Question about Samsung ML 1210 Laser Printer
Both Red error light AND paper light go on
There IS paper loaded. I've tried switching the printer on and off--no luck.
How does the ML-1210 let me know it needs a new toner cartridge? Maybe that;s the problem. But I don't want to buy one if it is NOT the problem.
Any advice?
Re: both Red error light AND paper light go on
It can be a fuser problem see what if the light is go on on the start or not if not you should chek your thermistor (heat sensing element) and clean it
some measurement must be taken
Posted on Jul 22, 2008
I too have a 1210. Had mine for nearly 3 years. It sounds like that the sensor may have debris or may need replacing. If you have paper in, and the red light is on, then it is most likly a hardware issue. I doubt it being toner, but remove cartridge and shake side-to-side. Check your manual as well.
Posted on Feb 16, 2008
0 characters
3 Points
Paper will not feed thru my Samsung ML-1210 Printer. How do I fix?
Check to see if you have dropped something in the feed... maybe a pencil, paper clip, some pizza...
Feb 21, 2015 | Samsung Printers & Copiers
Page is not loading during printing
Occasionally, paper cannot be load during a print job.
Some of causes include:
• The tray is overfilled.
• The front cover has been opened during a print job.
• Paper that does not meet paper specifications has been used.
• Paper that is outside of the supported size range has been used.
If a paper jam occurs, the On Line/Error LED on the control panel lights red.
Find and remove the jammed paper. If it is invisible, look inside the printer.
Note: U would find the complete instructions along with the screen shots in the below link
Best of Luck
Dec 05, 2010 | Samsung ML 2010 Laser Printer
The online error light is red on my ML-1610 Mono Laser Printer any ideas how to fix this?
It probably has a jam somewhere. Open each flap, remove the toner cartridge and check the paper path is clear.
Jul 16, 2010 | Samsung ML 1610 Laser Printer
Have you found a solution to the Samsung ml-2510 printer red error light staying problem?
There are a couple of reasons why this happen. A paper jam could have occurred. The cover might be open, try closing the
cover. There might be no paper in the tray, load paper in the tray. The toner cartridge is not installed. The printer has stopped printing due to a major error (you need to contact your manufacture for this).
Nov 11, 2009 | Samsung ML-2510 Laser Printer
Online/error light is red
When you pull the paper out, that affect paper loading switch inside(or paper status monitering switch)
pull all the paper out, check switch inside near Loding roller
put you paper back and Put the tonner cartridge back, close the door and try agian ( i solved my problem this way)
Mar 25, 2009 | Samsung ML 2010 Laser Printer
The online/error light is always red, and I can't print. I turn the printer off, change the toner and the light is still red, what can I do
Sep 13, 2008 | Samsung ML 1610 Laser Printer
Samsung ml 2010 r laser printer
Check your manual, there is a solution there or download the user guide from
this site below or read the information below.
LED pattern Possible Problems and Solutions
Your system has some problems. If this problem occurs,
contact your service representative.
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see “Clearing
Paper Jams” on page 5.6.
• The front cover is open. Close the front cover.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See “Installing the Toner
Cartridge” on page 2.4.
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
Jul 17, 2008 | Samsung ML 2010 Laser Printer
Randomly printer stops printing - need switch off and on to restart printing
Sounds like you are just beginning to have problems with the paper feeding. Try cleaning the roller or applying rubber cement per my other post on the paper feed topic.
Apr 12, 2008 | Samsung ML 1210 Laser Printer
Driver of samsung ML-1210 printer
hi Dear
Please send me the driver of Samsung ML 1210
With best regards Shakeeb
Oct 16, 2007 | Samsung ML 1210 Laser Printer
Unable to print
If both printers are connected through a parallel switch, be advised that changes on the switch do not take effect until the computer is restarted. Those boxes worked fine under DOS, but Windows does not support them. Connect the Samsung printer to the USB port and make sure you use a good quality cable and not those thin and cheap cables.
Aug 30, 2007 | Samsung ML 1210 Laser Printer
Samsung ML 1210 Laser Printer Logo
166 people viewed this question
Top Samsung Printers & Copiers Experts
Level 1 Expert
 Mike M
Mike M
Are you a Samsung Printer and Copier Expert? Answer questions, earn points and help others
