Question about Tanaka Garden
Terex hr16 running fine then just lost all functionality. plenty of hydraulic fluid safty switch fine. could b pump?
4 Suggested Answers
  • 3 Answers
SOURCE: Hydraulics Pump not working
look around for a valve or a switch,and or button
Posted on Jan 13, 2009
  • 508 Answers
SOURCE: my fuel pumps dont run
There is a fuel pump relay switch usually found under the hood in the engine compartment on top of the left fenderwell. The three relays will be together and will be for the horn, starter and fuel pump. Replace the relay for the fuel pump. First rotate one of the known good relays into the fuel pump relays position to make sure that is the problem. If so you can get the relay at your local Ford dealer for about $16.00.
Posted on Feb 06, 2011
  • 14 Answers
SOURCE: the car wont start furl pump runs whrer is the safty switch
It wont be the safety switch as it shuts fuel pump off
Posted on Feb 05, 2016
I have a 35 ton black diamond log splitter . The ram won’t move it has plenty of hydraulic oil . Worked fine 2days ago .
does it make any noise when you press the lever?
it could be a number of things.
hydraulic circuits usually have bypasses when they reach a certain pressure the relief valve opens and oil is returned to the tank safely. if not you could have popped a safety v/v which is in place if the return circuit is not functioning it releases the oil pressure it may have to be replaced for it to function again. this may not be the case either sometimes with log splitters the track get clogged full of crud but you would hear the pump loading then unloading through the relief circuit. the ram could be bent but usually there would be an oil leak in this case. i assume that the pump is running and all that?
Oct 26, 2017 | Garden
I have a 3316 mahandra tractor the bucket or back hoe wont move I checked the hydraulic hoses they r fine I checked the filter it's full but the hydraulic pump ain't getting oil to it need help
You may have something stopping up the hydraulic supply line. You may have to bleed the air out of the cylinders. they often have bleeders in the end of the cylinders, if not crack the supply hoses loose and bleed air from them. Also loosen the pressure line side of the pump and bleed out air. The pumps should start pushing fluid out, crack the pressure lines while running. Also check that the vent cap is functioning properly. If it is not venting it can build up a vacuum that will starve the pump of oil.
Apr 25, 2014 | Garden
Dear Sir, We have one Sundstrand Turolla-200 make Hydraulic Pump, Model: TFP-200/6D SC51 LAA/9B , which is not building up hyd. pressure more than 80 bar. We are also not getting source of supplier for...
First you need to find out if you have fluid in the cylinder,if low or empty it will not build up pressure.Hydraulics are famous for blowing seals and bleeding hydraulic fluid everywhere. If you have fluid its possible the switch valve is sticking to go up or down or not working. if that is working check the pump motor to see if the motor shaft is attatched to the pump
Feb 15, 2011 | Danfoss Sundstrand-sauer-danfoss...
I have a 2000 Isuzu Rodeo and I am having problems starting the vehicle. I've been told that its the fuel pump. Is there a switch where the pump can be turned back on or does the fuel pump have to be...
  1. The observation with your vehicle implies mechanical malfunctions likely caused by insufficient, clogged, or burnout lubrication fluids. Since the component parts experiencing malfunction are observable at significant vehicle areas like power drive trains, several conditions are likely factors to driver's suspicion. For example, the drive train of significant mechanical sprockets linked at joints making propulsion possible with the control lever situated at drivers seating area is significant reason of concern. First, the driver's lever control functions hydraulically as modern improvement made possible with fluid lubrications, and several absorptions chambers. Once, an engineered hydraulic mechanical lever is realized to dispense manual contact requires inspections. First, a mechanical inspection to ascertain the conditions of constutuents providing hydraulic should be made on the vehicle. The possible outcomes include findings of an absence of faulty turbines implying no wear had occurred. Second, the observation findings may ascertain a burnout fluid that may require replacement procedures. For example, burnout hydraulic fluids usually may require cleaning draining, cleaning the residue slug from turbine areas making possible replacement of newer fluids. Hydraulic fluid conditions usually may require resistant variety that performs under overexerted conditions. For example, the fluid type may vary depending on the task requirements of the vehicle. Also, the type of condition expectations of the vehicle would require frequent hydraulic inspections.
Jan 22, 2011 | 2000 Isuzu Rodeo
The fuel pump will run and start the van but will not work at all on occasion.
Jan 22, 2011 | 1995 GMC Safari
I have a 2007 VW Touran, recently serviced. After a motorway run using the cruise control I often find the clutch feels as if it had lost all hydraulic pressure and I have to pump the pedal to get the...
It might be the brake & clutch fluid wrong because it is too old inside. First time change the brake & clutch fluid. If the problem persists then replace both clutch master hydraulic cylinder and clutch receiver hydraulic cylinder. Bleed also correctly the clutch hydraulic line!
Sep 06, 2010 | 2009 Volkswagen Routan
My 1994 Chevy silverado is spewing fluid when shifting operates fine haven't lost any gears and doesn't slip. What could be the cause
If the fluid is coming from the bell housing of the transmission, your front hydraulic pump seal has walked. The only fix for this is to remove and rebuild the transmission. This commonly happens around 200,000 miles.
May 30, 2010 | 1994 Chevrolet C1500
Ford 9n 3 point will not lift
Hey Chris..my name is Keith..and i restore 9N's,2N's and 8N's ..and i can help you with your hydraulic problem...the most probable cause is the hydraulic safety relief valve and i would change that 1st..the part number for it is..8N-638..and they cost about 25 dollars..and to change it..you either jack up the rear axle or you part the tractor down hill..so the hydraulic fluid goes to the front..and then you open up the side cover..that has the dip stick in it and unscrew the Safety relief valve from the hydraulic pump9located on the back side of the pump)..and install a new one..and have plenty of rags..because it is a mess job..and if you dont want to opent that cover again..i would replace the hydraulic control valve..part number 9N-640..is costs about 35 dollars and its on the back side of the pump also..and dont forget to get a new cover gasket and that part number is 9N-4131 and it costs about 1 dollar..i hope this has helped..if not write me back and we will get into the hard stuff on the hydraulic system
Mar 15, 2009 | Ford Garden
Lost all power steering fluid and brakes
Hi Salmancasmi,
On vehicles with a hydraulic booster you will find that the power steering pump supplies fluid through bot the steering gear box and the hydraulic booster.
Just a visual inspection of the system should point you to the part that failed, most likely a hose. These can be obtained through your local parts store or dealership.
Locate and replace the failed part, refill the reservoir with power steering fluid. With the front of the truck on jack stands, start the truck and turn the steering wheel from full left to full right several times while pumping the brakes. This will remove the air from the system. Recheck for leaks and fluid level and you'll be on your way.
Hope that helps, good luck.
Nov 26, 2008 | 2001 Ford F350 Super Duty SuperCab
Garden Logo
301 people viewed this question
Top Tanaka Garden Experts
john h
Nick Olsen
matt
matt
Are you a Tanaka Garden Expert? Answer questions, earn points and help others
