairing Bluetooth Devices Posters often ask "How do I pair my Bluetooth ???" Insert whatever device you have at the question marks.
Generally, you need to read the instructions for the camera, headset, speakers or whatever the Bluetooth device is.
Roughly speaking though.
Settings - Bluetooth - Search, on the Android, iPhone, Windows phone whatever.
With camera, speaker, headphones or whatever the Bluetooth device is, you have to press a button on that device to send out the signal. On my Bowers and Wilkins T6 Speakers, there is a button on the top with the Bluetooth symbol on it. This is the part people usually don't do and ask for advice, thinking it will do this automatically.
When the Android or iOS device recognises it, click Pair, and if it asks for a code, the Default is '0000', (four zeros, no quotes).
Posted by Andrew... on Nov 19, 2016
Feb 20, 2018 | Garmin Watches
How do I set the time on my gold watch that has three buttons
As your watch has 3 buttons I am assuming that it has the main dial and 2 sub dials maybee to show the date. The centre button should pull out (DO IT GENTLY) and either will stop or click ,you should then rotate it to set the time, when done push it back in to start the watch running.
The 2 outer buttons probably work by pushing them in a click at a time to set there respective dials.
Oct 02, 2017 | The Watches
Changed battery and it doesn't detect transmitter. Everything else works and the transmitter gets detected by our treadmill, so I know it works.?
Transmitter Battery
The estimated average battery life span of the transmitter is 2500 hours of use. If you suspect that the transmitter battery
has run out, contact your authorized Polar Service Center for a replacement transmitter. Polar recycles used transmitters;;;
Dec 28, 2013 | Polar F6 Wrist Watch
How do you set the day of the week?
Since you didnt tell me what KIND of watch it is I am giving you a general instructions.
  • Wait until the second hand is at zero (the top of the dial). Then pull the crown knob out as far as it will go to set the time on your watch. Turn the knob in either direction and look at the three additional hands on the time dials of your watch: the minute hand, the hour hand and the 24-hour hand.
  • Step 2 Stop turning the knob when all minute and hour hands are pointing to the correct time. Pay special attention to the 24-hour hand so that you have a.m. or p.m. correct.
  • Step 3 Push the knob back in exactly when a new minute is starting so that your second hand will be correct. Use another clock you know to be accurate as a reference, such as the government clock available online.
  • Step 4 Pull the knob out halfway so you can set the date. Turn it counterclockwise until you notice the date on the watch changing. Stop it and push the knob back in to its starting position once you reach the correct one. Try to set the date before 9 p.m. If you set it after that time, it may not register with your watch that it should switch the date at midnight. If this happens with your watch, just fix it the next day.
  • Step 5 Set the chronograph, or big dial, on your watch. It works like a stopwatch to let you time activities for up to one hour. Push the top button on the side of your watch to start it. Push it again to stop it. Push the bottom button on the side of your watch to reset it.
  • It would certainly help if next time you let us know what kind of watch it is you have, Best of luck.
    Aug 11, 2010 | Watches
    Can someone tell me how to work the 3 dials on a Tourneau Safari Sea Big Date watch? I ordered the watch and it did not come with a manual (I am getting ready to call up Tourneau to ask them to mail me...
    The push button at 2 o'clock is START/STOP/RESTART button for chronograph function. Push button at 4 is for RESET (it resets chronograph hand to zero when pushed). Crown at 3 is for time and date setting. When pulled out to first click, it changes the dates by the means of turning it. When pulled out to the second click, it sets the time by turning it.
    Feb 26, 2010 | Bell Watches
    I have a police chronograph watch about a year old if that and the chronograph dials have reset themselves at random points does anyone know why and if so is there a fix? many thanks david
    hi,
    all you need to do is pull the centre bezel out (to where you adjust the time) and by pressing the top button the chronograph needle will move round. Once it is the correct place simply push the centre bezel back in.
    Hope this helps.
    Duncan
    Dec 17, 2009 | Police Watches
    I purchased thr Citizen BL717459L at an auction. How do I set it?
