Question about Dometic Rooftop RV Air Conditioner
I had my 4 button CCC upgraded to a 5 button with the CCC upgrade kit. Now the T sat has EE and won't come on. I tried holding down the mode and zone buttons together and when I do i get the FF on display but as soon as I release them it goes back to EE on T stat and the units won't come on.I have tried this more than 10 times no luck!
  • 1 more comment
  • bpford Jul 12, 2009
    I'am sorry I don't understand what the sensar place is?
    No. I had a RV mobile repair man come and do it.
    He changed both boxes in both Roof airs.He also set the pin to on for unit 1 and 2. 1st tast worked fine till that afternoon when I came in and turned it to on .Nothing no air no light in stat. He came back and changed t stat and now the tstat is light and shows on only EE and still no air!
  • 3,230 Answers
First of all make sure sensar place of thermostate, do a check i think there must be some missing....
Post back further comments..
Good Luck!!
Thanks
Posted on Jul 12, 2009
  • Mukesh Kumar Jul 12, 2009
    Do you upgrade 5 button ccc yourself?
  • Mukesh Kumar Jul 13, 2009
    It seems that there must be some fault during the 5 button installation, so it will need a recheck ....
How do i remove the remote from safe mode?
Safe Mode is a diagnostic tool in the Remote used for troubleshooting purposes. If the words "Safe Mode" or "Safe Mode Requested" appear on the remote, complete the following steps:
1. Ensure the Remote is in "Safe Mode Requested" by taking out the batteries, and disconnecting the remote from the USB cable.
2. Hold down the Off button and plug the remote into the USB.
3. Continue holding down the Off button for another 10 seconds. The remote should then display the words "Safe Mode Requested".
4. With the unit in "Safe Mode Requested", re-install the firmware by clicking Support on your home page.
5. Click Firmware in the Downloads section and follow the online instructions to upgrade the firmware.
6. Once the firmware upgrade is complete, click Update My Remote.
7. Insert new batteries into the remote.
Jul 27, 2010 | Logitech Harmony 659 LCD Remote Control
Stuck in safe mode
1. Remove the batteries. While holding the 2 button down, connect the USB cable. The remote will boot into normal mode.
2. Update the firmware. Update the configuration.
3. There could be a stuck button on the remote causing the symptom. Remove the batteries from the remote. Push in, and massage each button ensuring it is not stuck down. Replace the batteries and Update the firmware. Update the configuration.
4. Remove the batteries from the remote. Manually place the remote into `Safe Mode` by holding off and plug in the USB. Upgrade the firmware in the remote. Update the configuration.
FIRMWARE:
1. Log into the Logitech Harmony Remote Software on your computer
2. Click on the Downloads button at the top-right corner of your screen
3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
4. Once the firmware upgrade is complete, click on the Update Remote button
5. Test your remote.
Jan 27, 2010 | Logitech Harmony 520 LCD Remote Control
Remote is in safe mode
You can try this solution to your Harmony 550 Safe mode problem:
Harmony 550 Safe Mode Fix Safe Mode is a diagnostic tool in the Remote used for troubleshooting purposes. If the words "Safe Mode" or "Safe Mode Requested" appear on the remote, complete the following steps:
Hope that helps.
Aug 18, 2009 | Logitech Harmony 550 Remote Control
It says safe mode
Hey!
I got my Harmony Remote stuck in safe mode and found the following link that got it working properly!!!
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=11941
I hope this helps!!!
-Kennedy
Aug 05, 2009 | Logitech Harmony 550 Remote Control
What is the EE message on the DuoTherm Comfort Control Center?
It means that an error has occurred. If you have a 4 button comfort control. Follow these steps to reset:
To initiate a RESET, do the following in the order
listed:
1) Turn control on to ensure annunciator data and light are present. If data and light are present, continue to next step. Depress MODE switch to activate annunciator light.
Simultaneously depress the bottom two buttons (temperature UP and DOWN) and hold.
While holding these buttons down, depress the MODE button once and release.
Release the two buttons previously held down. Depress the MODE button once again.
At this time the light should extinguish, and the mode should register “OFF”. If not, repeat these steps.
Retest system ensuring that all functions are present
and operational.
If you have the five button comfort control. Turn the unit off and hold down the mode and zone buttons together. While holding them down, turn the thermostat back on. Hold the buttons down until an FF appears on the screen. Release the buttons and the display should return to normal. If not, try it again.
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
My compressor will not start.
