Question about Home
Need to replace the faucet on my whirlpool tub but no access panel
  • 62 Answers
No access panel is common practice just access panel for repalcing a shower valve....sorry, get out your pocket book.
Posted on Jul 14, 2009
How to fix drip on Moen T951 faucet
Replace cartridge..Moen will give you free cartridges for life of faucet.
Sep 09, 2014 | Moen T951 Monticello Two-Handle Low Arc...
Tub faucet (hot side) won't turn off when tight and the shutoff valve won't stop the water either
sound like you need a new valve in the hot water Faucet the rubber washer or cartridge depending on what type of faucet you have
May 09, 2014 | Sunrise Specialty Cast Iron Claw Foot Tub...
Hydrabath tub
I suppose you intend to install the faucets on the hydrabath tub. There should not be any restriction to the choice of faucets as long as they fit into the location and situation of use.
Feb 23, 2014 | Plumbing
I have A whirlpool hot water heater I can get hot water downstairs but not upstairs through the shower and tub
Upstairs do you get hot water to your sink faucet. If you do this indicates to me that the temperature valve in your Shower & Tub may need to be adjusted.
For single handle please remove handle to gain access to dial that adjusts hot & cold water mixing.
Remember where it is and take it out and replace about a 1/8 to 1/4 turn counter clockwise and reinstall and try.
It is a plastic adjustment dial that will slide off after the handle is removed.
Trace lines if possible to assure correct pipe's are connected to valve.
May 20, 2010 | Home
My bath tub with jets hums and I can't find an access panel.
The pump is usually at the side/rear of the tub, opposite the drain, the faucets can be mounted anywhere, but usually over the drain. The panel could be tiled, and just grouted in, if it is not exposed, try tapping on it to see if it sounds different in spots. Who knows, it might just fall out. How about behind the back wall?? Closet? Access? There is no electrical parts in there to repair, Pretty sure it is just the motor. and a bunch of pipes glued together and stuck through the tub. Did you fill the tub with water before trying the jets? Just checking. Hope this helps.
May 15, 2010 | American Standard 2770.018w.020 Cadet...
The roman tub faucet keeps dripping. I push down on the stems and it stops?
the retaining nut,located under handle may not be screwed down all the way.this happened to me on similar / same faucet's.so try this and see,nice and easy
Dec 30, 2009 | Delta Faucet Delta T2710-LHP Classic Roman...
My American standard hot tub leaks sometimes when it is running. It doesn't leak in the front where there is an access panel, so I assume it must be leaking on the otherside of the tub. Where should I look...
take a real good look at all waste and over flow conection's. be sure to check the over flow outlet real good,and faucet flange's, estcuchoen's etc. try using small mirror's where you can't see good.
Dec 29, 2009 | Home
Can I replace delta faucet t2710 with Delta SBS 84010BN ?
yes . when buying the faucet dont forget to buy stainless steel suply lines for water line connection.
May 17, 2009 | Delta Faucet Delta T2710-LHP Classic Roman...
I have a vitabath tub and would like to change out the brass jet fittings and faucet with brushed nickel or even white ones. Is that possible?
see if you can get the ones you want and see what it will take. But, yes it 's possible. Get the replacements first, the instructions on the faucet will help.
May 15, 2009 | Whirlpool Best Selling Two Person Air Tub...
How to Change White Water Whirlpool Tub Jet Hardware
First step is to remove the old hardware so you have something to compare it to. THere are two types/sizes of tub faucets on the market for deck mounted applications. If yours is mounted on the tub deck then it is a deck mounted application.
The faucet spread (distance between the threaded nipples on the bottom of the faucet) is going to be something close to 8" or it will be of variable distance. If the two handles and the spout are connected via hose then they are of variable length.
Bring the old faucet into the hardware store and compare it so you know you are getting the correct one. It is not hard but also not fun to have to adjust the holes in the tub deck to accommodate a different size.
AS for the suction.....I am assuming that you are referring to the inlet part o the pumping system and all of the equipment behind the tub. I always recommend that you use parts from the same manufacturer. It is extremely helpful to call them with all of the numbers you have to get a list of acceptable replacement parts.
Hope this helps.
Apr 27, 2009 | Home
Home Logo
198 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
