Question about Samsung HLN4365W 43" Rear Projection HDTV-Ready Television
Picture loses color on samsung HLN4365W
Hi I have samsung HLN4365W- 2004 and second time this same thing happens.Picture becomes black/white and flickers/jumps.
I have color wheel replaced aug 2006 and also new lamp installed.
I still have one new lamp, should I try to change the lamp again.
Appreciate your help.
  • 111 Answers
Re: picture loses color on samsung HLN4365W
If the picture is still visible but lacking color, it is not the lamp. check the color wheel and make sure it is working. replacing the color wheel is a pretty easy task and can be performed by yourself without many problems. as a sidenote, older samsung dlp tvs seem to experience this problem quite often, although they usually sound like someone strangling a cat before the bearings go out.. should carry your replacement for 100 USD or so, the part number is BP96-00250A.
before replacing it, make sure your old one isn't just stuck or not spinning at full rpm, if this is the case, you can usually remove it and clean the motor using electronic or contact cleaner that is safe for plastics.
to check everything out, you will need to remove the back panel of your tv, then power it up (keep kids, small animals, hands and such away from the back while powered up), take a look in front of the projection lamp and see if the wheel is turning. if not, a very good writeup is available here, this is the writeup i send my own customers to if they feel like attempting the repair themselves.
replacing the color wheel is actually not very hard at all, if you have ever worked on your own desktop pc (installed a new drive or upgraded it yourself) then you should be able to do this with limited difficulty.
hope this helps,
Posted on Nov 16, 2007
0 characters
3 Points
I have a 43 inch samsung DLP tv 2004 model# HLN4365W, I was getting a black and white picture, so i replaced the color wheel which was broken. It worked fine for a couple of days then there was no picture,...
No picture on a DLP when you can see the lamp is working is ALWAYS the DLP chip. BECAUSE you recently replaced the color wheel, i suspect that the LVDS/data cable to the light engine was not plugged in well and has come loose. I suggest checking and rechecking every cable and plug you can find.
Aug 09, 2012 | Samsung HLN4365W 43" Rear Projection...
Model hln617w. the picture on the screen freezes into a black and white image of what was showing on the screen. with no blinking LEDs, yet. I turn off the tv, then turn it back on. thats when the LEDs...
Most likely your problem is on the DMD Assy Board P/N BP96-00249A . More presicely there is a few bad electronic components on that board that are bad. That board can be repaired by replacing the bad components (and the other few compoonents that are probly going bad and will soon cause your tv to lockup and lose remote and button functions when it fails so you will need to unplug it to get it on again).
Or the DMD board can be replaced .But it is not a cheap board.
For removal and Installation of the DMD board I would reccomend a tv service person because it is in the heart of the television and there are some adjustements to be made when the new board is installed.
To get the new board you could probably find it by just gooogling the part number.
Component level repair would require some experience in desoldering and soldering SMT,SMD , and or surface mount components.The actual components are about $15.00 total so just repairing your board should cost about $125.00 by a qualified servicer (if you were to remove and install it yourself). This DMD board is used in many models and can a few common problems.
HLM437W HLM4365W HLM5065W HLM507W HLM617W HLN437W HLN4365W HLN467W HLN507W HLN50665W HLN567W HLN617W ( L2 and L5 chassis )
-Intermittant picture freezing with a negative looking B/W frozen picture.
-Intermittant loss of pic with/without shutdown,abnormal color wheel noise if attempted to start after shutdown.
-lockup of tv control functions . Remote and front keypad do nothing , TV must be unplugged to reset .
-horizantal tearing, distortion , flippnig , solarization , red picture, leading to blank screen and lockup.(tv menu would be affected by all picture defects).
Hope this helps someone..
May 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
The sound comes from the color wheel and not a fan,common to samsung dlp tv's which can be the cause of the shut down.
Mar 22, 2010 | Samsung HLN4365W 43" Rear Projection...
50" DLP Samsung HDTV
That sounds like one of 2 things:
  1. Color wheel
  2. Light engine
Color wheel because of the losing color, but the light engine because of the picture freeze. It's very difficult to judge since I can't be there to see it. I'm leaning toward the light engine though. The only fix is to replace the DMD board, or entire light engine.
Feb 04, 2010 | Samsung HLN5065W 50" Rear Projection...
Distorted picture. changes from color to black and white.
Hi, this is a bad main board that is causing this issue you are experiencing. simply replacing this board will fix this issue.
Click Here
May 21, 2009 | Mitsubishi WS-55511 55" Rear Projection...
My samsung dlp picture is dark, and if i turn on game mode the picture will lose color and become black and white.
you need to replace the lamp, and after you put it on game mode, go in and adjust the pick settings see if that helps
Jan 07, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Problem with Samsung HLN4385WX
These sets have a color wheel in them that has been know to cause this, Many times the customer heres the color wheel bearings failing and think it's a fan failing. The part BP96-00250a is only about $95.00 and since I have changed well over a hundred would call this a easy repair but for the newbie this might be a challenge
Apr 02, 2008 | Samsung HCL4715W 47" Rear Projection...
HLN4365W Picture goes askew and turns to black and white.
Hi...what you are seeing is the DMD board (digital Mirror display board) going bad. And if you leave it turned on like that it will damage the DMD mirror and freeze that picture into the mirror. It will look as if someone etched it into the mirror. DMD boards can be repaired and some cannot be repaired. The DMD board can be replaced. The DMD mirror can also be replaced too.
Mar 27, 2008 | Samsung HLN4365W 43" Rear Projection...
Picture problem
try to put away any electric device which is near your tv set
Nov 25, 2007 | Samsung HLN4365W 43" Rear Projection...
No picture, new lamp
Did you reset the hours on the lamp with the menu options on your set? Sometimes, if you do not do that it can mess with the tv performance thinking that its over hours. It needs to be reset to 0 again...
Sep 24, 2007 | Samsung HLN4365W 43" Rear Projection...
Samsung HLN4365W 43" Rear Projection HDTV-Ready Television Logo
609 people viewed this question
Top Samsung Projection Televisions Experts
Steven Wander
Steven Wander
The Wyzzyrd
Donald Griswold
Donald Griswold
Level 1 Expert
Are you a Samsung Projection Television Expert? Answer questions, earn points and help others
