Question about Medion MD-40954 Notebook
Build-in laptop Keyboard types wrong characters
My USB external keybord works fine.
I tried another laptop keyboard and it was same problem (eg : 9 ->o9).
I check connections inside and everything seems right ..
So is it possible that it's a problem with driver ?
If it's not a driver problem , where is the problem ?
Thanks for your advices.
I need this laptop for university .... if I cann't fix it by myself I'd have to buy another one .
NB : Repair service don't have too much time to spend for this kind of problem . This is not too simple and cost of an hour of labor is expensive ; same for a motherboard ....
    Scholar:
  • 113 Answers
TRY GOING INTO YOUR KEYBOARD SETTINGS OFF THE START > CONTROL PANEL AND MAKE SURE THAT IT'S EITHER SET BACK TO DEFAULT OR THE PREFERRED SETTINGS .
Posted on Jul 13, 2009
About keybord
check the keyboard settings are correct. eg a US keyboard setting will give the @ symbol where the " symbol is. look in control panel/ keyboard/language settings for your options
Dec 23, 2013 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
The character keys and numeral keys dont print only make a noice when pressed
From your query I interprete as they key is not displayed in the screen. First check with the external usb keyboard. If the external keyboard is also not working, please check the keyboard layout in the control panel regional settings. If the external keyboard is working well, change the laptop keyboard.
Nov 13, 2017 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Hi my dell vostro key board has locked ,right hand side of keyboard blue light with a lock and 9 inside it .tried everything can you help
The 9 lock key means that your Number lock key is on. The blue light usually means that your blue tooth is on. Try connecting an external USB keyboard to see if it functions normally. If so then you need to have your keyboard replaced.
Jan 09, 2011 | Dell Vostro 1500 Notebook
My laptop is dell inspiron 1501 but no work keybord and battery charging but supply line(AC adaptor) is ok.
Hello there. The Inspiron 1510 was released almost 5 years ago. If your system is more than 2 years old, then perhaps you will have to replace the battery. Battery for the most part, will only last 1 to 2 years. As for the battery, try connecting an external USB keyboard. If its working, then you need to replace the laptop's keyboard. Hope this will help.
Mel
Feb 13, 2010 | Dell Inspiron 1501 Notebook
I still can't get my Fn key to unlock. I've tried everything suggested here and by your associate to uninstall keyboard & reinstall. I have my laptop keyboard hooked up to another keyboard and it is...
Change your keybord layout in control panel->regional settings.
Then if still same thn your laptop keybord has issue because anothr usb keybord works fine.
There is not issue with operating system you need to repair your laptop key bord.
If it is warrenty you can use warrenty
Let me know if you need further assistance.Thanks for using fixya.
Nov 22, 2009 | Intel Durabook V38263 Notebook
The keyboard does!t work
remove the connections and reinsert them also uninstall and then connect and reinstall keyboard.
Jan 12, 2009 | Adesso Gift Idea Under $50: Win-Touch...
Keyboard, Touch mouse and all USB pads not working
first of all u have to re install windows( operating system)
before inserting the windows cd u have to plug an external keybord and mouse and start the system.
boot from cd and continue.
the laptop keybord and mouse could be unusable anymore.
May 24, 2008 | Acer Aspire 5100 Notebook
Compaq Presario v2405us Laptop keyboard help
yes u can remove keybord cheak loose connectons also FN button did u hitthat to stop keybord from working sumtime sthat doe sit hit fn button and try sum keys u can replce the keybord pretty easy get part on ebay install it yourself im open for chat thx nick helpap in saginaw michigan
Jan 07, 2008 | Compaq Keyboard
Keyboard detection problem
if the kb works on another system then the ribbion is ok, right?, the port on the motherboard is broken, which is almost certainly integrated(soldered to the board with no wires in between) which means to replace just the port you need to get a desoldering tool and cloth and a soldering iron(do not use a gun, they are not as acurate when working with this small of a space) and of course some solder, not to mention the replacement part or a more seriously broken laptop with the same part that you can take apart, seems like a lot of work to resurect a laptop, i would suggest a new board, new laptop or get a usb kb, maybe one of those rollup ones they sell on thinkgeek.com so you can retain some of the protablity, then again since the onboard kb is not functional it just sorta becomes deskspace for an external one. the fastest cheapest fix would be an external keyboard, next time i would recomend knowing what you are doing a little better before working on a valueable system or any that you cannot afford to loose, I see people break the ribbion cables and connectors all the time when working on laptops, its usualy because they dont know how to open the clips on the connectors, anyways try to be more careful next time
Jul 09, 2007 | Toshiba (225EXTR5)
Medion MD-40954 Notebook Logo
228 people viewed this question
Top Medion Computers & Internet Experts
Larry Chandler
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