    Pull the crown out 2 clicks and rotate it to set the hands push it one click in to set the date. If you need to set your chrono hands or resynchronize them then pull the crown out 2 times and push the upper button until the hand is synchronized with the 12, the lower button should adjust the other dial the same way. If you have a third dial that needs synched only pull the crown out 1 click and push the top button to synch the hand on the dial.
    Nov 19, 2009 | Citizen BL717459L Watch
    I need instructions on setting the alarm for the Pulsar Chronograph 100M. I'm able to set everything else. Your response is greatly appreciated. THANKS!!
    I answered this for different Fossil watch post, but I believe it will be the same for your watch.
    I'll re-post the answer below.
    To set the alarm on these models of Pulsar watches, do the following:
    Looking at the face of the watch, there are two buttons and a crown on the right side. The TOP button is Button "A". - The BOTTOM button is Button "B".
    There are 3 positions on the crown: IN (#0), FIRST CLICK (#1) & SECOND CLICK (#2).
    The small dials located at the bottom of the watch face (6 O'clock) are the alarm minute and hour dials.
    First, pull the crown out to the second 'click' (position #2) ... This is all the way out. (STOP THERE! Pulling harder will harm your watch! Don't try to pull past position #2!)
    Second, set the correct time. (plus one or two minutes... time to complete this.)
    Third, with the crown still out to position #2, push button "B" (bottom) until the alarm minute and hour hands are set to the present time (same as the large dials).
    Fourth, push the crown all the way in- to position #0.
    The current time on the large dial should read the same as the small alarm 'time'. {This is the CURRENT TIME, not the alarm SOUND SET.}
    To set the alarm SOUND time, pull the crown out to the first click (position #1).
    Push button "B" until the dials of the alarm are at the time you want the alarm to sound... It can only be set within 12 hours! ... It does NOT know "am or pm".
    When the desired time is set for the "alarm sound", push the crown all the way in (position #0).
    The alarm dials will now indicate the time for your alarm to sound, NOT the current time. (this way, you know that the alarm is engaged.)
    To reset the alarm- or disable it, pull the crown out to the first click (position #1) and hold button "B" down until the dials advance and stop at the current time... it will stop at the current time- then release button "B". --- Push the crown back in (position #0) and the alarm will now be disabled.
    If the alarm dials are always moving and at the current time, you know that the alarm is disabled.
    If the alarm dials are stationary and not moving with the time, you know that the alarm is engaged and set to the time shown.
    I hope this helps.
    Nov 05, 2009 | Pulsar Chronograph Watch
    Vivani watch has multiple dials and buttons but no response
    Yeah I have the same kind of watch. The three small dials are ornamental and nothing more (this is obvious because their denominations are 60, 60, and 24, instead of something useful like 1-12 month, 1-31 for date, and 7 days of week). The extra two spring buttons are probably the same... nothing but ornamental. You could verify this by taking the back off the watch and seeing for yourself that they probably press nothing at all. Are simply there for maybe some other design where the case is uses,to illuminate the dial or other thing not on the watch. Vivani watches seem to be simple watches that are very ornamental and pretty (i.e., dress watches on the cheap) but completely lacking in features at all.).
    Apr 16, 2009 | Watches
    Fossil ch 2470 watch. I have no idea what the extra little dials are for on the face and how to set them. Please help
    The dials are part of a Chronograph (stop watch) I assume there is a second, minute, and maybe a date function. Usually the large second hand is part of the stop watch on only moves when you start the stopwatch (top right button) push again to stop and reset back too zero is the bottom button. Usually to set or zero out those dials pull out the crown to the first click (also sets date) then push the top button to set the seconds (big hand) and the bottom button to set the other. sometimes you may need to pull the crown out to the second click (also sets hour and minutes) to set add'l dials. This is generally how you set most chronograph watches the button you push and what moves may be different.
    Dec 25, 2008 | Fossil CH2470 Watch
    Watches Logo
    324 people viewed this question
    Top Watches Experts
    Arturs Kalnins
    Arturs Kalnins
    Marvin
    Marvin
    Are you a Watch Expert? Answer questions, earn points and help others
