Question about Sony VAIO VGN-N250E/W Notebook
I spilled a little white wine on my Gateway laptop keyboard. I immediately turned it upside down, then removed the battery and power cord. I let it dry overnight (upside down). The next day I replaced the battery and power cord but it did not power on. I left it for a while (plugged in) and later went back and it started right up. However, I received a message at first saying that the system wasn't recognizing a battery present. After unplugging and plugging back in the message changed from 'no battery detected' to 'plugged in but battery not charging' or something to that effect. It gradually had a shorter and shorter time that the computer would remain with power. It did work normally for days after the spill with the exception that I needede to have it plugged in. As soon as I would unplug the computer it would remain on for a minute (if that) then shut down. Now I cannot even power it on, even with the power cord. Is this a power source problem alone? (I did take up my keyboard to clean it but only after it wouldn't power on and without disconnecting the keyboard from the computer) Also tried the removal of all power, battery and cord and held down the power button then replaced battery and cord, but nothing). Any insight would be greatly appreciated.
  • 448 Answers
Please remove the Battery from the Battery bay and disconnect the AC Adaptor from the Notebook. Then, clean the metal contact in the Battery Bay and leave the Battery removed for half an hour. Next, connect the AC Adaptor to the Notebook and the power cable to a functional wall outlet and try to turn ON the Notebook. If the power LED on the Notebook doesn't glow then again disconnect the AC Adaptor and try removing and reinserting the RAM module. If the issue persists even after performing all the above steps then service will be required.
However, if the Notebook turns on after performing the above mentioned steps but the Battery is not detected then perform C: Drive Restore using the VAIO Recovery Center.
As per the specification published online, the Computer model VGN-N250E is preinstalled with the VAIO Recovery Center in the hidden partition of the Computer. You may use it to perform C: Drive Restore to restore the Computer to the original factory settings. Please make sure that the new Battery is installed in the Computer while performing the Complete System Restore.
Performing a C: Drive Recovery will erase all the data present in the C: Drive only and will reinstall the pre-installed Operating System, Applications and the original Drivers supplied with the Computer.
Please restart the Computer and keep on tapping the F10 key to access the VAIO Recovery Center. Next press the Enter key then select the "VAIO Recovery Center" option then follow the steps given in the link mentioned below to proceed with the C: Drive Restore.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C473668
In the link given above, please click on the sublink "Restore C: Drive" to view further information on performing the C: Drive Restore.
Performing all the steps successfully should resolve the issue.
Posted on Jul 12, 2009
Spill on laptop keyboard now wont power up
You probably shorted something. Food and computers don't mix.
Jan 25, 2014 | Lenovo IdeaPad Z560 Notebook
Tip
Liquid spills
Todays notebooks & laptops come equipped with spill resistant keyboards. Thats a big help in itself. But some are not . If your notebook has suffered a liquid spill while its on , IMMEDIATELY shut it down. GET AWAY from carpeting or metal furniture or objects: stand on wood or cement floor only. Turn the unit and place on its side to drain it from the liquid (NOT UPSIDE DOWN) and to avoid further damage to mainboard and keyboard. DO NOT TURN IT ON AGAIN  . Remove the battery, hard disk drive, CDROM, memory modules, remove back cover, until exposed to mainboard. Take conventional hair dryer, blow dry using HIGH heat, slowly move over peripherals and mainboard  five inches away with  Extra drying process on keyboard and mainboard. Using a few cotton balls, pat down any excess liquid by absorbing into cotton -- blow dry this area intensley for long time (20-35 minutes, depending on amount of liquid spill). Wait a few days , replace all parts and turn on notebook.
on Jan 21, 2012 | HP Computers & Internet
Keyboard dont type
No matter how careful you may be, knocking a cup of coffee or spilling a glass of soda over your keyboard may happen. This does not, however, mean the end of your keyboard. If you act quickly, you may be able to fix your wet keyboard to avoid any corrosion of its electronic components or any short circuit which might render it unusable. By following a few recommendations, you should be able to fix your wet computer keyboard.