There are a few more things to try, in the control unit of the AC there is Cold Control/Freeze Switch. Take down the control unit (inside unit, remove inner shroud) and remove the cover, The freeze control is plugged into the blue plug on the board. Remove the plug and install a jumper wire in its place. Does the compressor come on? If so, you have a bad freeze control. If not, then we need to check and see if your AC power module is sending power to the Compressor. Check power across the relay in the control unit, Black to Blue. If the blue wire is hot, then you need to go upstairs to the top of the compressor and check the thermal overload. If the blue wire is not hot, the comfort control center may not be sending a signal to turn the compressor on. If it is not, do a reset of the CCC. For a five button system, turn the tstat off and hold down the Mode and Zone buttons simultaneously. While holding them down, turn the CCC on and hold the buttons until FF appears on the screen. Release the buttons and try the AC.
Four button reset -
should register “OFF”. If not, repeat Steps 2 through
6.
and operational.
Hope this helps,
Jeff
Rate me please!!
Jun 28, 2009 | Dometic 57915531 Air Conditioner
My harmony 550 remote is in Safe Mode and will not respond to any button I push. How do I get my remote to work again?
Did you try this response from the Logitech users' forum? It can't hurt to try since all your settings are stored on the web, not on the remote.
http://logitech-en-amr.custhelp.com/...i=&p_topview=1
Basically, Safe Mode is a diagnostic tool in the Remote used for troubleshooting purposes. If the words "Safe Mode" or "Safe Mode Requested" appear on the remote, complete the following steps:
Jun 15, 2009 | Logitech Harmony 550 Remote Control
Safe mode
NOTE: Ensure the new batteries are all the same brand.
Nov 26, 2008 | Logitech Harmony 659 LCD Remote Control
Delete or reset a wrong firmware file for IVO- m600 mp3 Player (Rockchip)
This is how to get into update mode,
All you do is this,
1) Switch the player OFF using the main on/off switch.
2) Hold down the "MENU" or the "PLAY" button and keep it held down.(try the other buttons if these dont work)
3) Connect the usb to the player.
4) Wait for about 10 seconds before releasing the button.
5) You should be now in "ROCK USB" upgrade mode
6) Then just start ConsumerUpdate and upload your firmware.
Nov 18, 2007 | Audio Players & Recorders
Information About Management Mode for Firmware Recovery
What is Management Mode? If you encounter an irrecoverable condition with the WRT54G v5, you can use Management Mode to recover the router by uploading a new firmware image. In Management Mode, the router will have just enough functionality to load a newer firmware. You should be able to recover the router is most situations. When will the WRT54G v5 enter Management Mode? The WRT54G v5 will enter Management Mode when: * The router's firmware is corrupt (for example, when the router's Power light is blinking), OR * When the router has been reset incorrectly using the following steps: 1. Unplug the power cord. 2. Press and hold the Reset button. 3. Plug power cord back in (Reset button still held in). 4. Wait about 5-10 seconds. How do I get out of Management Mode? * To get out of Management Mode, simply unplug the power cord from the back or router for ten (10) seconds and plug the power cord back in (without using the Reset button). If the router's firmware is complete and without error, the router will start up normally. If the above does not work, try: * Download a local copy of WRT54G Version 5 firmware that you can use for recovery. Visit http://www.linksys.com/download to download the latest firmware. After unzipping and extracting the firmware file, click on the Browse button from the Management Mode page, select the firmware file, and upgrade the firmware. After this, Reset the router normally (by holding in the Reset button for 10 seconds) and the router should exit Management Mode. How do I enter Management Mode manually to recover my router? NOTES: * The PC that will be used for the recovery MUST be connected to the router via a hardwired Ethernet cable and not a wirelessly connected computer. * Be sure that you have a local copy of WRT54G Version 5 firmware that you can use for recovery. Visit http://www.linksys.com/download to download the latest firmware. * In most cases, the router will be able to provide an IP address via DHCP when in Management Mode. If your PC does not automatically receive an IP address from the router, you will have to set up a static IP address for the upgrade. See Answer ID 534 for more information. * When the router is forced into Management Mode, the Power light will blink. 1. Unplug the power cord from the back of the router. 2. Hold down the Reset button. 3. While holding down the Reset button, plug back in the power cord to the router. 4. Continue to hold the Reset button for five (5) seconds. After five (5) seconds, release the button. 5. Wait for about one (1) minute. Then, on a computer connected to the router, launch a web browser (for example, Internet Explorer or Mozilla Firefox). 6. Type in the router's IP address of http://192.168.1.1 into the Address field and press the [Enter] key. 7. The Management Mode - Firmware Upgrade interface should appear. NOTE: If you accidentally enter into Management Mode, you can exit by simply unplugging the power cord from the router and by plugging it back in. 8. Click Browse and locate the firmware file. 9. Click Apply to start the firmware upgrade process. 10.Once the firmware upgrade process has successfully completed, an "Upgrade Success" message will appear to confirm that the upgrade has ended. 11. Unplug the power cord from the back of the router and plug it back in -- this will restart your router using the new firmware.
Feb 16, 2006 | Linksys (WRT54GC) Router
Dometic Rooftop RV Air Conditioner Logo
78 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
