Question about Philips DVDR3380/05 DVD Recorder
Poor sound when playing dvd
I checked connection, I'm sure it's correct. There must be something wrong with the dvd player.
  • 687 Answers
Have you checked your TV audio inputs try using a separate audio lead from the DVDR to the TV most will have an AV input normally with two mono inputs this will also identify which channel has the fault if any.
LOL
Posted on Sep 24, 2009
My techwood won't play sound and the colour is completely wrong. How do I fix this?!
please see the chart troubleshooting. and fix it. God bless you
No sound
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Oct 14, 2013 | Gemini 1 Device Universal Television...
Samsung tv ct21m17mj
follow this steps and fix it. GOD BLESS YOU
  1. Make sure all power cords are connected.
  2. Try pressing the enter/play key.
  3. Make sure the TV is turned on and the input is set properly.
  4. Make sure the TV source is set properly on the TV (This is probably done on the screen; Check your TV manual).
No sound:
Jul 17, 2013 | Televison & Video
My dvd has no sound
Okay so this could be several things from something as simple as a cable has came loose to something a bit more serious like the dvd player overheating. Does the Tv's sound work? have you tried using another scart cable? and have you made sure all the cables are plugged in properly? If you can try and connect it to another scart port in the back of the tv. Once youve rulled out the TV and the Cabling it must be the DVD player. If you can try the DVD player in another TV aswell just to find out if you can get sound, If theres still no sound then im affraid your dvd player needs repaired.
Jul 04, 2013 | Televison & Video
My dvd player is playing color dvd's in black and white.
It sounds to me as if you have the Video standard wrong, Check what your standard is either PAL, NTSC or SECAM and make sure you have correct one activated. Sounds like a PAL signal being played NTSC. or vice versa.
Jan 26, 2010 | Televison & Video
Problem with vertical hold.
with your control push the set up button and on TV Output choose NTSC and Video Output choose S- Video.
Feb 15, 2009 | TruTech TT320
DVD player and receiver will not play a dvd in surround sound ?
The dvd player is responsible for reading the surround sound track, and sending it to the receiver. First make sure you are playing the surround sound track on the dvd, many have a stereo track too. Next, try another dvd and see if you can play surround sound on that one. If you can't play surround on ANY dvd I would start looking at the audio connection from dvd to receiver. Are you using an optical cable? Red, white, and yellow RCA cables? Optical will transmit any sound over only one cable, RCA cables need one cable for each channel (LF, C, RF, LR, RR, sub.) If your connections are correct, is the receiver set to play a surround sound track? Is it set in 2 channel mode?
Dec 28, 2008 | Harman Kardon AVR 35 Receiver
Cannot hear audio when connect dvd player to TV using analog audio cable
i think you need to get an Optical Digital Audio Cable and connect it to the tv and speakers then it should work
Jul 08, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
I am connecting a Technika 1031 to a LG 19LS4D using a good quality scart. I get sound but no picture. Connecting via the Y, Pb/Cb and Pr/Cr ports does nothing. Am I doing something wrong?
Make sure that the proper input is selected on the TV. Also, check to be sure that the correct output is activated on the DVD. I'm not familiar with the Technika brand so verify the output selection in the owner's manual.
If those selections are correct, try connecting to the standard AV input using the Red/White/Yel cable connection.
Dan
Mar 18, 2008 | Televison & Video
I need help in connecting my audio video system correctly once and for all.
http://www.retrevo.com/s/Denon-AVR-1803-Receivers-review-manual/id/363bh838/t/1-2/
please have a look in user manual above.
regarding your dvd check for yellow socket named dvd video in----or change your video cable.
Feb 08, 2008 | Denon AVR-1803 Receiver
DVD connection
Go back and check your connections again, sound like they are wrong...accordianman
Oct 16, 2007 | Hitachi 51F510 51" Rear Projection...
Philips DVDR3380/05 DVD Recorder Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
