Question about Boating
I have a 2000 5.7 efi with bravo3. It seems to have a dead miss maybe one cinlinder. Changed plugs and tested for fire on each.(good)Checked injectors and they are working fine except one side seems to dump a little more fuel than the other, and some times when I shut the engine off the TBI fuse blows. Any ideas?
  • 5,537 Answers
This sounds like you should ask several boat repair shops if they have a tester for the TBI module. By the flow you suspect the TBI is not regulating correctly and with a fuse blowing intermittingly it indicates grounding somewhere. You might do a close inspection of the injector wires and unwrap their wiring loom to see if there is evidence of shorting.
If there is slack in the TBI loom try a wiggle test with the engine running to see if miss changes.
Posted on Jul 28, 2009
Miss fire after up to temp and runfor short amount of time. I get a miss fire coming to a stop..drops to cylinders or 1. will not accelerate at all boggs with miss fire.
Check your tank vent. Ride the bike until it stalls, pull over and pop open the gas tank lid. If you hear a "ffffwwwwwah" of air being sucked in when you open the tank, your air vent is blocked. The bike runs great when you start out, but as fuel is taken out of the tank no air can get in to replace it and the tank develops a vacuum.
Jan 14, 2015 | 2000 Yamaha V-Max
Joe, i'm afraid we'll need some more info; year, make and model. Have you changed anything to after market like air cleaners or exhaust? How many miles are on it?
Jan 14, 2015 | Motorcycles
1994 Geo Metro will not start
all spark plugs dead. and at the main coil?
in this case after fuse (test them , ones that look good can be bad)
these steps work or all EFI cars made.
first is the rotor spinning cranking, if not the cam belt snapped!
a 1 second check, do you try to run 60k mile belts 200k ?
  1. CEL lamp on? key on? no crank? y/n,, if no the ECU is dead. or lamp burned out, we fix this FIRST. for next tests.
  2. I insert the diagnostic jumper clip (paper clip)
  3. the CEL now flashes codes, write them all down.
  4. I then crank for 5 seconds. and release the key.
  5. The ECU then reports live codes. beyond above stored codes.
  6. The ECU is very good at finding bad crank or cam sensors dead or even missing pulses, 1 in 10 lost. trust it, on all cars ......
  7. if no sensor code errors or spark bad errors then do the next things.
  8. The ecu also reads back the Tacho signal and will report dead tacho, sig, the ECU creates this and is the COIL drive signal to the ignition coil via the IGNITOR device.
  9. If the ignitor dies, or the coil primary opens, (dead Ign.coil) then the ECU see this and gives you Spark fail codes, cranking only!
  10. if you get far with a dead ignition coil, the ignitor is bad or the coil assuming coil even has power 12vcd key on.
this is all in the FSM, if you read it.
as is the Ignitior tests, and the coil tests.
The FSM is an amazing thing if your read it.
buy one.
ECU = engine brain, or EFI brain
EFI = eletronic fuel injection
CEL is the check engine light also called SES or MIL.
your ECU is OBD1 and no scan tool works .
only the winky blinky light.
Mar 04, 2014 | 1994 Geo Metro
Cerokee 3,1td startoff solenoid
which engine, no engine stated means answers will be wrong.
so??????????????????
that above is a statement so will run with that.
so what makes you think there is no fuel pressure??
1: the pressure gage is way low? how low , that you connected.
2: the pump seems silent. (near useless test)
3: pump never gets 12vdc cranking, you must crank.
4: the dribble test fails. (wasted time) (rail drips)
5: the injectors seem all dry, (spark plug tips are all dry)
now EFI 101 (crash course)
THE EFI system will be dead if fuse are blown.
and the ECU never injects with spark errors.
or CKP errors
or CMP errors
or IMMO is active. immobilizer is unhappy see lamp, look at it.
if all that works good, the ASD closes
the injectors fire
and the car starts if the ECU/PCM sees any errors stated above
it drops out in 2seconds <KILLING all injections,.
this is the PCM logic hard coded for fire prevention. all cars have it
with EFI.
does that help.
key factorys, ASD closes, for 2 seconds.
crank with no errors (scan tool shows errors after 5 seconds cranking)
if that works the engine does start.
ask for more tests, i have 3 more that find any bad start.
Feb 16, 2014 | Jeep Grand Cherokee Cars & Trucks
Number 2 cylinder misfire at idle. Runs smooth at 1000 rpms
Could be a loose connection at the plug or at the coils. Look at in the dark and see if you see any spark off.
Aug 27, 2017 | 2000 Chevrolet Blazer
2008 96ci EFI a year ago at 25,000 miles changed to a 103 stage 2 with stock head and SE 255 cam which harley installed Now at 53,000 miles changed to 103 SE 11:1:1 piston SE 110 heads SE263 cam.This is my...
The Night rider site is not set up so that one can ask a question. It's more a site that offers information about "how to" stuff so that you can read and learn how to do a job or verify that you have done the job correctly.
According to your response, I'm assuming you have good compression and you're confident in your work as the cams are concerned. Now, the problem seems to be more electrical rather than mechanical. Have you checked for spark at the plugs? The Twin Cam engines have a compression sensor. If this sensor does not sense compression, the plugs won't fire. This could be your problem since you installed the compression releases. Have you somehow over ridden these sensors?
Good Luck
Steve
P.S. I have no formal training with the Twin Cam enignes nor do I work on them. I've got all I want to do with the older models. Especially the Shovelheads. It's gotten very difficult to find a Shovelhead mechanic these days. The last year for the Shovel was 1984 for most models.
Nov 08, 2010 | Harley Davidson FXD Dyna Super Glide...
I have a 2000 neon with a 2 liter, it has a skip in the motor.it is a pretty bad miss i can barely take off. i hold the pedal then after a few seconds(5-10) it finally takes off but with no power a bad...
on the plugs that you changed did you notice a black carbon trace on the ceramic part of either one of the plugs,if there is this means the wire is firing to the ceramic part of the plug, you will need plug wires, if any mark on plugs you just installed replace them also
Aug 18, 2009 | 2000 Dodge Neon
Lack of power, hesitation, #1 miss firing
you may need to perform a leak down test to the cyliner and maybe you may have carbon on that valve. make sure the new spark plug wire has the correct continiuty
Jul 27, 2009 | Mitsubishi Mirage Cars & Trucks
2000 bonneville will not crank-battery good-starter good
Hey Cameron check your battery cables!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Nov 12, 2008 | 2000 Pontiac Bonneville
Boating Logo
67 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
