The bobbin housing fell out on my machine and I can't figure out how to get it back in.
SOURCE: Putting my machine back to operating order
Go to this link; http://www.sew4less.com/manuals.php and select your machine brand and model. Unfortunately they are not free, but you can purchase the instruction manual, the parts manual and the service manual of you wish. Sorry i hunted for free ones with no success. Hope this helps :)
SOURCE: bobbin compartment trouble
Put the needle in the up position. Tilt the machine back with one hand and lay the hook in its position on what is called the hookrace. The little ledge inside the the circle opposite the other part that moves. Then take the outer ring and lay that in over top of it. There is a small pin on the bottom that fits into a notch. The two small nubs should be on the outside, then click the two black knobs over those. Put the bobbin in the case and the thread through the notch up under the tension spring on the case. Looking at the back of the case, pull the thread and in most machines the bobbin should turn clock-wise. Now snap it onto the post.
Your good to go.
Good luck.
SOURCE: the bobbin housing fell out
You can see a the directions on www.ehow.com, they have nice large diagrams. About holding the bobbin case and the tab being used to insert it in the shuttle case. Your manual does a decent job too, with diagrams that you can enlarge. If, you can't find your manual go to www.brother-usa.com and under support you can get a copy to download for free. Save it to your computer.
