Question about Cingular Wireless Smartphone 2125 Smartphone
Lionking smartphone to BMW 750
BMW doesn't provide a means to link smartphones to the bmw handsfree system installed in the car (750) When I first got the car, a friend at Microsoft changed some of the programming in the phone so that it recognized the phone and it worked correctly. I had to get a replacement phone and now he's no longer available; my new phone doesn't sync with the system. Is there a program I can download to fix the new phone to work as the old one?
How to install an Alpine DVD unit into my BMW E46 M3 convertible
Providing it fits the aperture properly the only thing you may need is a special jumper cable harness that links the BMW euro standard harness to your player. Its possible the harness is right anyway but be prepared.
Oct 20, 2014 | Alpine IVE-W530 - 6.1" In-Dash Video...
Dose the amp go bad on 2006 bmw 750li
Radio failures occur regularly after all they are prone to shorts , over voltage, surges, incorrect polarity hook up etc. The problem I think is that the radio installer hesitates to work on your unit because he may want approval from bmw to work on it possibly under warranty. Some vehicles state that any unauthorised work voids warranty. Clear the air with the radio teck and find out his problem exactly and if still in doubt take it somewhere else.
Mar 31, 2013 | 2006 BMW 750Li
My speed sensor needs replaced on my 1999 BMW 750 iL, where is this located?
It looks like you actually have two of them and they are near the rear wheel carriers. I have provided a diagram for you.
http://realoem.com/bmw/showparts.do?model=GJ03&mospid=48546&btnr=33_0444&hg=33&fg=30
Mar 15, 2011 | 1999 BMW 7 Series
Bmw 750il 1999 not start when I changed battery
Did you mean charged or changed? If charged, it could be battery has lost depth of charge. You can charge a "tired" battery for hours only to have "surface charge". Just doesn't charge deep into the plates like it used to. If changed - did you get a big enough battery? That 750 (12 cyl) is a monster on battery and your electrical system is almost in the NASA sphere of complications.
Jan 05, 2011 | 1999 BMW 7 Series
BMW Bluetooth related issue. The BT menu would not initiate - menu will show up with TEL,BC & CONFIG but the telephone icon would...
Ismail,i have been wrong before BUT i dont think the bt kit is compatible with the bmw system,(same as Audi/VW)the Parot or vodaphone system is the ones we used to fit to for customers who requested handsfree. regards.Geoff.
Nov 24, 2010 | 2006 BMW 3 Series
Resetting brake warning lamp 2006 bmw 750 li
you will require to take the car to a dealer to resett this
Apr 03, 2009 | 2006 BMW 750Li
Bluetooth?
Even if you have the handsfree kit installed (a little mic above the steering wheel console + the nice little bluetooth button on the steering wheel next to the radio controls) it does not mean you actually have bluetooth. Check your trunk. If you have the bluetooth module, it will be a black box, about half the length of a VHS and visible against the wall seperating the trunk from the inside of the car. The wire usually leads from the center console into the trunk and on some occassions, the module can be hidden under the mat you have to take out when accessing your spare.
Hope this helps!
Jan 18, 2009 | 2004 BMW Z4
How to set-up handsfree system on 2002 bmw 525i?
turn on bluetooth to your vehicle...open your phone to bluetooth you should see a menue that says pair devece or look for devices to pair with click on that and let it searchh that should fix the prob...
Dec 20, 2008 | 2002 BMW 5 Series
Cingular Wireless Smartphone 2125 Smartphone Logo
59 people viewed this question
Top Cingular Wireless Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
fordexpert
Erik Walters
Are you a Cingular Wireless Computer and Internet Expert? Answer questions, earn points and help others