Unplug the keyboard from your computer immediately after the spill to avoid any corrosion or short circuit. If you spilled water over your laptop's keyboard, turn your computer off by clicking on "Shut Down" on "Turn Off" in the start menu, unplug the power supply and remove the battery. Turn the keyboard upside down and shake it to remove most of the water from it. Take a hair dryer and set it to its lowest temperature setting. Use it to dry any water which might remain under your keyboard's keys. Wait at least 12 hours before plugging your keyboard into your computer again. If your computer is a laptop, wait 12 hours before turning it on again. For Other Liquids Disconnect the keyboard from your computer immediately after the spill to avoid any short circuit or corrosion. Turn your computer off by selecting "Shut Down" or "Turn Off" in the start menu, remove the battery and disconnect the power supply. Place paper towels on a table, turn the keyboard upside down and shake it over them to allow most of the liquid to fall down. Take a few clean paper towels and wipe the liquid off your keyboard's keys. To clean between the keys, you can also use cotton swabs with just a little bit of water. If the liquid which you spilled over your keyboard contained a high amount of sugar, such as soda or sugared coffee, you might have to remove some of your keyboard's keys to clean the surface under the keys with paper towels or swabs. You can do so by lifting them gently with a screwdriver or by using a key remover, which you can find in some IT stores. Wait at least 12 hours before using your keyboard again. If your computer is a laptop, wait the same length of time before turning it on again. How to Clean Your Keyboard http://www.tucows.com/article/684 Fix Computer Keyboard Problems http://technologyandinternet.blogspot.com/2007/10/fix-computer-keyboard-problems.html
Apr 20, 2013 | E-Machines eMachines Desktop PC
Spilled water on my asus laptop
Maybe or maybe not.They can not be opened.
Oct 23, 2012 | ASUS Computers & Internet
Soda spill on inspiron
Okay shut it down, do not try to boot it up!! You want to first open the lid as far as it goes and turn it upside down to try and get as much of the liquid out. Then you want to remove the keyboard and all covers from underneath the laptop use compressed air to dry the laptop as much as you can, then with some alcohol and small brush clean soda residue let sit and dry for at least a couple of days. Then re install battery, keyboard and all covers. Then try to boot it up. Hopefully you did not short out the motherboard, or mouse pad and keyboard. Good luck.
Mar 10, 2011 | Dell Inspiron 1525 Notebook
Mykeyboardisnotworkingeverytimeiclickitnothinghappentellmewhattodo
dirt between the buttons can be one reason, another is wear between the contacts, keyboard is easy cleaned, just put it upside down and use stiff brush to clean between the buttons.
if contacts are dirty, usually caused by spill (my son spill coffe at least twice a year on keyboard during last 10 years of his programming...). easy way is to if use corded keyboard (if wireless start from step3)
1. switch off the computer
2. remove keyboard cable from socket
3. remove batteries if installed
4. turn keyboard upside down
5. remove all screws
6. turn back to correct position
7. remove top frame (with keys)
8. check for any physical debris and remove if any
9. lift rubberised pad and whipe bottom of it with methylated spirit, allow to dry
10. check if plastic film can be separated, if so, whipe each layer with methylated spirit, do not under any circumstances break any of printed conduit lines.
11. when all is dry, put all back together in reverse order. watch for little springs present in some models.
12. go to shop and buy new keyboard... they are about $5.00 to $250.00 in that broad range you can find something suitable and affordable...
this is general description of the keyboard "gizzards", they vary slightly between the brands but principle is this same. if you have keyboard made before 1994, it will be electro-mechanical switches and that will cause more trouble...
Jul 29, 2010 | Computers & Internet
Spilled water on thinkpad t23 kybd
Hi, let it dry for a good few days, then try , hopefully it will; be ok.
Anthony
Jan 30, 2010 | IBM ThinkPad T23 2647 Notebook
I spilled a small amount of coffee onto the keyboard while the computer was in use. I immediately turned it upside down and dried it off. I cannot get it to power " on"
Don't power it on. If that is doesn't seem kind of all water proof kind. Take out the battery and the AC power supply. Turn the laptop upside down without closing the screen monitor and let the coffee be out. Dry it/or take it on a reputable shop( I may suggest).
Have it clean. Hope it doesn't fry something inside.
Sep 21, 2009 | Lenovo ThinkPad T400 - Intel Centrino 2...
Sony VAIO VGN-N250E/W Notebook Logo
384 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
