4 cylinder. The alternator was new the serpentine belt and fan belt were lose due to no tensioner bolt. Is the tensioner connected to the alternator. The alternator is new.
SOURCE: Serpentine belt problem
I had the same problem and went through a number of serpentine belts, one possible solution is the tensioner, but another to look at is the power steering pump pulley, mine has shifte just enough to cause the belt to move, it is a bugger to shim, I cut a flat washer in half and stuck it in place between the pump and the bracket, gl...
SOURCE: need diagram for 2000 dodge dakota serpentine belt
On the 1999 Dakota with the 3.9liter, the fan shroud absolutely DOES NOT have to be removed. Very simple job. Simply use a breaker bar with a 15mm socket on the belt tesioner pulley nut. Using the breaker bar push (as though tightening) the pulley nut...the reaction will be that the tensioner removes tension from the pulley and the entire belt can be removed by easily slipping it toward the front of the vehicle...comes right off. The new belt can go back on in exactly the same manner. By the way the belt routing diagram IS CONVIENENTLY LOCATED between the hood latch and the radiator mounting for simple and quick refernce...one person job, I did removal and installation four times in less than 10 minutes. (why four times? The auto parts store was selling replacement belts that were too long and did not allow the belt tensioner to provide suffiecient tension...I had to try four different manufacturers before the tensioner was adequately tight with room to grow as the belt naturally stretches from use.). I found no stringing around the fan is required because of the way the belt is routed (it doglegs around the main engine pulley which is centered below the fanhousing and then the belt runs from there to the left side of the fan housing...avoiding the fan/fanhousing all-together (sure you can try to go past the fan/fan housing if you so desire...but you dont have to...and besides the space between the pulleys and the fan is ample to allow the belt to pass between with minimal interference or a simple rotation of the fan as you attempt this method. One hint that made my installs easy as pie...the last pulley you put it over should not be a bezeled and ridged pulley or you will needlessly make life difficult for yourself...the last pulley should be the water pump pulley which is a smooth bore and non-ridged pulley (makes you wonder how the belt even stays on it!)...making it easy as pie to slip it right over...as your last act of defiance to that mean old serpentine belt!
SOURCE: i need to change the alternator on my 2000 dodge
I have to use a 15mm open/closed end wrench on the tensioner pulley. Use the closed end of the 15mm and pull toward you and use the end of a cresent wrench to use for additional torque. You can slip the belt over the fixed pulley (not the tensioner pulley). Give yourself more room by not using the hood bar and use instead a broomstick on the right side to prop the hood open. I recommend a goodyear gator belt too. Good Luck, you'll need it with a caravan. Its on the left side. its the easyest pully to see.
http://www.autozone.com/images/cds/jpg/small/0900823d8010b6d6.jpg
http://image01.shopzilla-images.com/resize?sq=140&uid=762102759
Hope this helps and please don't forget to rate.
SOURCE: How to tension a serpentine belt
It sounds like you have an auto tensioner. There is a square hole in the bracket the tensioner is mounted on. Put a breaker-bar drive or ratchet-drive (3/8 or 1/2) in that hole -- this will allow you to move the tensioner so you can get the belt around the water pump.
SOURCE: serpentine belt slips off
Please tighten the grip for the belt to enable tighter stay in-line.
Sorry.
Locate the two belts on the left side (passenger side) of your Mitsubishi Lancer. The outer belt is a serpentine belt, operating four pulleys and the inner belt is your alternator belt.
Follow the serpentine (outer) belt to the three pulleys lined up vertically near the front of the engine compartment. Locate the middle pulley, which is the tension pulley for the belt.
Loosen the bolt on the middle pulley with a socket wrench by turning counter-clockwise. Do not remove the bolt, just turn it a couple of times. Loosen the tensioner bolt on the side of the of the pulley, facing the front of the vehicle.
Remove the serpentine belt and then loosen the bolt on the alternator. With the alternator loose, move it forward so that the alternator belt loosens up and then remove belt from the pulleys.
Install the new alternator belt by placing it over both inside pulleys. Tighten the tension on the alternator belt by moving the alternator back and keeping tension on it by holding it back with a long screwdriver. While the alternator belt is tight, use a socket wrench to tighten up the bolt on the alternator.
Place the serpentine belt back on the pulleys and then use a socket wrench on the bolt on the front of the tension pulley. Once the serpentine belt is tight, tighten up the bolt in the middle of the tension pulley.
Start the Mitsubishi Lancer's engine to test the alternator belt and make sure it is working properly. Once you have verified it is working, turn the engine off.
